Question about Mountain Shimano Tourney 6/7 Rear Derailleur Direct Mount Bike
The chain is rubbing on the rear tyre when its free wheeling. what do I do?
  • 484 Answers
You may have too large a tire on the back for the bike. However, if the derailleur hanger is bent, this could also cause the problem. Flip your bike over onto the bars and seat and make sure the derailleur alignment is good (vertically and longitudinally straight). If the derailleur hanger is straight, then you will have to use a narrower tire in the back.
Posted on Sep 12, 2009
Noise coming from the rear of the car as result of changed rear tyres.
Did you fit tyres of the same size as were removed, if not tyre could be rubbing on inner guard or suspension.
Did you use the same rims as you removed, if not the rim offset may be wrong and rubbing on the brake or suspension.
Remove wheels and look for rub marks.
Apr 19, 2015 | Cars & Trucks
Noisy rear wheel
Sounds like a seperation in tire. Inspect outer tread if nothing look for places around tire that not smoothe.
Apr 08, 2014 | 1999 Subaru Impreza
I need details toremove rear wheel for tyre change please
You need to remove the exhaust first,then put a motorcycle liftt under the bike,lift it to just take off the rear wheel from the floor,remove the caliper and let it hang on the side,then loosen the axle nut and remove the axle then the belt or the chain.Voila!!! your wheel is now ready to swap with the new tyre.
Apr 24, 2011 | Harley Davidson FXST - FXSTI Softail...
How do you align the wheels on a ktm 660 smc
Place the bikes rear on a paddock stand or have someone hold it upright for you.
Place two lengths of straight edged angle iron or wood, at least a foot longer that the wheel base of the bike on the ground, one either side of the rear tyre. The front wheel must be central. After adjusting the chain tension push the straight edges up against the rear tyre and pull/push the otherside of the axle until the front wheel is in line with the central place between the straight edges.
Jan 16, 2011 | 2004 KTM 660 SMC
Jaguar x type 19" alloy wheel upgrade but rear wheels rub on arch
I really don't think you will be able to use those rims and tires, probably the biggest is going to be 18" wheels. The 8.5" rim is too wide. An 18" came as the stock size on the sport package for the Jag, it's 7.5 wide. I don't think who sold them to you really knew if they would fit or not. Without wheel spaces and raising the suspension, I don't think they'll work on the car.
May 14, 2010 | 2004 Jaguar X-Type
Rear tyre upsizing
Yes you can go to a 100/90/18 on the rear, if you are sure it wont rub on anything. This will not create any problems with stability, in fact may improve the handling of your bike. Will not affect the life of the chain.
Apr 15, 2010 | 2005 TVS Fiero F2
MY REAR TYRE CONSTANTLY MOVES TO THE RIGHT HAND SIDE AND RUBS UNDER GUARD .I HAV CHANGED TYRES FROM A 140 NOW TO A 130 IS THERE SPACES GETTING GRINDED SMALLER. 1200 XL
Check the wheel bearings. The wheel should not move from left to right. Also take the bike and get the rear wheel in the air on a jack and take hold of the wheel on top and on bottom and see if you can move the wheel while you push the top and pull the bottom repeatably
Oct 02, 2009 | 2000 Harley Davidson XL 1200 C Sportster...
Rummbling noise at rear wheels
Sounds like universal joints going out.
Aug 06, 2009 | 2003 Audi A4 Cabriolet
Mountain Shimano Tourney 6/7 Rear Derailleur Direct Mount Bike Logo
138 people viewed this question
Top Mountain Cycling Experts
Michial Gueffroy
john h
Are you a Mountain Cycling Expert? Answer questions, earn points and help others
