Question about Sylvania 6413TG 13" TV
Fried resistor, need value for R801
I fried the resistor right next to the headphone input jack at the front of the board. I want to replace it but cannot tell the resistor value because it is so badly burned. What is the value for this resistor?
If it matters I fried it by plugging the headphone output jack into an external powered speaker system.
Brown/ Black/ Brown/ Gold It is a 100 ohm +/- 5%
Posted on Feb 11, 2008
Low level input resistor values ti600.2 left and right channel resistors on board next to RCA in both burned
Hi Dave,
Schematics are tough to come by - but - you may find someone with your model that can help you out in the "Phoenix Gold Phorum" Joining is free - then ask your question and wait for a reply.
Dec 17, 2013 | Phoenix Gold Car Audio & Video
MCS 160 Boston Subwoofer ZD3 Zener Diode Value
ZD3 is a 18v zener. Also check the surface mount resistor on the back of the board that is attached to ZD3, I think it is R9. Should be 10 ohms. This resistor sometimes opens when the diode goes short.
Jul 13, 2013 | Audio Players & Recorders
I replaced the DC jack on the laptops motherboard because my Charger Fried and also melted the inside of the DC Jack, But not That I have installed a new on the power doesn't seem to come on at all, The...
There is. It would appear that the DC jack was not the only thing that was fried. If all your solder connections are correct, the mother board may have been damaged be the shorting of some part on the board, and burned open. Look for fuses, and "resistors that are have a "0" on them. they should read a short. if you find nothing. the board is damaged beyond repair.
Apr 18, 2011 | Samsung V25 XVC 2800 Notebook
I have a Polaroid FLM323B and was watching it and it just went out. No power light, no nothing, what could have fried?
Sounds like a power surge related problem. My money would be on the Power supply board itself. In cases like these it might be a good idea to replace the entire board itself (costs about 100$) instead of going component by component coz off late the protection circuitry have been getting weaker and as a result a lot of components are getting fried by surges. Last week I have worked on a set with similar problem that had the following fried components blown 10A fuse, 2 Voltage , 2 10KOhm resistors , Regulator ICs, 2 Circuit protectors along with a few capacitors of varying values of capacitance!
Aug 26, 2010 | Polaroid FLM-3232 Television
HDMI fried?
I imagine you can look for shorted semiconductor components on the circuit where the hdmi plugs into. It's a bit challenging if you are not familiar with electronic components. You would look for shorted diodes shorted transsistor, open resistors etc. Those components on new electronic device are extremely small and require skills on removal and replacement. They also have values that must be replaced with the same value. Also you can tell visually if they are bad. You would need a multimeter. Taking it to a shop may cost you several hundred dollars.
Jun 26, 2010 | Vizio VECO320L 32 in. LCD TV
Hi have been given a Marshall MBB15 amp to find out why it doesnt produce sound through the input jack, have checked inside, looks like the resistors connected directly to the input jack are dead. Could...
Dead resistors? The evidence would be if the resistors are cracked OR if their is evidence of smoke/fire around them.
In either case, there would LIKELY be damage at least one or two layers deep beyond those resistors if in fact they are fried. If they are cracked physically, teh circuit board also may be cracked due to physical bending. Tripping over an inpout cable can do this.
Causes of this would be shorting the input to power line voltage or the output of a high powered amplifier.
I question that the resistors are "dead".
THE USUAL cause of failures of these small amplifiers is frying of the output power chip which is often in the TDA family of 5/7 terminal amplifier chips in modified TO220 packages.
Another less common problem is failure of the rectifier and filter capacitor combination.
Nov 03, 2009 | Marshall 15 Watt Guitar Amp
Y-SUS board: How to determine if it's fried?
Your solid green "resistor" is probably a fuse and will have an amp rating stamped on it, if you can read it with a magnifying glass. Before you replace that you need to find out what else on the board or somewhere else in the TV is blowing the fuse. Resistors have bands to denote their value unless it is a large power resistor and the value is written on it.
Apr 16, 2017 | Maxent MX-42VM10 42 in. HD-Ready Plasma...
Blown resistor
if you mhave the circut diagram please check it .
Nov 23, 2008 | Electronics - Others
Sylvania 6413TG 13" TV Logo
216 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
