Question about Refrigerators
  • John Tripp
    John Tripp May 11, 2010
    I need to know what brand walk in cooler you have. Also when you say the fan is frozen is your meaning frozen with ice or stuck and not moving. Most older style walk in coolers use R-22 freon. They have a thermostat that turns the compressor off so the water will drip down a drain to exit the cooler. If the thermostat is stuck and does not turn the compressor off then ice will build up and possibly cause your problem. Now if you have a digital camera and can send me model numbers and photos of what is happening that will help a lot. You can call me if you want and I will advise you on what to look for and help you get this fixed. My number is 864-487-4851 my email is My website is Let me know, Sea Breeze
    Director Badge:
    Uploaded 100 video answers.
  • Refrigerators Master
  • 488 Answers
How to Replace walk in cooler defrost timer
Posted on Apr 27, 2017
  • 27 Answers
Check the settings of the pressure control or if the fan is operating or if it has a defrost timer if the coil ices up the fan cannot pull air over the coil thus loosing cooling effect. possibly call a local tech im in logan city brisbane if that helps?
Posted on Jun 30, 2009
Coleman Electric Cooler
Replace the anti-freeze/coolant that is in the appliance.
Jul 29, 2013 | Coleman Electric Cooler 40 Beverage Cooler
Cant keep cool
You need to check that tour filters are new. Then check that air is coming from the vents and is at least 15 degrees cooler than room temp. If no air coil is frozen, or blower motor and run cap are not working. If frozen than turn system to off and fan switch is on until you feel air through vents.
You'll need to make sure the outside unit is runing and the larger copper line is cold like a can soda. If it's cold but is freezing up, it needs to have a charge added. If its running but not cold and the fan is not running or the compressor isn't running it could have a blown capacitor. If its not running at all check. the circuit breakers and reset them. And a good idea to keep the outside unit washed with water,and that it is clear of weeds and stuff.
Jul 10, 2010 | Goodman CLQ36AR49 Air Conditioner
Is it safe to take my digital slr out into -C temperatures and then back indoors into the warmth? I am worried that there will be condensation in the body and it will corrode.
You're right to worry. Get yourself a cooler(the kind that holds a 6-pack) and put some silica gel packets in the bottom. When you're finished taking pictures in the cold, put the camera in the cooler and keep it closed for at least half an hour after coming in form the cold. That way, it reaches room temp slowly and any stray moisture gets absorbed by the silica gel packets.
Jan 09, 2010 | Cameras
Fan not kicking on or working and compressor gets
take cover off use room fan until you get new fan motor(get that compressor cooler or lose it)
Aug 27, 2009 | Refrigerators
Coleman Electric Cooler doesn't stay cold
the most common problem is that one or both cooling fans has failed. If you have the newer version, you can get replacement fans anywhere computer parts are sold
Jul 03, 2009 | Coleman Electric Cooler 40 Beverage Cooler
Fan runs constantly and does not keep temp cool enough
forst on the back wall means you have a defrost problem or a air leak aroudh the door gasket-mike
Mar 16, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Fan blower coleman electric cooler
The fan should blow air into the heat sink. The warm air exits the heat sink at both ends. (It might work the other way, haven't tried it.)
When you have ice in your cooler, you know the thermo-electric element is working well--it's below freezing!
Ice builds up because there is water in the cooler. For example, in humid weather, you open the cooler, some humid air gets in, and the cooler temperature condenses the water. You have to empty this water, either by tipping the cooler, or using a sponge.
You can easily defrost the cooler by unplugging it for an hour or so. You know it's time to defrost when you hear the fan blades making a racket because they're hitting something--a thick buildup of ice.
Aug 10, 2008 | Coleman Electric Cooler 40 Beverage Cooler
Ice/cold room chiller fan noise
bearings in motor bad(new motor) fan blade hitting ice build up many different causes for this
Mar 29, 2008 | Freezers
Freezer in gargae
Refrigerator Freezers are controlled by the refrigerator temperature and NOT the freezer temperature. Move it to a warmer location.
Dec 10, 2007 | Nor-Lake Norlake Refrigeration 4' x 6'...
Refrigerators Logo
743 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
