Question about HP LaserJet P2015dn Printer
HP Laserjet P2015n error
Theres no paperjam, but it indicates, paperjam, no paper, no cartridge its simulteneous. this is just suddenly happen. any idea? need help...
or somebady teach me how to reset this Laserjet P2015n to factory setting i think it could help in that way. please help...
  • thnkermatrix May 11, 2010
    Thanks for the advice, I appreciate, I think your right the formatter board had the problem. coz in our three printer with the same model they are all the same problem.
    Novelist:
  • 102 Answers
If paper jam light is solid or printer shows paper out light solid all the time,
Then try these suggeted steps:
Take the Tray 2 out and check if all the paper guides are moving freely if they are than remove the toner cartridge and check if any toner sensor is not align correctly.
If they are aligned correctly than next to the pickup roller there is a small piece of plastic make sure it should be hanging freely if it is than we need to perform cold reset of the printer.
Switch off the printer press and hold down the go button and switch the printer on keep holding down go button till the time three lights lit up on control panel, as soon as three lights lits up release the go button and let the printer initialise of it s own.
If that doesn't fix than Formatter Board of the printer is faulty.
Logic:
If there is no paper jam and printer rep[orts the jam means either any of the sensors is not aligned correctly and reporting the jam or formatter Board(Motherboard) of the printer is faulty and showing incorrect display.
Thanks and Regards
Posted on Jul 03, 2009
    Champion:
  • 220 Answers
Fuser faulty
Posted on Jun 30, 2009
HP P2015n paper jam error
heat main chip of formatter
Nov 14, 2011 | HP LaserJet P2015n Printer
My hp lasert jet 1012 light keeps blinking there is a new cartridge in there too
Indicating paperjam or cartridge missing most of the cases..check any paper jams if no remove back cover observe there are two sensors left for paper path sensor & right for catridge sensing sensor, check these two sensors flags, strucking/springs out..
Sep 19, 2011 | HP LaserJet 1012 Printer
Why do I get a black line on my paper when i print on my P2015n
The Cartridge of this printer needs Drum /Dr. blade change ,so get it replaced.
Feb 16, 2011 | HP LaserJet P2015n Printer
I have an HP 1022N and the top yellow light with triangle with exclamation mark symbol inside is blinking and printer won't function. How to fix?.
According to the user manual the triangle lamp blinking is an indication that the error needs user intervention. The possible causes are the ink cartridge door is not closed completely, out of paper, no ink cartridge, or there is a paperjam. To fix these, click on the link below to download the user manual. This issue is posted on page 75. Hope this helps.
http://h10032.www1.hp.com/ctg/Manual/c00264442.pdf
Jul 22, 2010 | HP LaserJet 1022 Printer
HP LASERJET 4L has a paperjam
1. Open front cover, remove toner cartridge and remove paper
2 Open back door , remove paper
Oct 22, 2009 | HP LaserJet 4L Printer
Printer hp laserjet p2015n
laser unit mirror is dirty clean it than solve it
May 29, 2009 | HP LaserJet P2015dn Printer
ERROR on HP laserjet P2015N
Try contacting HP support, even if the printer is out of warranty they may be a send out a new DIMM. But it sounds to me like the formatter board, These cost about £70 but are free under warranty.
Thanks
Apr 09, 2009 | HP LaserJet P2015n Printer
HP LaserJet 1022 Error Message
I had exactky the same issue. The problem is not with the front door or the cartridge. I solved this as there was a very small paperjam. If you take out all the paper and shine a torch into the printer you may find a small piece of paper stuck on the sensor that is causing the problem
Aug 12, 2008 | HP LaserJet 1022n Printer
Paperjams
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
Nov 21, 2007 | HP Color Laserjet 3550 Printer
HP LaserJet P2015dn Printer Logo
1,011 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
