Question about Epson Stylus C46 InkJet Printer
Error message saying parts have come to the end of their life. Does this mean the whole printer needs replacing
  • Epson Master
  • 511 Answers
It mean waste ink pad full. Epson stop to prin to prevent waste ink flow from pad to other (power supply is nearest part). Replace pad, or wash pad. Or just extend outlet pipe to outside of printer. You must reset waste ink counter to make printer work again. Use SSC utility to rset it. Find at indoreset.blogspot.com.
Posted on Jun 30, 2009
What does a belt life ends soon mean, on a brother MFC 9440ch color laser printer?
Are you sure of the error message? The Brother printers that I have used have Drum Ends Soon and Change Belt messages.
The Brother MFC-9440CN has a belt that can be replaced. The Belt unit has an life expectancy of ~50000 pages. The belt unit is part BU100CL and costs a bit over $150 at office supply stores. Amazon.com and some other stores have the unit for under $100. http://www.amazon.com/Brother-BU-100CL-HL-4040CN-HL-4070CDW-Series/dp/B000SC245E is one source.
When the unit says Change Belt Unit, follow the directions from the manual's maintenance section to replace the belt unit. See page 178 (page 189 of the PDF) http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002252/mfc9440_usa_usr_b.pdf . You have to remove the Drum and then the Belt Unit. Then slide in the new Belt Unit and replace the Drum unit. Then close the printer and turn it on. Finally reset the counter from the Machine Info sub menu (press Menu 8 4 and select the Belt Unit and press OK. Then press 1 followed by Stop/Exit).
If you mean the Drum Unit, that is part DR-110CL and costs over $175 at the office supply stores. Order this part when the Drum End Soon message appears and replace it if the print quality deteriorates (or when you have the new drum). The Drum Life is ~17000 pages. The steps start on page 166 (182 of the PDF). You need to remove the old Drum unit. Then remove the toner cartridges from the drum. Prepare the new Drum Unit, including putting the cartridges in the new Drum. Then replace the Drum unit and reset the counter.
I hope this helps.
Jun 04, 2012 | Brother MFC-8460N Laser Printer
My Epson Stylus photo R320 gave me an error saying "Service required. Printer parts are at end of service life. See printer manual for details". Which parts need replaced? thanks, Holly
It's probably going to be less expensive to REPLACE the whole printer, rather than paying a qualified printer technician $50 to $75 to disassemble the printer, change the parts (which won't be included in that charge for "labour"), to reassemble, and to test it.
Oct 11, 2010 | Epson Stylus Photo R320 InkJet Printer
Says parts need replacing but they dont how do I get the printer to work
If the error message reads parts inside the printer are at the end of its service life, and both red lights flashing alternately while power light is off, it is an indication that the waste ink pad is full and needs to be replaced. This part is not user replaceable so you need to take in the printer for service.
Apr 11, 2010 | Epson C64 InkJet Printer
I am getting an end of service life message. what
The printer is telling you that some parts are worn-out -- "end of life" -- and your printer either needs to have some parts replaced. Or, replace the entire printer, after comparing the cost with an estimate of parts/labour to fix the old printer.
Jan 14, 2010 | Office Equipment & Supplies
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
Brother MFC 9440CN
You need to order the drum unit. It's different from the toners. You can replace it after the part comes in - you do not need a technicain to come in to do it for you. You can find the part from Amazon or Brother website.
Apr 01, 2009 | Brother MFC-8460N Laser Printer
Epson stylus cv6400 error message "parts inside printer are at end of their service life.see your printer documentation."what does this mean? thanks in advance.....
The printer has an end of life service, meaning it has printed its last print on paper.. you have to get it reset from a technician or if you are savy enough you can download this resetter and do the reset yourself.
http://www.ssclg.com/epsone.shtml
Mar 29, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Printer
Duh, what does the error message say? Use the status monitor to get more info about the message. Chances are it will say "parts inside the printer have reached the end of their life..."
This means the waste ink counter has hit it's limit and needs to be reset after cleaning the pads.
This rescue kit will fix you up.
Oct 29, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus C46 InkJet Printer Logo
180 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
