Question about LG Heating & Cooling
Air conditioner shuts off
Model S12AHN turns on fine ... runs for a minute and switches off displaying the code C5 or CS on the units display panel. Any ideas??
C5
Communication Error
• Wrong or missing wiring between indoor and outdoor unit cable
• Defect of communication components in indoor pcb assembly
• Defect of communication components in outdoor pcb assembly
• Defect of power supply components in outdoor pcb assembly
• No ground connection in air conditioner unit
(affected by noise in power source)
Posted on Dec 20, 2010
What is the error code E5 on bluestar air conditioners mean
Problem
Overheat of inverter compressor motor
Cause
Shortage of refrigerant amount Leakage of four way valve
Defect of connector contact
Aug 14, 2014 | Heating & Cooling
I have a Sharp AF-S80FX A.C. unit. Whether on cool or fan the unit keeps tripping the breaker on the plug with an E1 message. The filter has been removed and cleaned, but it really wasn't dirty.
small_16_7.jpg For a detailed Air Conditioner illustration, click below.
redarrow.gif Window
It doesn't turn on at all
The fan runs but there's no cold air
The air is cool but doesn't seem cold enough
The unit never turns off
There is water sloshing around inside
The unit tries to start for a few seconds and then quits
A motor is running but there is no air blowing
The unit rattles loudly when it turns off
Water leaks out the front of the unit
The air smells musty
Note: If your repair problem isn't listed, click here
Check to see if there is power getting to the air conditioner. If it is a 110-volt unit, plug a lamp or other device into the same outlet the air conditioner is plugged into. If there's no power, check the fuses or circuit breakers. If there's still no power, you will need to contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it is still completely dead there may be a problem in one or more of the following areas:
Jul 10, 2008 | Sharp Heating & Cooling
E1 error code displays when unit is plugged in I have a wall unit with about 10,000 BTU capacity. Two days ago, it quit working and displayed the E1 error code. I unplugged the unit, let it sit for 10...
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Jun 05, 2008 | Haier hwr10xc6 Air Conditioner
How can i open my Nokia c5-04
Warning: Do not enter any wrong unlock unlock codes on your Nokia C5-04 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia C5-04 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C5-04.
3 - Compose #pw+CODE+1#.
4 - The Nokia C5-04 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C5-04 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia C5-04
Each Nokia C5-04 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia C5-04 mobile phone atwww.mobileunlocksolutions.com.
Apr 20, 2014 | Nokia C5 Cell Phone
How do i unlock nokia phone C5, IMEI no. 359345/03/567499/9
Hi, You can unlock a Nokia C5 safer and easier using unlock code. You can get the unlock code from www.unlock-zone.com/nokia-c5/rs16wp9/ at low cost
UNLOCKING STEPS FOR A NOKIA C5
1 - Switch on your Nokia C5 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C5.
4 - The Nokia C5 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C5 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
Oct 19, 2012 | Nokia C5 Cell Phone
Imei : 359331047328543 get me the code for nokia c5-03 plz
imei ; 359056/04/891274/4
mastrcode : 6620047052
Sep 28, 2012 | Cell Phones
How to unlock nokia c5-03?
It's simple to Unlock the Nokia C5-03,there are many ways to Unlock the Phone,But Unlock code is best,You need to specify in which country's network it locked now?
then get the Unlock code here
Theunlockarena.com and Unlock it step by step following the instructions below:
Nokia C5-03 Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Nokia C5-03 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia C5-03 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia C5-03 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C5-03.
4 - The Nokia C5-03 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C5-03 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
The CODE you need to enter is the unique unlock code for your Nokia C5-03
Jun 18, 2011 | Nokia Cell Phones
I have an LG split system air conditioner model number LSZ244VN-4 it is coming up with a fault code of CS after it has been running for approx 5 minutes
There is no CS code. Please read as C5.
Fault Code 05 and 53 (CH05 is displayed at indoor unit, 53 is displayed at outdoor unit)
This fault code indicates a communication error between the indoor and outdoor units; this is usually caused
by wiring errors or condensate pumps connected to the inter-connecting cable.
The communication between the units is a fluctuating DC voltage commonly called a serial signal, it can be
easily lost if the wiring is not done correctly. If there is a communication error fault CH05 will appear within 5
mins of powering up the system.
Testing
• Check Outdoor and Indoor Power Supply Voltages ( 230V ±10% ) and correct as necessary.
• Check for any mis-wiring or loose connections and correct as required.
• Check the resistance between communication line and GND. (Normal: Over 2M).
• If one Indoor unit operates normally Outdoor PCB is generally normal.
Turn on the power and start the indoor unit in cooling, set the temperature to 18ºC; the serial communication
signal will only be present for the first 3 mins of operation.
Set your meter to DC Volts, Test between terminals 5 (Red probe) and 2 or Earth (Black probe) of the outdoor
unit, you should see a fluctuating 0-72 Vdc.
If the Voltage is not present disconnect the terminal 5 cable, test the Voltage between this wire (Red probe)
and 2 or Earth (Black probe), you should see a steady voltage in the range of -0.1 to -10.0 Vdc. If No Voltage
is present either the cable or Indoor PCB must be faulty. This can be determined by checking the voltage
output on the Comms terminal of the Indoor unit, with the Comms wire disconnected. If No Voltage is present
the Indoor PCB must be faulty, if present, cable must be at fault.
Jan 19, 2011 | Heating & Cooling
We recently had a flood go through the house and now when we turn the air conditioner on it displays c5 what does this mean?
C5 Indoor malfunction of gas pipe thermistor. Check amps of your unit .If very less than specified, it's gas leak. If only little difference and having freezing blow, it's coil and blower wheel dust blocked. Service the unit completely and run the unit.
If gas leak call repairman to find leak and arrest and then recharge gas.
Hope it's helpful. Thanks,.
Dec 25, 2010 | LG Heating & Cooling
Bizhub c450 error c3752 Guillemin
Fuser Heat Error. Sometimes this code can be cleared by using the reset procedure outlined below. If the code returns then you will need to have the unit serviced.
Reset Procedure:
1. Turn main power switch OFF.
2. Turn main power switch ON while pressing the Menu/Select key.
3. Keep pressing the Menu/Select key until the LED turns OFF on the control Panel.
4. Check to make sure that "Trouble Reset" is displayed on the control Panel
after LED turns OFF.
5. Pressing the Menu/Select key.
6. Check to make sure that "OK" is displayed and the it has been reset.
7. Turn main power switch OFF and ON again, and make sure that the machine properly
starts.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 16, 2010 | Konica Minolta bizhub C450P Laser Printer
Heating & Cooling Logo
1,481 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
