Question about HP PSC 1315 All-In-One InkJet Printer
Hp1200 every time print self text page
Haiii hp1200 every time printing self test page only, what is the problem , pls reply me
    Genius:
  • 2,785 Answers
After the test page plz put the test page in the scanner and push the scanner button
Posted on Jun 30, 2009
Not printing full text on page
It sounds like you are trying to print from frames. If in doubt the simple test is try printing the windows self test page. If that prints OK then your cartridges are OK. If you sre trying to print from an internet browser - download the page first and then print it or see if there is a "printer friendly bar"
Feb 12, 2018 | HP C4280 AllInOne InkJet Printer
Pages print with a line thru all the text. They aren't underlines, but have an actual line printed over the text. How do I change this?
It's called overstrike.
Try send a print out from another application. If result is same, then print a self test page. Still the same, then replace cartridge.
Otherwise, head needs service/replacement.
However, if self test print out look good then you should check printer preferences.
good luck
Dec 02, 2010 | OKI MICROLINE 380 Matrix Printer
Missing text and top of some text is missing
* Perform Step 2 in the following HP web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01446637&cc=uk&lc=en&dlc=en&product=3643612
If the issue persists, please print a self test page from the unit and verify whether the unit prints the test apge fine. Step are given below:
  1. Load U.S. Letter, A4, or legal size paper into the input tray.
  2. Press the Setup button.
  3. Press 1 to select Print Report , and then press 1 to select Self-Test Report .
  4. Press OK . The self-test page prints.
:) Dr Tony
Apr 20, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
All of a sudden it will not print but as soon as u turn the printer on it prints like a test page
may be you chaged the catridge.
It is not the test page it is alignment test page just put the printed alignment test page paper on scanner glass and press the scan button to complete the process. It is alignment process which is printer is doing for self testing after installing new cartridge. Just finish the process.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 18, 2010 | HP PSC 1510 All-In-One InkJet Printer
When I copy the page comes out black
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridges. You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please disconnect and then reconnect the power supply on the printer and make sure it makes a setup noise when the cable is reattached.
Next, try this printer self-test by following the steps given below:
1. Press the "Mode" button until "Copy" light comes on.
2. Press the "Options" button nine times. The "Maintenance" option should appear on the LCD display.
3. Press the right arrow key three times. The "Print Test Page" option should appear.
4. Press "Select."
The self-test should print out some text at the top of the page and a black and gray bar below the text. Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service.
If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know.
May 11, 2009 | Lexmark X7170 All-In-One InkJet Printer
I have an HP LaserJet 1200, that doesn't print except on "Self Test." On self Test, it says, "Pages Jammed in Printer=19, Pages Mispicked in Printer=4." What can I do?
Yes, that is the total number of pages misfed, and jammed over the life of your printer -pretty good actually
Are you sure the driver is properly installed and thecable is ok? I would try removing it and re-installing it. When asked if you want to 'replace existing driver' during installation, select 'yes'. If after you reinstall it and you still can't print, then there is a board problem, and it's time to replace it...entry level lasers are under $100 these days and are about 4 times faster than your HP1200
Mar 08, 2009 | HP Office Equipment & Supplies
Unable to print text documents
Some times image/picture files are very big files. That big size, in mega-bytes, some times conflicts with your amount of available memory. It could effect the print que or ram. Try running the file through a picture editing program edit the files then rename and save them. You can check the file size prior and then after you run the file through the program. If the file size is lowered it should print.
Nov 07, 2008 | HP - HP Photosmart 8250 printer
Horizontal white lines through the text
Your ink cartridge (s) is dried up, even some new ones are dried up, even tho' they're sealed.
Some self-tests don't use black.
Sep 21, 2008 | HP DeskJet 6122 InkJet Printer
HP1200 prints blank page
Try ressetting the printer:
Turn the printer off. Press and hold the Go button for 20 seconds while powering on the printer
Jun 28, 2008 | HP LaserJet 1200 Printer
Enlarging print size
if you use Mozilla Firefox for your web browser (click here to go to the Mozilla site) when you print you can zoom in and out if you go to file > page setup the screen below will come up just un click shrink to fit page and enter in a zoom scale (larger makes your text lager & smaller makes your text smaller)
also with Mozilla you can zoom in and out on the page you are viewing by holding down 'ctrl' on your keyboard and clicking the + key to zoom in and the - key to zoom out.
i hope this has been helpful.
May 09, 2008 | Office Equipment & Supplies
HP PSC 1315 All-In-One InkJet Printer Logo
191 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
