Question about Toshiba E-Studio167 Copier
My Toshiba e studio 167 is showing a c44 error code. What should I do?
  • 313 Answers
The c44 error is an error in the fuser if you know how to take the fuser out check for toner buld up on the thermistors.. the sensors with the thin strip that presses against the hot roller gets toner build up and cant read temp properly.. you could also try turning machine off and then on whilst pressing 1 3 and * buttons together this might reset it temporarily for you.. Good Luck A
Posted on Jun 30, 2009
  • 2 more comments
  • clavier_2012 Oct 19, 2010
    It's Right Thanks you Much
  • Sanjay Parihar
    Sanjay Parihar Apr 28, 2014
    not 1 3 * its 0+8 m/c on type 400 & set 0 ok ok ok
  • YUSSEF
    YUSSEF May 29, 2014
    WAOUH THANK YOU
  • Mahmuddullah
    Mahmuddullah Dec 02, 2015
    lot of thanks sanjoy parihar bro
My Toshiba e studio 207 is showing call for service c44 error code. What should I do
Posted on Jul 28, 2010
My machine showing error code F14 what i do
Posted on Nov 12, 2010
Its the problem of heater section , may be from connector or may be power supply problem.
pragya
Posted on Jul 22, 2009
  • Toshiba Expert
  • 414 Answers
You can try going into (08) mode by holding 0 and 8 while turning on the copier. Once the copier starts up key in 400 and press start, input "0" and press interrupt.
087564572039
Posted on Aug 17, 2012
Please wait showing in toshiba es-167
Posted on May 22, 2010
2 Suggested Answers
  • 66 Answers
SOURCE: error c44 call for service
C44-Heater abnormality after abnormality judgment: The temperature of the fuser roller has exceeded the range of control or does not even reach the range.
You can try going into (08) mode by holding 0 and 8 while turning on the copier. Once the copier starts up key in 400 and press start, input "0" and press interrupt. Try rebooting the copier, if this doesn't clear that call for service then you are going to need to get work done on your fuser.
Posted on Oct 04, 2010
I have atoshiba e-studio 167 machine wich shows error code C41
Hi
The error means that the thermistor or heater abnormality at power-ON.
i think you should contact the provider.
Error Codes Toshiba Studio 167 Code C41
May 23, 2016 | Toshiba E-studio 167 B & W Copier....
Toshiba estudio 167 c44 code detail
Aug 02, 2014 | Toshiba E-Studio 167 estudio167
Toshiba e studio 18 error c43 how to reset
Dear sir i have to problem in Toshiba estudio 18 error c44
and fuser unit check ok but please tell as error reset
Jan 05, 2014 | Office Equipment & Supplies
Error c44 studio
codes c43, c44, c45
problem with the fuser
thermistor review
thermal fuse
check connectors
Dec 05, 2013 | Toshiba e-Studio 35 Copier
TOSHIBA E STUDIO 207 ERROR C 44
All error code soloution of fuser unit Fuser Unit Error Status Counter
Purpose
When a fuser unit related error (error code C41, C43, C44 or C45) occurs, the set value of the fuser status
counter varies, depending on type of error.
Displaying and checking the set value of the fuser status counter can analyze a cause for the error. If
any of "2 to 9" is set at the fuser status counter, the fuser unit will not be operated for safety reasons.
After the fuser unit related error is resolved, if "0" is set, the fuser unit will be operated as usual. If any of
"10 to 19" is set at the fuser status counter, the fuser unit will be operated as usual, even if "0" is not set
after the fuser unit related error is resolved.
C41: Thermistor or heater abnormality at power-ON
C43: Thermistor abnormality after abnormality judgment
C44: Heater abnormality after abnormality judgment
C45: Thermistor abnormality during printing
C46 to C49: Reserved
Description
When this code is used, the current set value of the fuser status counter is displayed. Only "0" can be
manually entered, in order to restore the fuser unit to its normal operation, after the fuser unit related
error is resolved.
For further reason why the counter value differs despite the same error code, refer to 5.1.7 or 5.1.8
[Fuser unit related service call] in the Service Handbook.
0: No error 10: C47 (Reserved)
1: C41 (Once) 11: C47 (Reserved)
2: C41 (Consecutively occurs) 12: C48 (Reserved)
3: C46 (Reserved) 13: C49 (Reserved)
4: C43 14: C47 (Reserved)
5: C44 15: C48 (Reserved)
6: C45 16: C49 (Reserved)
7: C44 17: C47 (Reserved)
8: C45 18: C48 (Reserved)
9: C44 19: C49 (Reserved)
* Default: 0
Setting Timing
Use this code to resolve the fuser unit related error (error code C41, C43, C44 or C45). Resolve the
error, and set "0" (or reset the counter), in order to restore the fuser unit to its normal operation.
Caution
Remember to resolve the fuser unit related error, and then reset to "0."
Jul 08, 2012 | Toshiba E Studio 207
Error codes and their meaning for Toshiba e-studio 181 copier
toshiba e-studio 181 is not working. It shows that cover is open symbol and tells the same and the printer is woken up. what to do to rectify it.pls
Apr 27, 2012 | Toshiba e-Studio 232 Black and White...
I am looking to reset my toshiba studio 163 spanner signal.the machien stoped functioning. i need he reset code.
Hello
Fisrt off please hold down the 8+C buttons together, there will show a error code in the copy quantity display.
Now not knowing what the error code is, i am going to hope that it is C44 that is the most common
error code on the E163 machine. If it is C44 please do the following.
Switch off the machine.
While holding down 0+8 buttons, switch on the machine.
When ad shows on the display, input 400 then press the start button.
If the value is not 0, input 0 button and press the interupt and energy saver buttons to save the change.
Switch off the machine wait awhile and then switch the machine on again.
The problem should be sorted out.
If the error code is not C44 you will have to let us know what the error code is, by holding the8+0 buttons down together.
Here is hoping the machine is working
Regards
Apr 15, 2011 | Toshiba e-Studio163 Copier
Can we refill toshiba e-studio 207 Tonar Cartige ( Cartige No.T-1640D
sir i have Toshiba 207 copier sir now write on screen call for service C44 sir please solve my this problem thanks
Sep 03, 2009 | Toshiba e-Studio 205 Copier
Toshiba 160 error code
c44 = fuser error
turn copier off
hold down 0 & 8 while turning it on
then wait one min, then press 4 0 0 start
then 0 and set
turn off wait one min then turn on if this does not work it might need parts
Mar 31, 2008 | Toshiba e-Studio163 Copier
Toshiba E-Studio 160
When the message call for service is displayed
press the C key and the 8 key at the same time
an alpha numeric code will appear eg: C47 etc
Post the error code and I'll tell you what it means
Jan 19, 2008 | Toshiba E-Studio 160 All-In-One Laser...
Toshiba E-Studio167 Copier Logo
3,269 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
