Question about Intel Desktop Board D845GLLY Motherboard
How to recognize the dameaged IC with analog meter
I have Intel desktop D845GLLY board ,on startup it does not give me any beep i think it ram ic problem but i have my doubts ...so how can i recognize the damaged ic .i am novice in electronics so please help me.........
  • 1,056 Answers
It is hard to tell. You need at least an oscilloscope, and understanding of digital electronics. When chips go bad they usually quit oscillating. An easy way to find out it is oscillating is by using a multimeter, and checking the frequency of the output, and the input pins. This test will not tell other problem with the chip tho. It will only tell if the chip is completely bad.
Posted on Jun 30, 2009
  • 3,267 Answers
If the RAM had got kaput then there would be continuous beeps coming from the MB speaker. Press all power plugs firmly, clean the RAM contact points with a pc of normal white paper, look inside the CPU. There should be a greenish LED lighted as long as the mains are connected & if its not, straight away change the SMPS(power supply inside the CPU), otherwise see that the power switch is connected. Also check the snugness of all cables including RAM slots. If the processor fan starts, but no display then check for any bent pins in the mouse & keyboard PS2 jacks(see to it that no key in the keboard is constanlty pressed/depressed). If still no display then use your older RAM only. If no success then change the SMPS.of the save 400-450 VA(watts).............sodeep
I have not get display due to mother board no access the RAM. and i have check the mother board without install RAM and i did not get any beep/sound plz tell me what is the problem and how i can solved...
This motherboard has an on-board video card and it uses shared RAM. The video uses part of the main RAM and if there is no RAM modules installed then you will not get any display or POST beep codes.
Jul 14, 2011 | Intel Desktop Board D845GLLY Motherboard
Have an intel 845 gvsr board. no beeps no display..
was you check your ram?/is your ram ok, usually the ram that half dead make this response, plug off ram then hear is there any beep, if yes change your ram if no its mean *********** board was damaged, change your motherboar
i hope this helpfull, please raet very helpfull or helpfull if you think this helpfull
thanks for using fixya
Jan 20, 2011 | Intel Desktop Board D845GLLY Motherboard
845glly intel motherboard sigmetal sound driver
Open the link provided & allow Intel to search your system for updates;
http://www.intel.com/support/motherboards/desktop/d845glly/
Or
Open this link; http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%c2%ae+845+Chipset+Family+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D845GLLY
Scroll down until you see, Audio: Sigmatel* AC97 Driver on the left side of the screen. Download & install the AC97 driver.
Cheers!
Mike
Oct 02, 2009 | NEC Galileo 845GL (N4-IBFGL) Motherboard
I have intel 845 glly mainboard.on startup it does not give any beep..i think it is Ram Ic problem but how can i recognize whether ram ic is okay or not.
1. Remove your Ram
2. Clean the Ram slot
3. Clean your motherboard with solvent cleaner
front and read with a brush
4. use rubber to rub your Ram teeth
5. fixit
6. hope your problem will solve
Jun 30, 2009 | Intel Desktop Board D845GLLY Motherboard
No Dispaly Intel D845 GLLY
check the all power cable. change the motherboard battery. remove the ram, agp, then add togther. change the power supply.
Jan 23, 2009 | Intel Desktop Board D845GLLY Motherboard
Intel 845GVSR Motherboard no display Problem
no diplay in this board give me sme notes to chag ic.what ic i did change
Jan 23, 2009 | Intel Motherboard
Intel 845 glly board please solve the problem
Hi Nadeem Nawaz,
No board will show display without memory. Your motherboard must run memory type;
Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts.
Unbuffered non-ECC DIMMs only.
Maximum total system memory: 2 GB; minimum total system memory: 64 MB.
Serial Presence Detect (SPD) DIMMs only.
Intel link showing memory specifications.
http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-012825.htm
If your memory is within Intel's memory specifications & you are not getting display on your monitor. It is possible that the integerated on board graphics (Shown on page 13 in your user manual), may be defective.
You can add a PCI video card to the PC. The Intel D845GLLY will auto detect the PCI video card. No need to enter the bios & make changes.
Please keep this in mind. The integrated video card is PCI, if it has failed, there is a good chance it will not see the PCI add in video card. If you can find a used (Working) PCI video card to test in the PC.
Intel Desktop Board D845GLLY main website link.
Luck!
Apr 19, 2008 | Intel D845GLLY Motherboard
Intel 845 gvsr no display
Intel d845 gvsr no display ,but the ram is ok when i incerted the ram there is no beep and there is no sound. may be bios corupted and how to solve the problem
Mar 09, 2008 | Intel Motherboard
Intel motherboard 845gvs
intel 845 gvsr motherboard have two most problem
vrm circuit fail IC ADP3168 {between the cpu and core volt connector}
f7338 mosfet ic fail {between the memory slot and ide connector}
Feb 26, 2008 | Intel Motherboard
Intel Desktop Board D845GLLY Motherboard Logo
110 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
