I cant figure out how to get my car going. it wont start the key wont come out at all
SOURCE: Key wont turn
no it sounds like the ignition clinder is broken or worn down inside either that or maybe the key itself. get a new key made (local hardware store) and try that one if that doesnt work im afraid that you may need a new key and tumbler
SOURCE: Cannot replace high rear brake light on 2006 Kia Optima.
go into the truck. there are 2 screws holding the stop light cover. it is at a place hard to get you hands in.
good luck
SOURCE: 2008 Kia Optima Check Engine Light
Just replace the air flow meter.That sounds like your problem.
SOURCE: 2008 kia optima LX Check Engine Light
P0442 EVAP Leak Monitor .040 Leak Detected (Medium Leak)
P0456 EVAP Leak Monitor .020 Leak Detected
replace your gas cap and clear codes, then wait and see if light comes back on, if it does you have a more serious problem like a fuel tank leak or a defective fuel tank pressure sensor.
SOURCE: Key won't turn in ignition
this problem is caused by one of the tiny little pins that are used to code the lock getting stuck, u can try getting some powdered Graphite lock cylinder lube to try and free it up, if that doean't do it you will need to replace the ignition lock cylinder, don't use anthing but dry lock lube, WD 40 or any kind of oily spray will make the problem worse in the long run. Lock lube is avil from any hardware store like ACE or Home Depot
