Question about Maytag Washing Machines
Maytag A9400 washer won't agitate
Washer fills, spins and pumps water out but will not agitate
there is a buzz suond like somthing wants to kick in but can't
  • 232 Answers
The motor, sorry! if left on wash cycle it humms for a bit quits and trys again? or not? the motor is about $130.00 part# 201805
Posted on Jun 30, 2009
Hello, I have a Maytag Bravos MVWX550XW washer that will not rinse or spin, only wash. The drum moves. I replaced the washer inlet valve, did not fix the problem. Removed the lid switch assembly...
hi Melanie.
this is all i could find out.
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
How to Drain Washing Machine That Won Drain Family Handyman
What is wrong with a washer that does not spin? If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle
Washer Doesnt Agitate or Spin
Maytag Washing Machines will not rinse or spin Google Search
Dec 12, 2017 | Maytag Washing Machines
Tip
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
on Dec 12, 2017 | Washing Machines
No water or agitate
IS THERE A BLOCKAGE IN THE PUMP OR THE MOTHER BOARD IS FAULTY
Dec 27, 2013 | Maytag Washing Machines
Washer buzzes and won't agitate or spin. Only will fill with water.
Almost certainly with that sound, the motor start capacitor has failed. It will be located either behind the control panel, or underneath next to the motor.
Dec 17, 2013 | Maytag Parts Washing Machines
Older maytag stackable washer and dryer combo washer fills , washes and spins but water wont pump out
check for the pump belt broken or off,clogged pump or sock or small item clogging the tub outlet to pump hose. the pump pulley may have become loose on the shaft also
Feb 28, 2013 | Maytag LSE7806A Top Load Stacked...
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Maytag MAV6257AWW Washer
Could you describe the noise you are hearing. This will help to determine what to look for.
Jan 13, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
246 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
