Question about Charles Hunter 52" The St Ceiling Fan- Weathered Bronze
Honda accord 91
After i turn the car off the engine fan will turn on and off. Sometime later on, by the way engine is now cool it will turn on again so on tell the battery dies. What should i do
  • manhood59923 Nov 26, 2007
    looking this up for my daughter who is not in the same state so im trying to find anything that might help .... so i can pass it on to her .. i gave her what i could think of but im not there to fix it for her nor am i familiar with Honda
Easiest solution would be to simply disconnect your battery if you don't drive the car for long periods
Posted on Feb 25, 2008
I have already replaced the radiator and thermostat but my 91 Honda Accord still overheats, why?
Run a cooling system pressure test. If you are losing pressure, then you will have to first locate the source of your leak.
With the engine started and the radiator topped off with coolant, does the radiator spout water out of the top? Does the spouting become more aggressive with engine revs? Yes? = Blown head gasket, or cracked cylinder.
No?- check operation of radiator cooling fan. With car stationary and hood up, run engine up to temperature and make sure radiator cooling fan kicks in before the engine temperature rises too high.
Nov 03, 2012 | 1991 Honda Accord
91 honda accord fan stars when you shut off engine
There are two fan switches on that car;
The main one turns the fan on and off when the ignition is on and the car is running.
The second switch powers the fan if the ignition is off and the engine temperature is too high, to cool the engine off if it was just shut down.
It sounds like your main fan switch has gone bad and needs to be replaced since it's not sending any signal to the fan, while the engine is running.
Oct 22, 2012 | 1991 Honda Accord
91 honda accord won't start sometimes-battery, a/c, starter?
Your tempermental starting problem could be the park neutral safety switch . They get worn inside an cause this type problem . Next time it won't start place gear selector into neutral an see if it starts then . The cooling running problem is probably the cooling fan timer module . From the diagram it's hard to say which side the A/C condenser fan is on. The A/C fan has blue with yellow stripe wire in the connector along with a black one . I would also suggest you have a qualified repair shop do a voltage drop test on the starting circuit .
How to voltage drop test starter motor circuit
Starter Voltage Drop These test's will find any starting circuit problem .
Mar 28, 2017 | 1991 Honda Accord
Sometime the engine will turn over fine but, not
Listen for 2 to 3 second prime on fuel pump when the key is turned to the on position. Make sure every thing is as quiet as possible when doing this. also it may take several tries to hear it so make sure you wait at least 10-15 seconds before each try . the fuel-pump should also run while cranking. Do this and re-post and we'll take ti from there!--thanks
May 24, 2010 | 1991 Honda Accord
1991 honda accord lx cooling fan
Some vehicles have sensors that can control the electric fan with the ignition off to keep the heat buildup that naturally occurs right after turning off the engine. This can prevent hard starting that can happen with a hot engine. If it is doing this an abnormal amount, the sensor that is operable with the ignition off may be failing. Before turning off the ignition, check to see if the engine temperature is pushing the 'red zone;' if it is, then the fan operation may be normal but your engine may be running hot.
Feb 05, 2010 | 1991 Honda Accord
Cooling fan continues to run too long with engine off.
The thermostat switch need to be check and change.
Feb 01, 2010 | 1990 Honda Accord
The cooling fan doesnt work on my 91 honda accord
  1. Cooling fan Relay
  2. Engine temp Sensor
  3. Cooling fan itself
  4. If While A/C is on Fan does not come on I would Check Fan By unplugging it first than apply Pos+ and Neg- to it if it comes on that's eliminated Then go to step 1-3 one of them is bad I usually replace Engine temp sensors no mater what they are Crucial components for the safety of the Engine.
Jan 13, 2009 | Honda Accord Cars & Trucks
Both fans cool the motor. If you have the air conditioner on both fans will run because the cars cooling system will have to disapate more heat. If you have the air conditioner off only one fan will run because the heat load on the engine isn't as great.
Jan 01, 2009 | 1991 Honda Accord
Dryers Logo
53 people viewed this question
Top Charles Dryers Experts
Are you a Charles Dryer Expert? Answer questions, earn points and help others
