Question about Sony Cyber-shot DSC-S730 Digital Camera
Just received it back from tec support saying fine memory stick may need formating which i already explaned id done even with new stick, my problem been when you take pics photos going into file when you open them to view some are file errors , this happens alot.
Hi you need to get the memory card a put it into your laptop and just put a few pictures on it, (it wont show on the camera when you view it) but after that put the memory card back into the camera and take a picture and you will be able to view it. i had the same problem, and just tried it now, and it works.
hope i helped.
Posted on Aug 09, 2009
I bought a new Memory stick for my Sony DCR-TRV320 Camcorder and when i switch my device to memory mode, it tells me "Memory Stick Error."
Check the following:
Memory Stick is inserted in correct position and orientation in camcorder. Try re-inserting several times.
Write-protect tab is switched to allow writing to memory stick (on back of memory stick)
Memory Stick is formatted in FAT file system (this should already be done except if memory stick has been formatted in a computer in a different format)
Memory Stick is not over the maximum capacity memory stick of the camcorder.
Memory Stick is not full.
Memory Stick is clean and dry.
The dcr-trv320 is a 2000 yr. model and came with a 4mb capacity stick and can probably only use up to a 128mb capacity stick or possibly 256mb. Most memory sticks you can buy today are 1GB, 4GB, 8GB etc. memory stick pro duo. and are probably incompatible. E-Bay has some of the old memory sticks like the 128mb for sale.
There is a slight possibility that static electricity discharge zapped the stick. Try another memory stick or try the stick in another device.
May 02, 2011 | Sony Handycam DCR-TRV320 Digital Camcorder
I thought my camera was fine until I plugged it into te computer after taking pictures, the pictures were all corrupted and even after I put them on the computer I couldn't view them, it does say there is...
This usually due to the memory stick on the digital camera getting corrupted etc. You will have to re-format the memory stick, but will lose the photos on it. You can try backing up the photos from the memory stick to the PC and see if you are able to view them correctly. The best would be to get a new memory stick if this continues to happen. Let me know, how you come along.
Feb 28, 2011 | Cameras
My memory stick says it needs to be formatted, but i cant lose the work. I have downloaded three differant types of file re-storers. none of them have even picked up that my memory stick is there.HELP!!!...
you can try some data recovery software. You can see
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
Jan 28, 2011 | Computers & Internet
Hi I have a sony cyber shot camera when i tried to ON it The memory stick error appears saying " INSERT MEMERY STICK" inspite of memery stick is inserted also i get this error.And when i tried to format it...
The Reinsert Memory Stick error message appears when the inserted Memory Stick is corrupted or not in a correct Format. This issue can be resolved by trying the steps mentioned below:
  • Remove and re-insert the Memory Stick in the Camera.
  • Check if the inserted Memory Stick is compatible with the Camera.
  • Format the Memory Stick in the Camera. Do not Format the Memory Stick in the Computer, as this will damage the Memory Stick being used in the Camera. The Camera will not detect the Memory Stick again, if it is formatted in the Camera.
  • Clean the terminals of the Memory Stick by using a soft dry cloth.
  • Remove the Memory Stick from the Camera and check if the Internal Memory is working fine.
You may also try power resetting the Camera. Power resetting can be done by removing the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Oct 21, 2010 | Sony Cameras
Well I got a new psp with a 2 gb memory stick produo with a Memory Stick Duo Adaptor. Well this is the problem: When I insert the adaptor with the memory stick inside my computer won't show any files it...
Put the card back in the computer and format it using FAT (not NTFS) format. In the format menu, you'll see the file system pull down option, choose FAT and try and format it again.
Thanks Mark
Jun 24, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
My sandisk memory stick pro duo wont work anymore
I have a Sony Cybershot DSC T70 and it keeps saying "Reinsert memory stick" whenever I turn on the camera or slide down the camera lid. Also, whenever I try to view the pictures on my laptop it shows "Please reinsert the memory stick" something along those lines. As I have been researching for the solution, I would have to format the memory card. However, I wouldn't want to lose the pictures as I just took many as from the holiday last week. The only problem is the memory card, I tried using another memory card and it works fine with the camera. There is nothing wrong with the camera.\r\nCan someone please help me how to solve the memory stick problem? It would be great. Ty.
Sep 11, 2009 | Sony Cyber-Shot DSC-P92 Digital Camera
How do i formate my psp memory stick
ur memory stick is corrupt if u have an email id send me . i give u a software can solve ur problem. (buntydcmc@gmail.com)
Aug 20, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Memory stick problem
ur memory is skrew you need to get a new one i got the same problem.
May 17, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
W850i memory stick
I had the same problem, I realised I must have got it wet from the above comments.
I basically took the card out and blew very hard into the socket in an attempt to dry it. I put the card in and it worked fine!
I hope this has helped, sorry if it doesn't.
Jan 19, 2008 | Sony Ericsson W850i Cellular Phone
Reinsert Memory Stick Message
i have sony cyber shot keeps saying reinsert memory stick cant veiw any pictures taken nor download cant take any new pictures have i lost all my pictures how can i get them back
May 03, 2007 | Sony Cyber-Shot DSC-T5 Digital Camera
Sony Cyber-shot DSC-S730 Digital Camera Logo
234 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
