Televison & Video Logo
A
Anonymous Posted on Jul 30, 2014
My picture display is narrow and does not cover the screen.
We use Direct TV and recently got a genie box put in living room. Our HD tv has been fine until recently. The picture stopped displaying across the 40 inch screen. There is 4 or 5 inches of black on each side. The Direct TV technician said to check with my TV Manual or manufacturer. Can't find my manual. TV is only 1 1/2 yrs old. It was working fine until they hooked up Genie and for a while it worked fine. I called them once before when it started and a technition talked me through and it was fine until a few days ago. Another technician today could not fix it. She said to call TV Manufacturing Co. Who should I talk with? Can you suggest something? Villa Jean Tiller
Roni Bartlett
Level 1:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 31 Answers
  • Posted on Jul 30, 2014
Roni Bartlett
Contributor
Level 1:
Night Owl:
Answers
31
Questions
Helped
6077
Points
83
Does the Genie box have screen settings in in? Sometimes hd will show in smaller screens. Makes the picture nicer. If you adjust the screen size with your remote the high definition "niceness" will not be there.
5 Related Answers
Anonymous
  • 109 Answers
  • Posted on Mar 31, 2008
SOURCE: Help with Panasonic plasma TV's display shift
you have an issue with the digital or main control board, and if the unit is still under warranty the manufacturer will help locate someone nearby. (actually even if out of warranty it's still a good idea to use that service co. for the simple fact they have more exeperience with the tv's
Anonymous
  • 927 Answers
  • Posted on Jan 02, 2010
SOURCE: Samsung LCD 40 inch LNT4061
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thanks for using FIXYA, big IRISH.
Anonymous
  • Posted on May 04, 2010
SOURCE: i have a 46 inch that has black across half the
call 1-251-414-3411 for answer
ripleymojica
Mando Mojica
  • 643 Answers
  • Posted on Mar 24, 2011
SOURCE: I have a Viera 42 inch plasma tv (model
the problem is the panel is going bad. usually not economical to repair. repair usually runs as much as a new one.
Anonymous
  • Posted on Nov 12, 2011
SOURCE: Polaroid 40 inch tv (TLX-04011C) Picture is
its the ribon cables from the lcd patern bords on top there is 2 of them normaly its the right side that goes bad but in your case its the left there is only 1 way to fix it
you have to replace the lcd screen panel with the 2 pattern bords on top
How do I setup my dvd to mt tv, i use direct tv
How to Program DIRECTV Remote Control ' DIRECTV ...
https://support.directv.com/.../how-to-program-directv-remote...
DIRECTVTo do this, press and hold the MUTE and ENTER buttons while pointing at your Genie HD DVR, Genie Mini, or Wireless Genie Mini. The screen will display Applying IR/RFsetup. To program your remote to control a regular HDTV (not a DIRECTV Ready TV) or audio devices, follow these steps: Press MENU on your remote.
How to Connect DIRECTV Receiver to TV ' DIRECTV Support
https://support.directv.com/.../how-to-connect-directv-receiver...
DIRECTVHow do I connect my DIRECTV receiver to my TV? Print. Email ... This will help you determine what cable to use to connect your receiver directly to your TV. ... For example, a DIRECTV receiver, DVD player, Blu-rayâ„¢ Disc player, o... How to ...
Remote Control Code Lookup - DirecTV
Tv screen goes black after 15-20 seconds
It's not the TV from what I can tell. I would start complaining about it and say you want a brand new box. Not used. They tend to give out boxes from people who previously had them and either didn't pay their bill or moved and clean them up.
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
N2750W PROBLEMS WITH DIRECT TV
just press the "PIP" button on the remote it happened to me and i just thought that it looked familiar and i pressed it and it worked hope it helps :)
RF module related to Direct TV.
yes you can but the 2nd tv wont be in HD. The modulator can be purchased for any electronics store. what it does is turns a composite video signal (yellow, red, white cables) into a coax (screw in cable). it has an composite input that you would connect from the receiver and a coax output that you would connect to the other bedroom tv.
Direct TV/Olevia 247 audio skipping
I have the same problem with comcast HD, completly useless talking to them, they do nothing to assist
Top Seiki Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
MrFixitSTTL
Kardoc
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
