SOURCE: glass door for a Siemens microwave hf 879
I've the same problem. Inside glass broke while heating.
SOURCE: my Siemens HF87950GB inner glass panel broke
This is a problem that at least a few others have experienced with your microwave and may be the subject of a recall although I could find nothing on their website.
I would definitely go to Siemens first as this definitely sounds like a manufacturers defect. Even if they have not publicly stated this in a recall, they likely know it is happening and may fix it (even out of warranty) if you push. ConsumerReports.org may be interested... I would talk to them if you don't get any satisfaction from Siemens.
Otherwise, the glass should be standard tempered glass that a local glass shop can get if you bring the door to them, or just a sample of the broken glass (for thickness) along with the internal dimensions of the glass.
Make sure that the metal mesh/screen remains in place and is not damaged, as this is what prevents the microwaves from escaping the cooking chamber.
Siemens Customer Support Website
Siemens Service # 1-866-447-4363
Testimonial: "Thank you very much!"
SOURCE: My Siemens HTHB86K Micro / Oven combo has
I just had exactly the same problem with the same oven, did you find a solution yet?
SOURCE: The door latch/lock pin on a Siwatherm C7 is
can u please provide the model number and i might be able to find you a schematic for your machine Thanks Rick
p.s im in hawaii on differnet time then you so i will answer and send your schematic after you send model number sometime tomorrow
