Question about Zanussi IZ12 Front Load Washer
After wash clothes come out after wash they have dirty specs
    Sergeant:
    Champion:
  • 353 Answers
If machine is noisy in spin cycle suspect faulty bearing seal. replace seal and bearings
Posted on Jun 30, 2009
I install a new spin motor in my defy twin washing m. When its cold its work 100%, after while the motor over heats and cut out
Why is the motor overheating - that is the issue. Too many clothes in drum? Excessive drum friction? Dirty motor bearings? Drive friction problem?
Disconnect motor and check current draw without a load to see what it is and if within specs. If motor has some melted windings internal resistance is down and current draw and heat is up! Motor could be fubar.
Sep 23, 2017 | Washing Machines
Dirty water still when i wash clothes
Do 2-3 loads with no clothes. Highest water level possible.
Mar 02, 2015 | Washing Machines
Why does my front loader washer leave clothes smelly ???
RUN A COUPLE WASH CYCLES WITH HOT WATER AND A GOOD AMOUNT OF VINEGAR HOPE THAT HELPS.
May 24, 2014 | Asko Washing Machines
Streaky dirty washing
try running some cleaner through the machine on a hot 60-90 degree wash cycle with no clothes in. It may take a few goes to remove the build up of soapscum from the inner drum of the appliance
Apr 09, 2014 | Hotpoint Washing Machines
My clothes are coming out dirty with lint build up from the washing machine- kelvinator smart drive 053, have undone and cleaned centre- is there a trap underneath anywhere that may be full or blocked?
9 WASH PERFORMANCE INFORMATION
9.1 Creasing
Creasing can be caused by over loading the washer or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet clothes to sit in the washer or laundry basket.
9.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash water. Cold water below 68oF / 20 oC does not wash effectively. Select the wash temperature according to soil type. For example, blood and mud are better washed in cold water, while sweat and oil based soil wash better in warmer water. Loads made up of articles of varying sizes will wash better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent than soft water.
9.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading the washer can increase the likelihood of linting. Insufficient detergent for the load can increase linting as there will not be enough detergent to hold the lint in suspension. Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the fabrics attracting lint.
9.4 Detergent Residue
Over loading the washer can result in detergent residue being caught in the creases of the fabrics.
If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check the instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times may not let the detergent dissolve properly. In these cases pre-dissolve the detergent. Overdosing of detergent can also cause residue when foam breaks down and will show as white specs on the clothing. Poor quality detergents can result in residue.
9.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is recommended that the machine is periodically filled with hot water, plus 1-2 cups of dishwasher powder and left to soak.
9.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that the machine be periodically filled with hot water, plus detergent and left to soak.
9.7 Dye Transfer
Wash and dry non-colorfast clothes separately. Non colorfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
9.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load the machine by wrapping clothes around the agitator.
Sep 18, 2013 | Fisher Washing Machines
Sludge On white clothes
12.1 Creasing
Creasing can be caused by over loading SmartDrive or the dryer. Permanent Press or Delicate
12.2 Soiling
water. Cold water below 20oC does not wash effectively. Select the wash temperature according
soft water.
12.3 Linting
fabrics). Over loading SmartDrive can increase the likelihood of linting. Insufficient detergent for
12.4 Detergent Residue
Over loading SmartDrive can result in detergent residue being caught in the creases of the
fabrics. If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check
12.5 Black Marks on Clothes
recommended that SmartDrive is periodically filled with hot water, plus 1-2 cups of dishwasher
12.6 Grey Marks on Clothes
this is a problem it is recommended that SmartDrive is periodically filled with hot water, plus
12.7 Dye Transfer
Wash and dry non-colourfast clothes separately. Non colourfast clothes left sitting in a washer or
12.8 Tangling
other. Do not load SmartDrive by wrapping clothes around the agitator.
Aug 09, 2013 | Fisher and Paykel Washing Machines
My Fisher and Paykel Aquasmart is leaving white marks on my clothes. I am using the correct washing liquid, so how can I fix this? I am sick of re-washing half of my clothes
12.1 Creasing
12.2 Soiling
soft water.
12.3 Linting
12.7 Dye Transfer
12.8 Tangling
May 24, 2013 | Fisher and Paykel Aquasmart wl80t65c
Fisher and paykel washing machine GW703-U leave black spot on clothes during final spin
12 WASH PERFORMANCE INFORMATION
12.1 Creasing
12.2 Soiling
soft water.
12.3 Linting
12.7 Dye Transfer
12.8 Tangling
Jan 30, 2012 | Fisher and Paykel Washing Machines
Dirt in rinse cycle causes clean clothes to come out with dirt all over them and inside of the washing tub has dirt everywhere!
Several things could be happening...The machine is NOT "spitting" all the water out and there is STILL some dirty h2o (water) in the wash. You could be putting in dirty WELL water ? If you have HARD water and your "hard water filter, cleaner not working. Your cloths could be SOOOOOOOOO dirty ( no offence !!! because there are many D I R T Y jobs that could take two(2) washings ) that they are not getting clean.
Aug 31, 2009 | Washing Machines
Zanussi IZ12 Front Load Washer Logo
99 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
