Gas oil mix
Most 2 cycle engines run on 40:1 ratio meaning for every gallon of gas mix 3.2 ounces of 2 stroke oil. Also check the owners manual to confirm the mix ratio. Some run on 32:1 or even 50:1. The 1 meaning 1 gallon of gas. I hope this helps.
Hi anon, the usual ratio for most 2 stroke engines is 40:1. The 1 being two stroke oil
SOURCE: Troy built 27cc string trimmer Model TB21 EC. What
4 cycle engines do not run on mixed fuel. Run on straight fuel. They have a spot to put oil in just like a lawn mover, and should be changed regularly. @ stroke engines run on mixed fuel.
