Question about HP Laserjet Cp2025n Printer
We do not actually know, it just says replace supplies, does this mean all of our cartridges?
  • 630 Answers
Yours is a network printer. Log into it using Internet Explorer using it's network address (typically http://192.168.1.xxx and it will give you the levels for each toner. On mine which isn't the same model the LCD has 4 colour bars and a display of the levels above the each bar. To prolong toner life check the recalibration menu and make it as infrequent as possible
Posted on Jun 30, 2009
  • philipk Jun 30, 2009
    Press OK to enter the menu
    Use the right arrow until you see reports
    Press OK
    Press right arrow until you see Supplies status and press OK
    It will then print out a page telling you how much toner is in each cartridge.
All linghts blinking in konica minolta pagepro 1500 what uis the solution
rapid blinking means third part toner replace all the toner cartridges with actual Konica minolta toner cartridge DO not use third party!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 08, 2018 | Konica Minolta Office Equipment & Supplies
Laserjet m1212nf mfp, getting "suppy
Supply memory error is referring to a defective toner cartridge. Actually it's the electronics chip that is attached to the cartridge. The printer gets toner information by reading the chip. Replace the cartridge.
Aug 12, 2011 | HP Hewlett Packard LaserJet 3000dn Printer
C6280 printer color why does it say replace cartridge even after i put a new one in
Hi, This printer takes the "02" cartridges. If the cartridge is not being detected is because the "chip" in the cartridge is defective. Also because this printer takes 6 cartridge, make sure when you are changing the cartridge you are meant to change. For example lets say that blue and light blue are both low. Then light blue actually runs out and needs replacing. Make sure you do replace teh light blue instead of teh blue.
A way to validate this would be in the default screen of your printer the display show the amount of ink remaining on each colour. If you are replacing the one with no "bars" and with the warning symbol and after insertion the printer doesn't recognize the supply (ie shows the message of "HP original supply installed" and go through a "maintenance routine", the your supply is defective :(
Oct 04, 2009 | HP Office Equipment & Supplies
Replaced black toner..now printer won't print any
In this case, actually it is not the Black toner that got depleted. Here the message being displayed indicate that one of the color Toner supply need to be replaced as it got depleted and currently the printer is printing in Black and white using the Black toner cartridge.
in this case, to troubleshoot these issues please try performing the following and check for the results.
* 1. Check for the level of the toner cartridges:
a) Check from the HP Toolbox application. Here are the steps to be performed from your PC:
* Access the Toolbox software.
* Select the Status tab.
* Select the Device status option.
Here you can check for the supplies status in terms of the % remaining for each toner cartridges.
b) By checking the supplies status from the printer control panel display.
On the printer display when printer is in Ready mode the supplies status can be checked from the supplies level indicator. Each toner cartridge and the Imaging drum level will be indicated by a bar which varies according to the level of the supplies present.
c) Print the supplies status page from the printer.
* On the printer control panel menu, press Menu .
* Use the (Right Arrow) button to select Reports, and then press Enter .
* Use the (Right Arrow) button to select Supplies Status, and then press Enter .
If any of the color toner cartridges and the Imaging drum have a low supply level replace them with genuine HP print cartridges.
The part numbers of the consumables are as follows:
* Black print cartridge - Q3960A
* Cyan print cartridge - Q3971A
* Magenta print cartridge - Q3973A
* Yellow print cartridge - Q3972A
* Imaging Drum - Q3964A
Sep 23, 2009 | HP LaserJet 2840 Printer
Jam 1 and no cartridge error message
If you have a sf-560R then you will need the correct toner cartridge.
Aug 24, 2008 | Samsung SF-560 All-In-One Laser Printer
Out of toner........ but not really.....
Print a Supplies Status page to see the actual pages printed...
To print the Supplies Status page from the printer, on the printer control panel, select
Reports Menu, Supplies Status, and then Print Supplies Status page.
If the page count from the Supplies Status page indicates that the toner should not be in need of replacement then you have a bad cartridge. Actually, the cartridge is probably fine but the chip on the cartridge has got a problem. Return the cartridge to O.D. and get another one. Unfortunately, chips that don't work properly in not all that unusual so HP has a pretty easy return policy.
Hope this helps.
Mar 07, 2008 | HP Color LaserJet 2600n Printer
3500-4500 series lexmark
Can you make sure the number corresponds with the typewriter itself? Sometimes, the manual could be a typo/misprint.
Zabrina
Jan 20, 2008 | Lexmark Wheelwriter 3500 Typewriter
I have error 29 on my 210c
!!!! Magenta ink error !!!!
The ink has run out or the ink cartridge is not set into place.
26: Black ink
27: Yellow ink
28: Cyan ink
29: Magenta ink
1. Reload ink cartridges, referring to the Owner's Manual.
2. Ink cartridge PCB defective Replace the ink refill ASSY.
3. Cannot detect ink cartridges.Main PCB defective Replace the main PCB.
I know your machine was not originally showing signs of main board fault or Ink supply issues, although main board can be killed by incorrect use of maintence mode.
Nov 14, 2007 | Brother MFC 210C All-In-One InkJet Printer
HP Laserjet Cp2025n Printer Logo
160 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
