Lowrance LGC-2000 GPS Unit GPS Receiver Logo
Posted on Jun 30, 2009
Where to put gps receiver, for fish finder, lowrance m52 s/gps
Just bought from bcf it and no instructions in the book about where to put the receiver.
Anonymous
Level 1:
Scholar:
  • Contributor 30 Answers
  • Posted on Jul 08, 2009
Anonymous
Contributor
Level 1:
Scholar:
Answers
30
Questions
0
Helped
18287
Points
52
The receiver needs to be mounted so that it has a clear, unobstructed view of the sky. It will be fine through glass windshields, fiberglass and cloth tops. Keep it at least 2 feet away from the display unit.
My Lowrance 525C Fish Finder comes on to Lowrance screen but does nothing when I mash any of the buttons. Eventually turns off by itself.
Question edited for clarity.
Make sure you got the correct transducer Your model comes in single frequency and dual frequency. Make sure the connection on the back of the unit is good and you have no corroded or missing pins. Make sure the software is up to date.
Lowrance LMS-525C DF Fish Finder Parts
Product Description: Designed for salt water or downrigger tracking, this dual-frequency sonar/GPS chartplotter
provides additional 50 kHz readings, in addition to a high-res 480 x 480 display on a 5" screen
and many professional features.
* Dual-frequency 50/200 kHz
* Precision 12-parallel channel external GPS+WAAS receiver
* Lowrance radar compatible
* LowranceNET® networking (NMEA 2000® certification pending)
* High-speed ethernet connection links multiple Lowrance display units and modules to
operate independently on shared network data, including sonar
200 khz transducer PDRT-WBL Part #106-89
Shoot-thru-hull mount, 20 degree pod type with remote temperature (200 kHz). (20 ft cable) Dual Frequency Transducer HP-DFBL260 Part #106-82
Thru-hull-mount, dual frequency bronze housing, high-power multiple element (50 kHz 19 degree
& 200 kHz 6 degree).
HST-DFSBL Part #106-77
Transom-mount, dual frequency skimmer with built-in temperature sensor. (25 feet of cable)
https://www.google.com/search?q=lowrance+lms-525c+df+software+update
1helpful
My fish finder shutsdown or restarts when I start my main motor
are they drawing power from the same bat? it maybe that starting the motor drop the voltage the finder receives
Why don't I see fish on my lowrance elite5 hdi fish locator
Sounds like you do not have your transducer connected.
You will know it is working if you have a bottom sounding. If you have a bottom sounding (depth reading) and it is correct then you may have to fine tune the finder to see the fish.
I have the same finder on my boat. http://njsaltfish.com/index.php/captainsfocus?sid=61
Where do I get a manual for lowrance elite 5 fish finder chart plotter gps
Just type this into your browser's searchbox. manualslib.com/manual/292954/Lowrance-Elite-5-Dsi.html
You should be able to pull up the manual there.I just did. Garcuda
I have a lowrance LMS 520c and I never pick up any fish. it does show the bottom
read the book that came with it you got to understand how it works and know how to set your unit before you can understand how it works and what you need to do to make it work and to get to what settings you want ..a fish finder is like a computer you got to program it to your likings .. I have a hd 10 structure scan on mine .. .now that's a nightmare to set but the book tells you everything you need to do and how to do it and how to get what your looking for and how to get to it
2answers
Lowrance 112c gps shuts off when cranking main engine?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} This is very common when using a single battery system in you boat.
If you more then battery connect the fish finder to the second battery.
Or if the Depth finder is connected through the acc. on the boat. The power is being cut off be fore the starter is engaged. By pass this and connect through a correct size fuse.
4answers
I need a manual!!
you can find the manual here,
www.lowrance.com/upload/Lowrance/Documents/Manuals/LMS339cDF_iGPS_0152-011_011206.pdf
Hope my info solves your problem,
Thanx for using fixya.....
Installing an old used lowrance fish finder
I don't think your old fish finder is the LMS-332C GPS Receiver listed above in the description. You don't need the speed wheel for the fish finder to function just the transducer and transducer mount. You should mount that on the back of the boat towards the center but not too close to the motor and not too close to the side of the board. Don't let it hand below the level of the boat. That should keep it from getting hit by the trailer or dragging on the bottom. Try to make it as level as possible. The green and white wires may be for the speed wheel but i'd need a model number for clarification. Hope this helps.
Top Lowrance GPS Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
ADMIN Eric
ADMIN Eric
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
