Willnot start in safemode
SOURCE: hp pavilion 533x wont boot up
Hello!
REinstall the windows operating system, don't forget to install the driver after installing the OS>
melnavz
SOURCE: when booting up after the logo the computer goes
Hopefully, you have backed up your critical data. Run Windows Repair: Change your setup to boot from the CD ROM, insert your Windows disk and run a repair.. Good luck.
SOURCE: my system is not booting up I click on safemode it
You will need to format your hard drive and reload the windows operating system and load your software.
You also may need a new hard drive.
If the hard drive is full it may not load.
SOURCE: lost power and windows wont
If you get blue screen while booting in safe mode you can try a few more steps:
-Unplug all the peripherals plugged with the cmputer.
-press F8 when you turn on.
- try last known good configration and see if it works.
-if it doesnt then try safe mode with command prompt
-if it works boot in safe mode with command prompt
-At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER.
-Follow the instructions that appear on the screen to restore your computer to a date when it was working fine.
If this doesnot works you will need to do a recovery you can do that if you have a recovery partiton on your system.
Or get a windows disc to repair your operating system.
