It is National fully automatic washing machine. It has been working fine for the past 7 years. But for the couple of month it has lost control over fucntions, i.e. it starts a fucntions and doesnot switch to other fuction automatically, it keeps on doing the same thing unless stopped manually. Any suggestions please. Thanks.
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
My washing machine shows a F, it rinse spin s and dry but don't wash
Completely striking out looking for our machine ... or codes
little further research tells me it is DEFINATIVELY not the USA market...
Get your T1303TEFT manual here:
https://www.manualslib.com/manual/644235/Lg-Wft11g00ted.html#manual
For service in your area...
Telephone Call an LG Support Representative at
Jordan
Saturday to Thursday: 8:00 am ~ 7:00 pm
Except national holidays
080022154 (Land line)
065608530 (Mobile / Land line)
Iraq
Saturday to Thursday: 8:00 am ~ 5:00 pm
80011110
Lebanon
Monday to Saturday: 8:00 am ~ 7:00 pm
1273
Syria
0115495400
Sorry didn't SEE that coming Carnac the Magnificent
Jan 13, 2017 | LG Washing Machines
My videocon fully automatic washing machine (45FDx) is 7 years old. It is continuously showing E2 error. I have called the company technician but not of much use. Can u help pleae?
This can be due to a error in the control panel, You can switch off, remove the front panel and check for moisture on the panel, if so use a dryer to ward off the moisture. Also check the connections on the board. If the fault reoccurs then you might need to replace the panel board.Make sure the door switch, inlet valve and drains are clean.
Feb 12, 2013 | Washing Machines
My Whirlpool Fully Automatic Washing machine has some problem with WASH process, the agitator is not all working but the SPIN process, SOAK process are going on fine. Some scratching sound was heard from...
Most Whirlpool washers have ratchet type pawls in the agitator. If it is like mine, the top of the agitator pops off where you would ad softener detergent (in the center top of the agitator) and you will see the ratchet pawls inside the agitator. Mine we worn out and doing the same thing. I replaced mine and the unit is working fine now.
Dec 01, 2010 | Washing Machines
My National Fully Automatic washer NA-650PT stops during DRAIN process, any suggestion on what should I do with it..
Check your Magnet coil, its the problem. it might be short curcited due to water.
Nov 05, 2010 | Washing Machines
We have a Whirlpool 7 KG fully Automatic washing and the display is showing FE and the water is not filling in the Machine
either your water supply is shut off or the water fill solenoid valve isnt working to let water past the fill valve or the solenoids are not getting power from the control unit to do so
Sep 29, 2010 | Whirlpool Washing Machines
For the past few years the small fuse in the washing machine blew about once a year. A few months ago it seemed to blow every week. Then it was fine again. Now I replace the fuse and as soon as I turn on...
One says the lid switchs are not working in tandem with each other. Another says the circuit board is bad. I say it is because it is a Maytag and built with an obsolete ethical plan for generating profit.
Dec 29, 2009 | Maytag LSE7806A Top Load Stacked...
Ultimate Care II Whirlpool Washing Machine (top loading) - same problem as everyone else. 4 years old - gets to the final spin cycle and just "whirs." It appears that the door switch is working. It clicks...
it sounds like you have a broken motor coupling. disconnect power supply unscrew 2 screw on each end of backside of control panel, flip control panel to back, remove lid swt connection and pry up the 2 clips that hold cabinet. remove cabinet, on bottom of front you'll see the pump and motor. pry off the 2 clamps that hold on pump you can tie pump to side to keep out of you way don't disconnect hoses. remove 2 1/4 in screw that hold clamp to motor and remove motor clamps pull mtr to front and pry off coupling from shaft of mtr and transmission.replace coupling pn 285753a for about $10 .reverse procedure to install
Dec 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Hi there, I have had my Servis M9813W for 2 years now, the other day i went to do some washing and the door would not lock - tried slamming it, turning off the machine but no avail - it will not lock and...
Unplug it, wait 2 minutes and try again.
Otherwise
5 year parts guarantee, 12 months labour. All Servis appliances come with a full 12 month parts and labour guarantee and an additional 4 year parts warranty (to take advantage of the additional 4 year parts warranty, the guarantee card must be returned to us for registration) which reflects the confidence in our range of products.
All products are extremely reliable and we hope that this guarantee demonstrates that Servis are serious about providing top quality products to the marketplace.
The after-sales service is provided by our own national team of service engineers who are fully trained and only use Servis replacement parts guaranteeing the long life and performance of your Servis product. Contacts Servis Cares Call Centre: 08705 168299 Proactive Repairs: 0121 568 2270 E-mail: proactive.repairs@servisuk.co.uk Replacement Parts: 08705 168299 E-mail: spare.parts@servisuk.co.uk
Sep 16, 2008 | Washing Machines
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
