Question about Sony KV-35V65 TV
When powering on receive no display, no sound
I get a constant blinking of the stand by/timer light; attemtped to shut off for 4 hours and retry, as suggested on another post for the same issue but have had no success. It appears that I will need to get a repair done. Can you estimate the cost that I should expect to pay for the required repair so that I wont be bamboozled?
Thank you, I greatly appreciate your time and assistance.
  • 790 Answers
Re: when powering on receive no display, no sound
the problem is the power oscillation circuit!.you need a qualified technician to diagnose your TV. here in the philippines that is abouth to spend around 1500 php.
Posted on Nov 08, 2007
0 characters
3 Points
I have a Sony model KDF-e55a20. I just changed the buld but I still don't get any picture all I get is the power on light blinks 3 times. Does anyone know what the problem is?
Sir reset the lamp timer of your unit.
1 Press "Display" on the remote, followed by the 5 button, then the sound up key, and "power on". Do this while the tv is in stand by mode.
2 Then press "jump" 3 times to enter DE service menu.The tv screen will display the total lamp time hours.
3 Reset the the lamp time by pressing channel 3, then mute, then enter.This will return lamp timer back to 0. Hope this may help good day and best regards.
Aug 18, 2011 | Sony KV-36FV26 TV
My tv shut itself off and now the 'stand by/timer' light is on
how old is your lamp, sounds bad. please give me high rating
Apr 16, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
The TV will not turn on. Stand by/Timer light just blinks...
well it's due to ur cable connection is unable to receive or ur dish tv
Mar 28, 2010 | Sony KV-35V68 35" TV
Tv turns on then off, stand by timer light blinks 4 times
You need to replace the power supply unit on this as it has malfuctioned there about $90 bucks plus labor on that.
May 25, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
The stand by timer blinks continuously
Unpluggnig the set will reset some things, but not an error code. The 4 blinks usually means a lack of vertical deflection. If you can solder, you should be able to fix this yourself. Be warned however that there are dangerous high voltages inside the set even when unplugged.
That being said, try locating the vertical IC which will be a small flat IC attached to a heatsink that will be marked LA7837 or something similar. Try resoldering the pins on that IC first. If that failes to resolve the problem, replace the IC and post your results here. There may be other components that need to be replaced, but they will show up as other symptoms once the IC is replaced.
Jan 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-35S66
power supply kit hozout plus flyback 1fuse 1restor
Nov 10, 2008 | Sony KV-35S66 35" TV
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Television
In these sets, it is common that the flyback transformer assembly, and sometimes the horizontal output transistor. With this there may be some failed capacitors in the horizontal section. When this type of failure occures it is possible that the power supply has some parts that also must be changed. The exact parts will be determined by the way the failure occured.
In some cases the CRT also goes shorted inside of the electron-gun. In this case the CRT must also be replaced.
In short order, you should take the set in for an estimate. It may be on the expensive side to service. If you are lucky, only the flyback may need replacement or some other simple part that is putting the set in to the protect mode.
Jerry G.
Apr 13, 2008 | Standard (CRT) Televisions
Blinking Stand By/Timer LED
You can try this on the remote in standby mode, meaning tv plugged in but set off. Press Display,5,vol+,power on remote.Press each button within a 1 sec interv. Next the CRT display the item being adjusted. Press 1or4 on remote to select item. 3or6 to change the data. Press Muting then Enter to write into memory. Service Reset muting green enter red. Press 8 then enter on remote to initialize. turn set off to exit. wait least 10 sec. before turning back on.
Sep 10, 2007 | Sony KV-32V40 32" TV
Standard (CRT) Televisions Logo
138 people viewed this question
Top Sony Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Sony Standard (CRT) Television Expert? Answer questions, earn points and help others
