Question about Frigidaire 14 cu. ft. / 396 liter Upright Freezer FFU14FC4A
Upright frigidaire freezer not running properly
For a while our upright frigidaire freezer was sitting outside. It started not keeping things in the door frozen. So we brought in inside thinking that whenever we opened the door the warm air was thawing these items out. After about 2 weeks in the house it started getting worse, so I took off the the panel inside the freezer and found a 4" piece of ice sitting below the coils. I got it removed with warm water, dried it all off and turned it back on, but the compressor didn't turn on. We waited for a few minutes still nothing, finally while looking around to make sure everything was still connected I found the defrost timer, I ever so slightly turned it from the position it was in which was lined up with the line and everything turned on. I looked through the manuals and they don't mention the defrost timer. Is this a bad thing to have turned the timer on? Does it need to be off the line for the timer to work?
  • 27 Answers
Sounds like your defrost timer has packed it in you need to fit another timer to it and everything will be as good as new.
by turning the timer you have forced it to run nothing to worry about. It has just stopped in the defrost position. What you have done is the first diagnostic test a tech would have performed. I hope this has helped you out.
Posted on Jun 30, 2009
How cold should the outside of the door be on an upright freezer
not that cold perhaps you have a bad gasket of too much in the door of the freezer and it isn't closing properly .
Aug 05, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Why are the sides of my frostfree freezer so hot?
check to see if you have a fan down by the compressor if so make sure it is running. if no fan you are starting to loose freon
Jul 25, 2014 | Frigidaire 13.7 cu. ft. / 388 liter...
My Fridgidaire upright Gallery freezer is freezing my food but the appliance seems to be constantly running and the temperature control on the outside is reading 29 Celsius when it obviously isn't
Hi Susan Abboud - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Nov 22, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
The freezer seems to be running a lot. Is this normal for an energy efficient freezer?
Good day,
Yes, the new high efficiency units tend to run a lot compared to older models. That in fact is not a bad thing, since the compressor has to cycle on and off fewer times per day, and starting and stopping are what create wear and tear on refrigeration equipment. Actually you pay less because of the much smaller compressor that uses less power.
However, keep an eye on it. If it gets continually worse going forward, call for service. Hopefully Frigidaire has solved it's problems but was known to develop internal restrictions in the refrigeration system causing that problem to the point it runs continuously and fails to cool properly.
If the machine is under 5 years of age it would be corrected free of charge.
Oct 26, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire freezer LFFH21F7HWG. the temp gauge outside registers only 0. I have 3 thermometers inside all register 18 degrees. ice cream is soft in the box. machine was delivered last Tuesday. the freezer...
these freezer are designed to run about 70 percent of the time the temp displayed can vary by +/- 3 degrees..make sure you have fan operation in the freezer and the air flow is not blocked or restricted. also make sure that the door is sealing properly
Aug 31, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
My freezer high temp light is on and it isnt running It is 2 years old and it is a Frigidaire Upright Freezer with digital temp on the outside of the freezer. My son went out to the garage 8 hours ago and...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 14, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
I just set up my Frigidaire upright Freezer, only
Rule of thumb, if you lay a frig/freezer on side let sit upright at new location for 24 hours before plugging it in.
Mar 07, 2010 | Freezers
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Aug 21, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
I want to just keep cokes,water,beer etc. in my small upright frigidaire freezer. is there a way to just make it cold enough not to freez the drinks.
Go to Home Depot find you a timer they start at $10.00, you know turn lights off/on when your not home. . They have an digital one for about $16.00 Set it up, ck your times, run it then shut it off for a while keep adjusting till you can keep the temp you want.
Apr 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire 14 cu. ft. / 396 liter Upright Freezer FFU14FC4A Logo
255 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
