SOURCE: 2006 Toyota Tacoma V6 engine oil sensor location
There is not enough flow at the sensor for a second oil filter. The sensor is at a dead end in the oil gallery. I recommend that you persue other options here. If you are concerned about oil contamination, don't be. There is nothing better than the factory filter...Look into adding more oil capacity; Look into an engine oil cooler; there is really no need for a second filter.
SOURCE: How do i reset the maintenance required light
1. Turn the ignition key to the “OFF” position
with the odometer reading shown.
(For details, see “Odometer and two
trip meters” on page 145 in this Section.)
2. Turn the ignition key to the “ON” position
while holding down the trip meter
reset knob.
Hold down the knob for at least 5
seconds. The odometer indicates “000000”
and the light goes off.
If the system fails to reset, the light will
continue flashing.
To reset the Maintenance Lamp turn the car key to ON (not start), set your odometer on mileage (not trip a or b), then depress and hold the button that switches from odo and trip then turn key off. Turn the key back to ON, while you are holding the button down you will notice the maintenance light blink and go out. Reset is complete and you are done.
These are available in your owners manual for the vehicle.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: how to change the check engine light on a 2000 toyota tacoma
i had the same thing, i had it tested at auto zone and they said it was the obd2. i was told the o2 sensor was not a big deal so i reset the check engine light by holding down the trip meter button while starting her up and it has not been on since.
SOURCE: 2003 parking bulb toyota tacoma
OK, I just fixed mine. The unit pulls out. You have to get a screwdiriver, wrap it with a cloth so it doesn't scratch the paint, then gently wedge the entire unit out. When it pops out, you'll see the clips that keep it in place. You might think its breaking when you pull it out, but trust me this is how you do. Just be gentle with it. After you get the unit out, simply take the socket out and replace the bulb. I did it in five minutes.
SOURCE: how do you change the differential oil on a 2006
if its not leaking do not touch it. its lifetime.
