Question about Saeco Incanto Sirius Fully Automatic Coffee Maker Stainless/Black
Fill water tank light still on despite tank full. It is just back from the repair shop. Do I have to prime the machine or do something the first time it is turned on after repair?
  • louisejanera Jun 30, 2009
    Followed your instructions. Coffee machine still tells me to fill tank even when then tank is full
    Yes I dont think the repairer did their job!!!!
    President:
  • 1,383 Answers
Just presss reset button and resdet all settigns to factory defaults.
Also reatttch all connection to it.
Posted on Jun 30, 2009
  • kishor
    kishor Jun 30, 2009
    I thikn your water sensor system has some issue .
    President:
  • 392 Answers
Please let me know the product's manufacturing company , and the solution for that is to get check the sensor.whether it is working or not.
DeLonghi (W160B) Portable Air Conditioner "No Water" symbol is still on despite the water tank being full
Tank hols 14 litres water where you fill there is a indicator if that is clear the tank is not full has to be red to be full. The water fill symbol will then go out.
Dec 23, 2012 | Heating & Cooling
Won't prime
The water pump system is not primed properly. Remove the water tank while the pump is running and put back a couple of times. If not working, when the power is off, using a straw, blow air through and try to **** through the water port at the bottom of Keurig. Plug the water tank again in and start the system. It will take some time to prime, keep trying. There is nothing wrong with the machine, but the water pump circuit.
Oct 18, 2012 | Keurig Elite B40 Coffee Maker
Water is full, but red water light is on and coffee wont come out
Try lifting the water tank and make sure it is pressed along the back of the machine when you put it back in.
Sep 28, 2009 | Saeco Incanto Classic Espresso Machine
Just out of the box, the sirena espresso maker doesn't heat and buttons don't flash
You need to prime the machine with water. Fill the water tank. Plug the machine in and turn the power on. Instructions state the lights will flash, but they won't. Blue water drop will illuminate indicating the machine is empty (the water tank is full, but the pipes in the machine are empty until you do the following). Place a cup under the steam wand, and rotate the steam knob fully to the "on" position (fully clockwise as you view it from the side until you hit the hard stop). No need to use force, just rotate until you hear the pump turn on. At this point, you'll hear a pump running, and after 10-30 seconds, water will be ejected from the wand. Continue until the blue light goes out and you're ready to brew. At this point, I think the lights flash and it comes up to temp. One more thing, when using the steam wand, always turn the knob until the pump engages, or you run the risk of emptying the water line. Hope this helps and enjoy!
Sep 15, 2009 | Saeco Starbucks Sirena Espresso Machine
Blue light blinking, tank full, water not heating up
noavatar_s.gif rktcyntst
Rank: Apprentice
Rating: 0%, 0 votes
Sep 14, 2009 | Saeco Starbucks Sirena Espresso Machine
The blue light is blinking, the water tank is full, but the water isn't heating up at all. should we return it? Or is there something that we missed? We followed the instructions and are getting no where.
blinking light means the water circuit requires priming.
1 - press power button.
2 - place a cup under steamer and turn on full.
3 - turn steam off when blue light stops blinking (probably a few ounces of water in your cup).
4 - you're ready to rock!
Aug 18, 2009 | Saeco Starbucks Sirena Espresso Machine
Via Veneto will not prime
Yes, unfortunately the Via Veneto is a difficult machine to prime, however, I have a simple way to prime the pump if you run into this problem. Simply remove the water tank, fill a clean turkey baster with water, open the steam valve fully then mate the baster tip with the water tank flow valve on the espresso machine. Wrap a towel or paper towel around the flow valve/baster tip then inject the water (agressively, but not forcefully). It's works for me every time.
Sep 18, 2008 | Saeco VIA Veneto Espresso & Coffee Maker
Fill Water tank - Ventilate
Hi Mike,
Make sure the magnet flow up, if it flow up and you still get fill water tank then you have to replace the magnet.
If you get ventilate all time, try to remove the filter and try again.
/Mirran
Aug 23, 2008 | Saeco Incanto Classic Espresso Machine
Nespresso Magimix M300 'Fill Water'
it just means that the pump needs primed. Turn on at the wall and on the machine, wait until screen says ready (make sure water tank full), then turn steam handle on RHS to on (do not push the steam button). the pump will prime until water comes out of the steam nozzle. now turn off the steam handle and you are ready to go!
Sep 16, 2007 | Coffee Makers & Espresso Machines
Saeco Incanto Sirius Fully Automatic Coffee Maker Stainless/Black Logo
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
