Computer says factory disc nearly full even after programmes removed?
SOURCE: sound problem
Hello, first off all, check if the sound device is activated
Second of all, you have two ways to get your sound driver:
1) Put your IBM cd recover and find there the sound drivers. (Usuallly is a folder with a number)
2) If you don't have the cd, go to ibm webpage at www.lenovo.com
then go to Support >> "software and drivers" put your machine number and model and get the sound driver there.
After that, you have to download the driver to your laptop, then go to "My PC" >> Properties >> Hardware >> Device Manager >> Audio ----->> and update the driver with the new one. That's it.
Please don't forget to rate my help >> Thank you!
Pablo
SOURCE: Will not create Acer factory default backup disc.
Are you trying to use a re-writable disc ? if so try it without. Is this a default back up just after purchase, if not ensure you run check disk on the unit first. to force one. Go to > My computer, right click the your root drive (normally c:). Go to > the properties of the drive Go to > second tab in and click "tools". Go to> check now error checking choose "automatic fix errors" this may require a reboot, then re-reun your acer factory default back up again. hope this helps
SOURCE: Creating recovery discs from the Acer eRecovery Management
http://support.acer.com/acerpanam/issues/260121793.shtml
click the link and download the patch
SOURCE: reset my dell d630 to factory settings
Hi:
The Dell D630 does not have a factory restore partition on the hard drive. Your only option is to use the windows restore feature that is accessable off of the start button, all programs, accessories, system tools. Plan B would be to borrow an operating system disk that matches the Certificate sticker on the bottom of the laptop, and then download all needed drivers from the Dell Website.
Acer are cheap and they don't provide you with a factory restore disk. You need to make this factory disk yourself. I know how to do this, but it is to much for me to type and here is a really really good reference site for you to visit to get instruction to make your own factory restore disk. After making that restore disc, pop the disk into your laptop and turn of your laptop and restart and the factory restore program should start, if it should not start then go into your bios menu and have it boot from your Dvd-Rom and save, after full restoration, make sure you turn your boot priority back to where your Os is being installed, exm hard drive.
http://www.ehow.com/how_4478845_restore-acer-computer-factory-settings.html
