Question about Dishwashers
Hello, I have a Hotpoint aquarius dishwaher model no. FDW20 when the machine starts its cycle it stops after about a minute and the dryer light flashes along with the wash light, cann you help me. Peter.
  • 138 Answers
Sounds like control switch is faulty. Check wires at motor first for corrosion or arcing.
Posted on Jun 30, 2009
Dishwasher repair
If this is the first and forth LEDs then i was told by a Hotpoint engineer that this means 'heater cut out due to overheat' and that probably the heater is just covered in limescale. If that is the case then running a descaler through the dishwaer on the highest setting should fix the problem and clean the inside of your machine to boot !
I guess this would happen if your machine is a few years old and you live in a hard water area.
Nov 12, 2013 | Dishwashers
Whay my Hotpoint -Ariston Aquarius WD420 Front Load All-in-One Washer / Dryer stpos have way the circle
You say it stops half way through cycle (if I have read it right), especially when fast spin starts. Does it stop anywhere else (in wash cycle or rinse cycle)?
I would check the main filter in the sump (pipe from drum to drain pump) and ensure pump itself is not blocked which could cause the pump out time to be exceeded and thus stop the program. A faulty pressure switch could also be responsible.
I would also check the tacho on the motor and connections to main board at bottom of machine near to motor.
Disconnect machine by pulling out plug and wait 10 minutes for capacitors to discharge before doing anything, to protect yourself against residual voltages.
From a retired engineer who owns one of these machines.
Jul 28, 2012 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius fdw20 fault lights
take base plate off and check for debris in the wash pump
Jan 11, 2009 | Dishwashers
Washer dryer wont stop running
unplug the machine for 3 mins and plaug back in if it still happens you might have a problem with the heating element or somthing.hope this helps.
Jan 02, 2009 | Hotpoint Aquarius WD63 Front Load...
Fast and delicate lights flashing.
No, do not repair this, everyone who has purchased this model should demand a refund !!!!The problems are endless.
Apr 24, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Dishwashers Logo
587 people viewed this question
Top Dishwashers Experts
