Question about Toshiba Portege 4010 Notebook
SD drive I have SD slot but it doe not work
  • pcjac Nov 08, 2007
    my sd drive and dvd rom is not working
  • 53 Answers
If your SD slot is not working it could be dirty or require the driver to be installed (download from toshiba)
Posted on Nov 09, 2007
How do you transfer a photo from computer to sanDisk
Please keep the sandisk in to the USB port of system/laptop,
select the files what you want to send to sandisk, then rightclick on the selection. Then goto "Send to" option. In that you will find your sandisk. Select the drive of sandisk.
System will send the fiels to memory card.
Jun 08, 2011 | SanDisk 4GB microSDHC Memory Card
Where can I insert my mini sandisk memorycard into my toshiba laptop? I see no slots for it.
If you have no SD slot on your laptop, you will have to buy an external USB SD reader. They typically cost $5-$10, and are readily available online (e.g. http://www.buy.com/prod/micro-sd-sdhc-card-usb-reader-for-1gb-2gb-4gb-8gb/q/sellerid/23962916/loc/101/213271933.html) or in almost any store with a good selection of electronics.
Dec 06, 2010 | SanDisk 2GB microSD Memory Card
I just bought sd card for my ilo but when I try to access it wont let me store any music. How do I format it and prep it for access?
You need to format all new cards. Does your Mp3 player show up as a drive when you hook it up to your computer if so open that drive right click on format use FAT32 for windows os. If your Mp3 player does not show up as a drive use the SD slot on your computer to format. Choose the SD card slot drive right click on the drive choose farmat... use FAT32 for windows os. and you should be off and downloading great tunes... Good luck hope that helped.
Oct 06, 2009 | iLO (2 GB) MP3 Player
My Memory Stick does not register to my Macbook Pro. I have put it in the the SD slot countless times every way.
memory stick pro duo slot is different from SD slot. get a inexpensive card reader which supports memory pro duo cards.
Aug 07, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Why cant I download my waypoint data to a 2 GB SD card. My Global map 5000c does not recognise the 2GB SD card. Do I need MMC/SD. Can I place the sd card in the slot beside the chart card ?. Thanks
You can place the SD card into the slot beside the chart card.
With the SD card in the GlobalMap unit by itself (take the chart card out), press MENU twice and choose BROWSE FILES. Does the unit indicate that an SD card is present? If yes, the card is working fine in that slot. Try the same thing in the other slot. If it only recognizes the SD card in one of the slots, the other slot is bad and probably won't work with any card. If the card is recognized in the BROWSE FILES menu, but the data that is on the card is not working, there could be compatibility issues with the data and the GlobalMap 5000.
Make sure the GlobalMap 5000 has the latest software update from http://www.lowrance.com/en/Products/Legacy-Products/GlobalMap-5000C/Downloads/GlobalMap-5000C-Software-Update-180/. You might need to get a different, smaller capacity card since your 2GB is not working.
If the 2GB SD card still isn't recognized in the BROWSE FILES menu after the update, the GlobalMap 5000 is not going to work with that 2GB card. You will want to get a different card. I suggest 1GB and smaller.
If this doesn't help, please let me know some more details. Is the 2GB SD card recognized in the BROWSE FILES menu. What are you seeing that makes you determine it does not recognize this card? What files are currently on this card? What kind of card is it (brand, model).
Jul 11, 2009 | Lowrance GPS
My computer does not recognize my SD 2GB SD Flash Card which I insert into my camera and take pictures. I have a slot on my computer for SD cards. Can I just put the card in the slot and access the...
yes you can directly use the SD card slot, make sure you unlock the write protection before inserting it into the slot if you wish to modify or copy the contents from or to the card.
Jun 24, 2009 | SanDisk 2GB microSD Memory Card
Dell Latitude X300 PC Notebook Sd card slot
You need to format the SD card.
It is better if you format the card in the device in which it is used.
If you have already attended to that chore and the card does not work, try using a different SD card or cards to eliminate the possibility that the card itself is defective.
It is not recommended that you format the card in your laptop if its primary use is in a camera or other device.
Mar 30, 2009 | Dell Latitude X300 Notebook
Cant fit my transflash adapter to my pc
ceejay_thomas,
Does your PC have a SD slot for the transflash adapter? If not you'll still need a SD to USB adapter to plug the SD into. If you have a Sony it may not be an SD slot it may be a Memory Stick or Memory StickPro which is not the same.
randy320sgi
Jan 16, 2009 | SanDisk 2GB microSD Memory Card
Problem with reading Sandisk 4gig hc micro sd card in my computer and laptop
I guess you put the SD adapter into the card reader right out of the box? You first may have to partition/format it after unpacking it. Under WinXP I can recommend an utility "DiskPart" which you can start from the command prompt (Run... -> cmd). For further instructions (if it sounds to you to be the problem ) contact me again.
Dec 30, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How does the 5 in 1 card reader work on the Acer Aspire 5920 laptop? I am not sure how to get the SD card into this slot. Thanks
There should be 5 slots. Near each slot has the trademark of the card that the slot is for. If you are unable to identify the trademarks or there aren't any ways of finding which slot is which, then try each slot. Do not force your SD card into the slot. There should be only one slot that is the perfect fit for the SD card. Just slightly change the angle of the SD card until it slides in. The SD card has little to no extra room so it will take a little while to get the SD card in. Also the slot is spring loaded so you should here a click when it is in correctly.
If you have trouble, just keep trying and don't force it in. Trust me that it will fit if it is the right slot. Sometimes I get my SD card into my Wii or laptop in under a minute and sometime I have to mess with it for over 5 minutes (the angle of the stand for the Wii doesn't help at all).
Once you get the SD card in correctly, it will show up as a drive in "My Computer" but Windows XP and Vista have normal alerts with a "new hardware found" tone. Think of it as an USB flash drive that is smaller and goes into a specific slot.
When you are done, just push the SD card in and the slot should eject the card so you can pull it out.
Good luck and I hope you get it in.
Aug 15, 2008 | Acer Computers & Internet
Toshiba Portege 4010 Notebook Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
