Question about RCA Alarm Clock w/CD Player, AM/FM Stereo & Nature Sounds
My Tzumi Cube LCD Digital Alarm Clock keeps blinking
The alarm clock time keeps blinking this is not the alarm clock in the picture it is a Tzumi Cube LCD Digital Alarm Clock
SOURCE:
SOURCE: Small black device within RCA RP5420
That black disc is the "backup" alarm if you lose power.... The battery then takes over and "buzzs" throught that little speaker too wake you... even tho there is no power... Mine buzzes too... cut that little speaker outta there.!
Robert
Posted on Jul 23, 2008
SOURCE: setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
Posted on Jan 08, 2009
SOURCE: Cannot turn off the alarm on my RCA clock radio rp5430
Look at the display. Look for a number 1 or a number 2 to determine which alarm is on. If you see a number 1, push the 1 button on the top right side of the alarm clock until the number light goes off (1 or 2 times, depending on whether it is set to beep or radio alarm). When the number is not lit up, the alarm is off.
Posted on Aug 05, 2009
  • 268 Answers
SOURCE: I need an instruction manual for my RCA Clock
There are three buttons under the heading "Dual Wake", WK1, Cancel, WK2. The WK buttons refer to the two wake time settings you can have. Press Cancel and then WKx. That will turn off the alarm. If you press WKx more than once, it will cycle through small symbols on the bottom of the screen with the number x in front of them. First symbol means it will have a sound alarm for alarm x, second symbol means it will have a radio alarm and the third symbol means it will play the CD to alarm. You set the time for alarm with the slide switch at the back of the unit, selecting WK1 for alarm 1 and WK2 for alarm 2. You can have both alarms active at once, or either one singly.
Posted on Jan 07, 2010
  • 5 Answers
SOURCE: do not know how to turn off alarm setting for clock radio
Instructions are here: the closest available RCA CD-CLOCK RADIO USER MANUAL online is for Model #RP5610 at this location: http://www.voxxsupport.com/images/manuals/RP5610/media/RP5610_DOC_OM.PDF
If unable to link to that webpage, go to RCA Tech Support page at: http://support.rcaaudiovideo.com/manual.aspx?product=143 and click on download manual.
Posted on Feb 21, 2010
Set time on alarm clock nlc695 nelsonic
Hi Joe.
this is all i could find.
How to set Nelsonic alarm clock? Press and hold the ALARM BUTTON to enter ALARM SETTING MODE. While still holding the ALARM BUTTON down, press and hold the HOUR and MINUTE BUTTONS until you see the time you want on your LCD DISPLAY. Release the TIME BUTTON and the Alarm Clock Radio will return to NORMAL TIME MODE.
USER GUIDE Alarm Clock Radio - Jazwares
jazwares.com/assets/pdf/userguides/13500_wwe_alarm_clock_radio.pdf Search for: How to set Nelsonic alarm clock?
or go to this link might help you.
how to Set time on alarm clock nlc695 nelsonic Google Search
Nov 04, 2017 | Audio Players & Recorders
We had a power failure after a few power surges and now I cannot set the clock. The display keeps blinking rapidly. How can I set the clock?
Jensen Smart Talk JCR 290 User Manual Page 10
USING MANUAL SETTINGS
In radio off mode, press SET BUTTON (#5) to enter AL1/AL2/Time
setup mode.
1. The HOUR DIGITS and AL1 indicator in the LCD panel will flash.
2. Using the > (UP) (#6) or < (DOWN) (#4) BUTTONS, adjust to the
desired hour for AL1.
3. Press SET BUTTON (#5). The MINUTE DIGITS and AL1 indicator
in the LCD panel will flash (#25).
4. Using the > (UP) (#6) or < (DOWN) (#4) BUTTONS, adjust to the
desired minute for AL1.
5. Press SET BUTTON (#5). The SOUND EFFECT INDICATORS of
AL1 will flash (#25).
6. Use the > (UP) (#6) or < (DOWN) (#4) BUTTONS to choose a
Wakeup Alarm Sound - Ocean, Rain, Brook, Radio or Beep Alarm.
Jensen Smart Talk JCR 290 User Manual Page 9
Mar 02, 2016 | Jensen Interactive AM/FM Talking Dual...
I can't find how to change the time for the alarm system for a Alphaline 150i digital radio alarm clock
PDF]Instruction Booklet - Sound Therapy and Relaxation Clock ...
www.conair.com/instruction.../07ps111_su7_ib.pdf
Conair CorporationThe LCD display will show the current time of ALARM 1, reset time. ... The Conair Sound Therapy & Relaxation Clock Radio System can be used with a cord ... 1) 10 high quality digital recordings .... 150 Milford Road, East Windsor, NJ 08520.
