Question about Zenith DBZN-311 Remote Control
Can't get it to program. need code and steps
Having problems with the code for cyber home dvd
Posted on Jun 30, 2009
How do I program my tv remote
HI,
DIRECT CODE ENTRY
Step 1:Press and hold the "CODE SEARCH" button ("CODE.SRCH" for RCU500).
Step 2:Press and release the device (VCR, TV, Cable etc.) button. If programming for AUX, press and release AUX button first, then press the device type to be programmed.
Step 3:Enter the 3 digit code number
Step 4:Release the "CODE SEARCH" button.
Step 5:With your device on, press another button like "PROGRAM UP/DOWN" OR "VOLUM UP/DOWN" to test.
CODE SEARCH
If you cannot locate the code for your device, try thecode searchmethod below:
Step 1:Turn on the device.
Step 2:Press and hold the "CODE SEARCH" button.
Step 3:Press and release the VCR, TV, Cable or Audio button. If programming for AUX, press and release AUX button first, then press the device type to be programmed.
Step 5:Press "ON/OFF" (or "POWER" for RCU500) repeatedly until the device turns off. Note that because there are so many codes, you may have to press the "ON/OFF" button up to a hundred times (at a rate of once per second) if your code is towards the end of the preprogrammed list.
Step 6:When your device shuts off, press and release the "ENTER" button.
Step 7:With your device on, press another button like "PROGRAM UP/DOWN" OR "VOLUM UP/DOWN" to test, and if it does not function correctly repeat steps 1 through 6.
CHECK THE LINK FOR CODE
Electronics Equipment Repair Center RCA UNIVERSAL REMOTE CONTROL 3 DIGIT...
Electronics Equipment Repair Center RCA UNIVERSAL REMOTE 4 DIGIT CODE FOR...
Electronics Equipment Repair Center 3 DIGIT RCA UNIVERSAL REMOTE CODE FOR...
Sep 27, 2014 | RCA Televison & Video
Keypad instructions for entry - need instructions to change combination
Programming/Erasing Personal Code
A unique personal five-digit code can be programmed by following these steps:
  1. Enter the factory set five-digit code (the keypad will illuminate when pressed).
  1. Press 1/2 within five seconds of Step 1.
  1. Enter the unique five-digit code.
The personal code does not substitute for the permanent factory set code. Either code can be used to access the vehicle. In addition, if a second personal code is programmed, it overwrites the previous personal code. To erase a personal code, carry out the following procedure:
  1. Enter factory set five-digit code.
  1. Press 7/8 and 9/0 at the same time within five seconds of Step 2.
The system now responds only to the factory set code
Mar 06, 2011 | 2003 Mercury Mountaineer
Need code to program a AUVIO 15-305 Universal Remote to COBY DVD938 Home Theater System.
Need a code for magnavox dvd player as well as step by step instruct toons on how to program that code for dvd player
Jan 30, 2011 | Directv RC23 Remote Control
I need the code for a Vizio LCD HDTV
There is no code for vizio tv's for that remote so you will have to do a PowerScan through all the codes to see which one will work. The procedure to do this is below.
Step 1: Manually turn off the device you wish to program (TV, VCR, DVD)
Step 2: Press and hold the appropriate device key (TV, VCR, DVD) until the red LED illuminates. This indicates that the remote is in programming mode.
Step 3: Press and release the power button. The LED flashes once and stays ON. Indicating that the remote is in PowerScan mode.
Step 4: Press either CH+ or CH- button repeatedly until the device switches on. The CH+ button searches upward in the code list while the CH- button searches downward.
Step 5: When the device turns on, press and release the OK button to store the new code and exit.
NOTE: If you press the CH+ or CH- again after the device turns on, the device will not be programmed and you will need to repeat steps 1 - 5.
Step 6: Press any other operable button (VOL+ or VOL-). If the device responds, no further programming is required. If the device does not respond then repeat steps 1 - 5.
