Question about Crown XTi 2000 2-Channel Amplifier
My XTi 2000 is very distorted intermintently. Sometimes the volume drops by at least half. I tap gently on he top of the amp and it comes back up to normal. I heard Crown has had some issues. What's the fix?
  • 4,234 Answers
From your description, I would suspect some poor solder connections inside. If you know how to work on these, check for bad connections near the voltage regulators. That is the mode common area.
Dan
Posted on Jun 30, 2009
Radio works but no sound
Don't laugh...but have you a) turned the volume right down. b) hit the 'mute' tab. c) tuned to a channel d) made sure antenna is up ? now it gets interesting e) checked the amp fuse inside the device f) checked the connectors from the speakers.......now the good bit.... wiggle the ignition key gently while engine running also gently pushing key in further.... it happened to my standard original 2001 lim ed still does, the wires cross inside . when engine on and radio going, it cuts out, sometimes just the display, sometimes whole thing blanks out.. comes back on when I tap key in. weird but true. sounds like amp fuse blown (right inside radio itself) Red
Apr 04, 2014 | 2002 Chrysler PT Cruiser
Stock headlight highbeam doesn't work, lowbeam does. How do I change the bulb? 2006 kawasaki 900 vulcan classic
Hey, Martin. There are two mounting screws that stick out of the back half of the housing just behind the seam, one on each side with their heads pointing downward a bit. Take them out, then tap the top of the front half to disengage the front half tab from the back half stop, and the front half should just drop forward into your hand. If you have the new bulb already, put on vinyl gloves -- the kind a doctor would put on before doing a prostate exam -- before opening the package it comes in. (Skin contact with the new bulb is a no-no, for the sake of the bulb.) Disconnect the modular connector from the bulb and gently remove the dust cover. Change bulbs, reconnect, snug the front half back into the housing (be sure that the word "TOP" is at 12:00), carefully reinstall the mounting screws, and you should be good to go.
Jan 12, 2014 | 1992 kawasaki VN 750 Vulcan
I use the crown xti 6000 for 2 double 18s pd186 for bass per channel
Send a signal from the mixer to the amp directly, seems as if you have a distorted signal from your crossover
Dec 23, 2013 | Crown XTi 2000 2-Channel Amplifier
Thermal protection comes on real fast at high volume
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . Please check speakers impedance .A thumbs up would be greatly appreciated if this answer is helpful to you
Aug 10, 2013 | Phoenix Gold Car Audio & Video
The guitar is not amplifying
faulty lead? when the lead is plugged in turn the amp distortion on (may be called 'gain') and when you tap the end that goes into the guitar with your finger you should hear a buzz. try another lead if not, and if it still doesn't work make sure that volume is up on the amp and the guitar. there may also be a knob in the back of the amp, turn that up too (but not all the way or when you do get it working you'll blow the speakers out).
Apr 19, 2011 | Marshall Amplification Marshall MG Guitar...
NAD 7020e sudden volume drops, sudden distortion- intemittently
OK. I dont know the answer to your prob, but to let you konw that youre not in this alone, my amp used to occasionly lose considerable volume in one channel. this could be remedied by cracking the volume up to max for a half second or so. (Not a great solution!!) It has finally given up the ghost ...I have lost one channel and the doctor says it wont come back. Not only this but they claim that spares ceased to be sold back in the 90's. having said this I have enjoyed this amp for almost 20 years. I think its time to put it to pasture.
SNO
Apr 12, 2010 | NAD Audio Players & Recorders
Roland kc 550 amp After it is warmed up for an hour, the output to speakers clip in all channels.Distorted and low volume.
Hello: You seem to have a heat related problem, I guess is that you are dealing with cold solder joints on the Preamp supplies or the Main board. This could also come from a faulty Vol control. Check for grey looking solder connections in the unit epecially around the output transistors in the main amp section. All solder connections should look Shiny. Check all capacitors for leakage or buldging at the tops. Seems when the unit has generated enough heat inside the unit the connections open up causeing distortion. When the unit is cold the connections make contact until heat is formed in the unit, So I say you have an Intermittent connection. Sometimes these can be very tricky to find. So use the handle of a screwdriver to tap gently around the unit while its open to see if you can reproduce the sound errors before it heats up.
Nov 29, 2009 | Televison & Video
Keep blowing speakers
It sounds more like you are overdriving the speakers not clipping the amp. If the output rating for the amp is 1000W into 4 ohms, this is approximately 500W into an 8 ohm load. Your speakers are rated for 400W. If you are running the amp at full output, that is too much power for the speakers and either the speakers are warming up too much and failing or are being extruded too far and failing. Your best bet is to better match the amp/speaker setup. Crown amps have built in clipping indicators and I believe that the xti series also has a compression circuit that would prevent distortion on the output side.
To confirm my suspicions, in what manner are the speakers failing? Are they completely open or do they sound distorted?
Thanks,
Dan
Apr 22, 2009 | Crown XTi 2000 2-Channel Amplifier
I have two xti 2000 amp running with electrovoice speaker 600w
This is most likely to be a heat issue where the amps overheat and shut themselves off then cool down and turn back on. Please check that the amps have proper ventilation and that any air ducts are clean.
Feb 26, 2009 | Crown XTi 2000 2-Channel Amplifier
Crown XTi 2000 2-Channel Amplifier Logo
235 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
