Question about Sony SLV-D100 DVD Player/VCR
SLV-100 will not respond to controls. Displays "Welcome". The fan continues to run.
  • 1,056 Answers
I have worked on a dvd with the same problem. Check to see that the board where the buttons to the control is located is not cracked. Sometimes people push them too hard, and break them. You would have to open it. If its cracked you can resolder each connection again, but some of the traces are extremely thin, and may require magnifying glass, it takes lots of patience. LOL Other than that it is beyond you the consumer to fix it. Electronic component failure is hard to spot without eletronic expertise.
Posted on Jun 30, 2009
Why does the cooling fan in oven run foerever?
The cooling fan is controlled by the EOC and a temperature sensor located at the top of the oven near the control panel. If the temperature is above a 100 degrees there the cooling fan will continue to run. If it does not turn off when the temperature goes below this, there is a problem with either the EOC or temperature sensor. Try turning off the power to your oven for at least an hour to reset the EOC, this may fix the problem.
May 14, 2014 | Kenmore 46123 Stainless Steel Electric...
Fan will not turn off even though oven is cold and the controls do not respond
I use and recommend RepairClinic.com. If you have the make and model number of your stove the website usually gives trobleshooting answers. Good Luck.
Nov 25, 2011 | Ovens
Door won't unlock after self cleaning. Code F1 appeared after cleaning was done. The fan continues to run even after oven is cool and door won't unlock
Hello & Welcome to FixYa
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Please get back to me if you have any other questions.
Kevin
Jan 01, 2011 | Maytag Kitchen Ranges
Lost codes for v.old universal remote
All universal remotes work about the same. Try this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 24, 2009 | Sony SLV-SE720 VCR
Sony slv n77 vcr remote sensor is not responding, please help. It is not the remote control's problem because I can use this same remote control to operate another sony n77 vcr.
might the receiver cant "see" the ir of the commander due to dirt which is inside the "plexiglass" (caused of smoke etc). try to test the remote without front bezzel...
Jun 16, 2009 | GE Televison & Video
Cooling fan continues to run after turning car off
Try change the Fan Assy....there a small box with state (Gate) on the upper right of fan assy... it does controling the sped of the fan...
Jun 13, 2009 | 2005 Mini Cooper
Loud Noise on laptop when booting
Most likely it is the POST throttling up the fan to 100% during boot up. Then it switches over to ACPI(?) power manangement and Windows manages your fan speed to extend battery life.
Suggestions:
Go to Dell Support Site https://support.dell.com/support/supportrequests/create.aspx?c=us&cs=19&l=en&s=dhs
Download the latest BIOS updates and run it.
If it continues, try a can of compressed air, and breifly blow out any debris from the system fan. Bits of paper and critter-fur can get sucked up into the system.
Apr 18, 2009 | Dell XPS M1210 Notebook
SLV-N750 compatibility with DTV signal
As long as your cable company converter box is feeding your VCR, you should be ok. The cable box should convert to analog which is what your VCR records.
Jan 19, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony SLV-D100 DVD Player/VCR Logo
99 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
