Question about Kenwood KD-291RC Turntable
I,m trying to replace my kenwood KD 47F turntable V68 catridge & N68 needle stylus with an Audio technica set due to non availibility of N68 stylus in my home country- singapore. Audio technica catridge and stylus is easily available. Could you recommend what suits my set
  • 69 Answers
Try mailing this company and get their advice for a suitable replacement?
mailto:info@needledoctor.com
Posted on Oct 07, 2009
  • 33 Answers
Hi, any cartridge are posible in every turntable as long the needle is available...the wiring is the same the position ,, but the only thing that im not sure is the sensetivity of the needle ..some are not good but some is compatible..u
Posted on Jul 09, 2009
I have a Kenwood KD12R turntable. How do I set the arm and needle. I have a weight with an adjustable dial at the end of the arm and a separate anti skating dial on the base of the turntable? Regards -...
The weight should be set to the position recomended by the cartridge maker. Typically 1.5 to 2.5. If you don't know the makers setting, set it at 1.5 and work upwards. The stylus should track nicely in the record groove and not jump. But not too heavy as to cause rumble in the sound. Set the skate control low and again try the record out, if the stylus starts to skate accross the record increase the force. It's a case of experimentation with no fixed rules on these settings. Some records might need adjusments afterwards.
Feb 15, 2011 | Kenwood KD-291RC Turntable
I bought an Audio Technica USB AT LP 120 Turntable last June. It worked fine as a turntable, but I was never able to get good recordings of vinyl without distortion. But now I have another problem: when...
Sorry it could be the cartridge! They can fail at anytime, only the stylus will wear with time. However it could be the amplifer's magnetic cartridge pre-amp. If you look inside your amp and trace back from the phono socket you should find the pre-amp. If it is distorting on both channels it's probably an IC that has failed.
Dec 05, 2010 | Audio Technica USB Turntable
I need a Kenwood Stylus N-74.
There's a whole list of resources here, including one at Amazon for $16.73
http://www.retrevo.com/s/stylus+n-74
Or Radio Shack.
Feb 08, 2010 | Audio Players & Recorders
Need replacement cartridge & Stylus
dont know about New Zealand but you could contact this company and mail order it/ship it to N/Z?
Sep 27, 2009 | Audio Players & Recorders
Trying to get the belt around the gears of my
I know this isn't the same model as yours, however it shows what I would describe to you on page 7. Hope this helps.
http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Home/Manuals/kd-491f.pdf
Jul 30, 2009 | Kenwood Audio Players & Recorders
One channel vocals drop out
yes, it is very likely the stylus. the stock needle is conical shaped like a ball point pen. You might have a tonearm that is out of alignment but usually it's the needle. It is possible it is just dust on the tip but if it occurrs in consistent areas of the record, then it is likely that the music is just too demanding for the LP2D you will either have to use your old technics which is likely better quality or you could try upgrading the stylus on your LP2D.
If you do a yahoo search for "4-211-DE-GUARD" with the quotes, the 1st result will take you to an elliptical upgrade over the stock needle. The elliptical tip will pull more info out of the grooves and into your computer for further processing.
Jan 16, 2009 | Audio Technica USB Turntable
Stylus for a Kenwood Belt Drive Turn table
I suggest try 'Lpgear@yahoo.com' There is a long list of Kenwoob turntable cartridges & needels. I hope you find your needel.
Sep 18, 2008 | Kenwood KD-291RC Turntable
Replacing the stylus
Go to esupport.sony.com and type in your turntable model, PS LX250H. The "H" is important. Available is the complete manual, and a separate publication just on removing the stylus and setting EQ. Basically, swing the protector bar down over the needle, and snap the entire (mine is beige) unit down from the tone arm, then pull forward. I'm still shopping for the replacement, frankly.
May 21, 2008 | Sony PS-LX250 Turntable
New needle for sony ps-lx250h?
Yes It's possible.You can purchase it on amazon, click here and take a look: Amazon com sony ps lx250h needle. I hope this was helpful. Cheers
Jan 24, 2008 | Sony PS-LX250H Turntable
Kenwood KD-291RC Turntable Logo
536 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