Jan 25, 2011 | Brookstone 538744 Remote Control
I have an RCA RCR312W remote and lost my manual, request the steps needed to program my JVC tv / I have the codes, just need to know the steps to take ... Thank you
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
Thank you
Jan 16, 2011 | RCA RCR311B Remote Control
How to sync with tv
Hi, i could tell you what code you need to program the remote if tell me what brand tv you have. If not you can try PowerScan through all the codes to see which one will work. Procedure is described below.
Dec 31, 2010 | Brookstone 538744 Remote Control
I can not program my universal RCA remote to my JVC DVD player. I know it can be done, because it was programmed before. I do not what I "hit" or"pressed" to make it stop working....I...
If you cannot locate the code for your device, try the code search method below:
Step 1: Turn on the device.
Step 2: Press the "CODE SEARCH" button until the indicator light illuminates, then release.
Step 3: Press and release the VCR, TV or Cable button. If programming for AUX, press and release AUX button first, then press the device type to be programmed.
Step 5: Press "ON/OFF" repeatedly until the device turns off. Note that because there are so many codes, you may have to press the "ON/OFF" button a few hundred times if your code is towards the end in the list.
Step 6: When your device shuts off, press and release the "ENTER" button.
Step 7: With your device on, press a frequently used button like "PROGRAM UP/DOWN" OR "VOLUM UP/DOWN" to test. If it does not function correctly, repeat steps 1 through 6.
Auto Code Search Step 1: Turn on the device you want the remote to operate.
Step 2: Press and hold the "CODE SEARCH" button until the indicator light illuminates, then release.
Step 3: Press and release the device key that corresponds to the equipment you want the remote to operate (TV, VCR/DVD or DBS/CABLE etc.). The indicator light blinks once and then remains lit.
Step 4: Aim the remote at the device and press the ON/OFF key once. The remote automatically sends every code for the specified component one at a time, with a a few seconds delay between each code. Keep the remote aimed at the component throughout the process.
Step 5: As soon as the component turns off, you must press the "ENTER" button immediately for the remote to store the correct code. If you don't press "ENTER" within a few seconds, the remote will send the next code in the list and you will have to start over from Step 2.
Step 6: Use Code Retrieval described below to identify the code for your device for future reference.
Code Retrieval If you used one of the "Code Search" methods to program your universal remote control, follow the steps below to find out which code is compatible with your device. Finding the actual code and writing it down will save you a lot of time if you ever need to program the remote again.
Step 1: Press and hold the "CODE SEARCH" button until the indicator light turns on, then release.
Step 2: Press and release the device key that matches the equipment's code you are retrieving (TV, VCR/DVD, DBS/CABLE, etc.). The indicator light will blink once then remains lit.
Step 3: Press and release the "CODE SEARCH" key. The indicator light will turn off.
Step 4: Starting with 0, press the number keys in order (0-9) until the indicator light blinks.
Step 5: The number that causes the indicator light to blink is the first digit of your code.
Step 6: Repeat Step 4 until you have retrieved all 3 numbers of your code.
Nov 04, 2010 | RCA 4-Device Universal Remote
I have rca universal remote needing to program ge tv. need instructions, please
HI,
Direct Code Entry:
Code Search:
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Aug 05, 2010 | RCA Televison & Video
Lost code and instruction book?
Orion Codes: 035, 121, 135, 191, 394 Programming a GE Universal Remote Control takes about seven steps. Step One: Manually turn on the device you wish to program. Step Two: Press the Code Search button on the remote until the indicator light turns on. Step Three: Release the Code Search button. Step Four: Press and release the button for the device you are programming. Step Five: Enter the three-digit code for the device using the number buttons on the remote. After the code is entered, the indicator light turns off. Step Six: Aim the remote at the device and press the power button. The device should turn off. Step Seven: Press Channel Up on the remote with the device on. If the device responds, no further programming is required. To look up a device code to enter directly into the remote, you can visit the GE Remote Code Locator Website. http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit-New.pdf http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit-Old.pdf Hope this helps, Good Luck :) Please Vote
Jul 10, 2007 | GE RM24911 Remote Control
Zenith DBZN-311 Remote Control Logo
294 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
