Question about Acer Computers & Internet
Extensa 4220 password remove
Hello
sir am a new user of this web,
any one can help me?
forgot dos password of my extensa 4220
now i can't change bot order
plz help me any one
thanks
I forgot my password on my hp omnibookxe3
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
it will prompt you to enter the new password
enter the new password and the password is changed
hope this helps
Jul 03, 2012 | HP OmniBook XE3 Notebook
I have acer extensa 4220 laptop amd motherboard and a amd turion tm 64 processor but dont know if if the processer will work with this board, do you know which processors work with this board.
I'd like to have more details for your extensa (the country that you bought from also) because officially this model has an Intel Celeron-M 530 processor at 1.73GHz, 533MHz FSB, 1MB L2 Cache. Here is the link with the official specifications (for the Extensa 4220 Series).
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Oct 04, 2011 | Acer 4220-2346 Notebook
I am trying to remove or reset password for Acer Extensa 4220. I already tried several times removing battery but no luck on resetting the password. Anyone know how to reset or disable the BIOS password?...
Hi
To break BIOS password, you need to unpack the laptop
there is inner cmos-battery that should be removed for a while, and put it back to it's plase,
but this operation isn't easy to be done, it should go through technician.
Please tell us your results
Good Luck
May 15, 2011 | Acer 4220-2346 Notebook
Dear Sir, i forgot my hp compaq nx6115 laptop power on password .please help me..
a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
If it fails, then try to remove the battery for at least one hour.
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
hope this helps
Jan 28, 2011 | HP Compaq nx6115 Notebook
Cant remember password to restore my computer
When you boot up to the log in screen type in administrator as the user to log in once you have your computer running again you have to take control (administrator)control panel user accounts on the users tab,click the name of the computer administrator you can change the password there or if your computer has a system restore you can restore it to an earlier date which will have your personal settings or
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
click start control panel user accounts
hope this helps
Jan 14, 2011 | Acer Extensa 5230E2913 Notebook
Reset bios password for acer extensa 4220
open the rear flap of the unit and remove the ram.
look for the two pins or bars near the ram and then take a paer clip open it and short out the pins. replace the RAM and reboot. Problem solved.
Please rate our help++++Thanks for using FIXYA
Oct 07, 2009 | Acer 4220-2346 Notebook
Forgot my administrator passwords
Was it in the BIOS as supervisor or in the windows section. If BIOS change password by entering blanks(spacebar) else create a new user, login, and modify the old password or delete that users account.........sodeep
Apr 09, 2009 | Computers & Internet
Web cam not working.
go into control pannel. go device manager. right click on the camera and uninstall (do not select delete driverS)
reboot the machine
install yawcam
if still having problems go to manufactureres website and search for new drivers for the camera.
or call my office 0845 20 20 118 and I can get them sent to you
Sion .
Dec 11, 2008 | Acer Aspire 3610 Notebook
I need to know how to reformat my acer extensa 4220. I have no boot disk and I have a virus that is not allowing me to see my system information or MYcomputer and so forth
first create a boot disk.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
  1. Place diskette in the computer.
  2. Open My Computer, right-click the A: drive and click Format.
  3. In the Format window, check Create an MS-DOS startup disk.
  4. Click Start
You Will Have your own Boot Disk.
Backup Your Data.
Boot With the help of BootDisk.
Load a new XP.
Virus Scan All the Drives and Data.
Sambeet
Sep 19, 2008 | Acer Computers & Internet
Computers & Internet Logo
85 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