Muse - Alarm clock radio
www.muse-europe.com/en/products/alarm-clock-radio
Catalogue Products, Cat?gorie Alarm clock radio. ... M-125 CRB. Clock radio CD player with MP3 ... M-150 CR. Clock radio ... Automatic time-set clock radio PLL ...
[PDF]FM/AM Clock Radio - Sony
Jan 10, 2016 | Watches
HOW TO STOP ALARM SYSTEM IN AJANTA QWARTZ ODC 120 MODEL WATCH. ALARM KEEPS BEEPING EVERY DAY AND I DONT WANT THAT.
Ask the maker via the Contact page. Looks cheap and nasty!
http://ajantaworld.com/index.php/products/time-products/picture-clock/digital/lcd.html
Sep 28, 2015 | Watches
Synergy global supply model 9105 how to set
http://www.synergythesource.com/doc/alarm-clock-setup-910500.pdf
Quick Setup
Model 9105
Alarm Clock Radio
1) Plug clock in before making any adjustments.
2) If using on East Coast- Do nothing! Time and date are set to EST- Daylight Savings time is 'On". Clock is ready to use.
3) If using in time zones other than EST. Hold the clock with LCD facing you. Lean clock back and find small button on bottom right marked P-M-C-E. Hold for 2+ sec. LCD will blink the time zone. Press button again until LCD blinks the correct time zone, CST, MNT, PACIFIC.
4) Daylight Savings time- Default is always on. If you are in a zone that does not recognize daylight savings time. Hold the clock facing you, lean clock back and on bottom left is a small button marked D. Hold 2+ seconds and the LCD will blink ON. Press again and LCD will blink OFF. Daylight savings time is now OFF.
5) If power goes out, clock will retain time and alarm will sound if in the ON position.
6) Replace batteries once every year...!
7) If clock looses time or date:
a. Hold Volume +, and Tuner + at same time for 3 seconds
b. Clock face will blink year
c. Turn outer ring of alarm to set Year
d. Press Tuner + once, turn outer ring to set Month
e. Press Tuner + once, set Day
f. Press Tuner +, set Hour
g. Press Tuner +, set Min.
h. Press Tuner + to save all settings.
You must go through all set points to have them remain in memory. (have to run thru all a - h, can't set just Day or Hour/Min, etc. without starting with Year)
Any questions please call:
Synergy Global Supply
804 435-7520
8:00am-4:00pm EST
Oct 23, 2012 | Audio Players & Recorders
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 | Vacuums
I just got a Memorex Digital CD Alarm Clock with no manul the modle number is MC 7101. I'm not able to set the clock or alarm. I just need the instructions.
To set the clock:
1. With the power off, press the TIME button; the time will blink.
2. Press the MINUTE button to set the present minute and the HOUR button to set the present hour.
Make sure to set the correct AM/PM setting.
3 Press the TIME button (or wait approx. 15 seconds) and the time will be set.
To set or reset alarm time:
1. With the power off, press the desired ALARM, Press and hold the desired ALARM 1 or ALARM 2 button; the alarm time will blink. The Alarm 1 or Alarm 2 time and settings will appear.
Press the MINUTE button to set the alarm.
2. Press and hold the desired ALARM 1 or ALARM 2button; the alarm time will blink.
Press the MINUTE button to set the alarm minute and the HOUR button to set the alarm hour. Make sure
to set AM/PM setting. Press the ALARM 1 or ALARM 2button again (or wait approx. 15 seconds).
3. Repeatedly press the ALARM 1 or ALARM 2 button to select alarm off, alarm on, for buzzer, radio or CD.
If you needed the manual it could be downloaded:
http://www.retrevo.com/support/Memorex-MC7101-Clock-Radios-manual/id/1081dj880/t/2/
Thanks.
gylacz
Aug 01, 2011 | Memorex MC7101 Clock Radio
Just purchased, didn't have any instructions in box. How do I set time and alarm? Thanks
Clock: With the radio off, press the Clock Set button, then the Memory button. The time will start blinking. Use the Hour and Minute buttons to set the alarm time. Press the memory button when you have set the correct time.
Alarm: With the radio off, press the Alarm Set button, then the Memory button. The alarm time will start blinking. Use the Hour and Minute buttons to set the alarm time. Press the memory button when you have set the correct time.
Sep 19, 2010 | Memorex MI4019BLK Alarm Clock Clock Radio...
Alarm time keeps flashing
Switch of at the mains and removed back up batteries, left for a while and then started all over again and for the time being at least it seems to have fixed the problem
Jan 26, 2009 | Audio Players & Recorders
RCA Alarm Clock w/CD Player, AM/FM Stereo & Nature Sounds Logo
191 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
