Question about Whirlpool LHW0050PQ Front Load Washer
Clean pump says... but i dont know where is the pump is??? help..
  • 1,056 Answers
The pump is actually attached to the motor. You would need to turn the washer to its side, and it is accessable underneath.
Posted on Jun 30, 2009
Sd code, not finishing cycle, water coming out door
SD is a suds code. Could be build up in pressure hose for pressure switch or pump can not drain.could be a bad pump. How old is the unit?
Feb 29, 2016 | Kenmore Washing Machines
Indesit pwde 8148 s display f05
take out plug????
take off rear panel
look for the pump
then take of the pipes to it and clean them
allso take the pump apart (3 screws)
and clean it
Jan 13, 2014 | Washing Machines
Pressure on my Goulds 2000 pump went from 60% to 20% after major storm.
Hi im Rossouw
Its pretty comen for minisepal pipes to burst during a big storm due to more presure, also more lickly in winter. i lookt up the pump bt dident realy get speks on it bt i will bet that there is ground in the bilt in filter of the pump, cleaning that out is not recomended if u dont know how, i would get a plumber in and also install a big filter befor the pump to ensure that it dosent hapen in the future.
I am a plumber and if u do want to try to clean it ur self ill read up about ur pump and direct u. thast let me know.
Plz rate my advice or exsplenasion. help me help more ppl thanx!
Jul 11, 2010 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
I have Amana heat pump, I dont know why it does
sounds like your resetting the compressor its going off on high head pressure. check and make sure the condensor coils are clean. and that the fan is running properly.
May 10, 2010 | Amana PTH123B25AJ Heat Pump Air...
My truck keeps shuttin down on me a i dont hear the fuel pump, so i need to know how to do this i have never worked on this fuel pump before and dont know where to start , please help if i had a diaphram...
You should check your Fuel Pump Relay first. If that is good, the fuel pump is in your gas tank. You will have to drain the tank and remove it to replace the unit.
Oct 27, 2009 | 1997 GMC Sierra
It is lighting up on washing machine saying clean pump dont have instruction mannual dont know where pump is
If it is a front load machine you can normaly access the pump from the front sometimes under the kickpanel, There should be a button trap which you can unscrew and clean out the debris. Hope this Helps Kind Regards.
Jul 09, 2009 | Washing Machines
My washing machine works went it wants to its not drawing water ive cleaned the filter but dont know what else to do,
99 out of 100 washers tend not to drain water out due to blockage inside either waste water pipe (also called waste hose, drain hose and etc.) or circulation hose (the one between pump and drum). To check this lay the machine down on one of the side walls, remove the back cover (2 or 4 screws), disconnect hoses from the pump and ensure all blockages are cleaned away, all coins, small socks and other stuff is removed. Also you might want to clean the pump itself as at this point you're more than half-way through.
1 out of 100 drain malfunctions appear due to pump motor or the main PWB, but I bet that you won't need to replace neither of those.
Please let me know if there's something more I can help you with
Good luck
Jun 22, 2009 | Washing Machines
Engine need choke to run but still does not run right. Motorcycle ( 2007 ) has very low mileage. Is there any common problem with the fuel delivery system ( pitcock,fuel pump,choke )or common vacauum...
have you just taken bike from winter storage? carbs could be gummed up (starving fuel) fuel filter could have **** in it (starving fuel) does fuel pump run continuosly? you definately are not getting enough gas. Berrymans B12 fuel additive is very good at breaking down the gum in the fuel system, i dont know where you are and dont know if berrymans is avaliable outside the USA. but some kind of additive whatever you can get that cleans carbs/injectors should help you out there.
good luck
Apr 02, 2009 | 2004 Vento Gladiator XLS
Clean pump!
remove bottom panel torx or 7 mm nut driver needed.pump has "knob" turn counter clock wise ..have plenty of towels handy to unlock door first reach up to bottom of door lock tear shaped plastic tab pull down door will open
Apr 26, 2008 | Whirlpool AWM8143 Front Load Washer
Troubleshooting reddy heater 115,000btu
Remove the nozzle and clean it. Clean the photo cell also. Check the fuel pump pressure it should be 5.1 #.
Feb 26, 2008 | Desa International ReddyHeater® R115DT...
Whirlpool LHW0050PQ Front Load Washer Logo
97 people viewed this question
Dan Webster
Dan Webster
Sal De
