Home | Samsung | HLN617W 61 in. Rear Projection HDTV Tel... | Loud noise, then shu...
Samsung HLN617W 61 in. Rear Projection HDTV Television
Problem for Samsung HLN617W 61 in. Rear Projection HDTV Television
Loud noise, then shuts down after seconds , fans look ok
By shine1968r on Jun 30, 2009
samsung HLN 617wloud noise, fans looks ok, the noise comes near the lamp
can you walk me throw changing the the wheel ?
Solution #1
posted on Jun 30, 2009
Not Rated)
Skyassoc
Rank: Guru  Televisions & Videos  Expert
Rating: 90%, 254 votes
On U_Tube, there is a video that shows the replacement proceedure. I understand it is quite good. My neighbor used it and it went in pretty easy. If you Google the model # it should be able to give you a link to it.
Good luck !!,
Hope this helps,
Skyassoc
Was this helpful?
Yes
No
Popular Solutions for Samsung HLN617W 61 in. Rear
Questions and Unsolved Problems for Samsung HLN617W 61 in. Rear
Do you recommend Samsung HLN617W 61 in. Rear Projection HDTV Television?
Answer
Answer
samsung flat screen keeps turning off...sound stays on...what is the problem
Answer
What's happening is power up chime, and faint volume. I can change channels. Meanwhile, no pic,... (More)
Answer
I have a Samsung HLN 617 W and I turned it on today and it worked fine then later this evening we... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung HLN617W 61 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
