Question about Canon Office Equipment & Supplies
Canon Toolbox 4.9 - internal error 2878 program folder list box Canon. Vista Sp1
  • 5 more comments
  • dpullen511 Jul 01, 2009
    Link refers to a"dmg" file. DMG files are Mac-specific and not designed to open in Windows.
    I am running Windows Vista Sp1. Magic Iso and Power Iso do not help with this file.
    Don
    File downloads and installs OK.
    Opens and runs, does not find scanner.
    Scanner is part of multifunction printer MF4140.
    Don
  • dpullen511 Jul 02, 2009
    This is for printer driver, my problem is with the toolbox. Toolbox can't find the scanner.
    I have original disk supplied with the printer. I have not used toolbox so do not have a system restore time where it worked.
    As far as I can see it has never worked.
    Don
    Printer prints and copies no problems.
    Problem is solely with the Toolbox for this printer - doesn't recognise or find the scanner.
    Paint shop and adobe find scanner, can scan to OCR.
    I am trying to set up system to scan to E-Mail and scan to PDF.
    Don
  • dpullen511 Jul 03, 2009
    None of suggestions work so I have decided to buy software for Scan to E-Mail.
    Thanks for your assistance
    Thank you four help
  • 615 Answers
1.Uninstall the SCANNER software restart the computer and reinstall whole canon multifunction printer software and driver.
2. Restore the system to earlier time when scanner software working correct
3. make sure cables are correct If prints correctly there is no faulty usb cable
you can download drivers here
http://support-in.canon-asia.com/contents/IN/EN/0900647801.html
Posted on Jul 01, 2009
    President:
  • 1,383 Answers
First uninstall old Canon Toolbox 4.9 software from control panel ->add remove program
then install aagin .
You can downlaod it from here.
http://download.cnet.com/Canon-CanoScan-Toolbox/3000-2118_4-98033.html
Posted on Jun 30, 2009
Lide 60 not working in mountain lion
Guide to installing Canon CanoScan LiDE 35, 50 and 60 on Mac OS X 10.8. Mountain Lion:
FIRST PART: DELETING OLD LiDE DRIVERS AND SOFTWARE
  • If this is the first attempt to install the scanner, skip this part
  • Trash the following files/folders from these folders:
HD:/Library/Image Capture/Twain Data Sources
delete the CanoScan CanoScan XXXX.ds file
(Make note of any other files that may be in this folder. If other files are present, move them to the desktop for now. Then place them back after successfully using the scanner.)
HD:/Library/Preferences
delete the 'CanoScan XXXX' folder
HD:/Users/Shared
delete the folders containing the name CanoScan, or starting with CNQL.
HD:/Applications
delete the CanoScan Toolbox Application
HD:/Users/YOUR-MAC-USERNAME/Library/Preferences
delete any items named "CanoScan Toolbox"
  • Restart your computer, then empty the trash
SECOND PART: MAKING YOUR SCANNER WORK
  • Make sure your scanner is well connected
  • Download the right driver depending on your Model. Also download the Scanner Software. Copy the filenames and search them via Google. Make sure you download the Canon files from an official Canon domain.
CanoScan LiDE 50 and LiDE 35 work both with the 35 driver:
lide35osx7721en.dmg
CanoScan LiDE 60 driver:
lide60osx11131en.dmg
VueScan Software:
http://www.hamrick.com/#download
VueScan 9.2 (or later) x32 for Mac OS X
Alternative to VueScan: CanoScan Toolbox. I prefer VueScan.
Try your luck with Version 4 or Version 5.
CanoScan Toolbox 4: cstbosx4934ej4.dmg
CanoScan Toolbox 5: cstbosx5014ej4.dmg
  • Open the downloaded driver file (lide35osx7721en.dmg or lide60osx11131en.dmg)
  • and Double-click the ScanGear file, install and restart when prompted
  • Open the downloaded VueScan file (vuex3292.dmg) and drag the VueScan application to the Mac Applications folder
  • Open the VueScan application. The scanner should be recognized automatically.
(Alternatively try and install CanoScan Toolbox 4 or 5)
Nov 04, 2012 | Canon Office Equipment & Supplies
Tip
Top 10 things to remember before installing WIN7
In this guide I will point out some important things that you need to do and remember before installing Windows 7 on your machine.
1 : Check the hardware requirement :- This is one of the most important factors that you need to keep in mind before thinking about Windows 7.Though Windows 7 should run fine with the 512 MB RAM system, it’s always better to follow Microsoft recommendations. Below are the Windows 7 requirements:
• A blank DVD
• A PC with a DVD burner
• A test PC for the Windows 7 Beta that meets these minimum hardware.
Recommendations (specific to the Beta and subject to change in the final version of Windows 7). Please do not use a PC you rely on for your work or daily use
• 1 GHz 32-bit or 64-bit processor
• 1 GB of system memory
• 16 GB of available disk space
• Support for DirectX 9 graphics with 128 MB memory (in order to enable Aero theme)
• DVD-R/W Drive
• Internet access (to download the Beta and get updates)
2 : Backup Vista :- If you are planning to upgrade from Vista SP1(SP1 is must) then it’s a good idea to backup your Vista drive so that you can revert back to Vista easily. I hope most of you know how to do back up task!
3 : You need to backup all your profiles and other important files that I have listed below. In case you are planning to wipe out Vista and install Windows 7 then also it’s better to create a backup of all profiles. Below are the important profiles that I backup:
• Documents
• Outlook pst file
• Windows live writer folder
• Saved games
• Other program profiles that you use.
4 : The most important thing for a web addict is browser bookmark folder. Use backup Bookmarks option in your browser to create a bookmark. Download Password Exporter add-on for Firefox to backup all your saved passwords. Also don’t forgot jot down all installed add-ons!
You can even use Mozilla Restorator to backup full Firefox profile.
5: If you have installed too many programs then it’s a good idea to generate list of installed application using a simple command that I have explained in the Generate list of installed applications guide.
6: Next obvious task is to backup all the custom settings that you have done to your Vista. Of course, you can back up! Type Windows Easy Transfer in Start Menu search box and hit enter to open. Follow the simple instructions to complete the task.
Windows Easy Transfer helps you move your files, folders, and program settings from one computer to another—all in one process.
Using Windows Easy Transfer, you can choose to move:
• User accounts
• Documents
• Music
• Pictures
• E–mail
• Internet favorites
• Program settings
7 : Move your Download folder from the “C” drive to any other safe location so that you will not lose the downloaded files.
8 : Though Microsoft recommends 16GB drive to install Windows 7 I recommend at least 30GB so that you won’t run out of free space in near feature.
9 : If you have any files in Desktop just move to safe place since most of us keep important files on Desktop for quick access.
10 : Last but least, don’t forget to retrieve Office and other product keys.
on May 11, 2010 | Computers & Internet
Tip
Canon image CLASS MF5700 Series Scanning
Scanning with [Start] on the Machine
By pressing [SCAN] [Start] on the operation panel of the machine, you can scan
documents to your computer.
Pressing [SCAN] [Start] has the same effect as clicking [Save] in the MF Toolbox.
You can change the settings for [Save], or set up a button other than [Save] to
perform the same operation. (See “Setting the Scanning Function for [Start],” on p.
3-3.)
NOTE
You can use the machine for only a local scanner (connected directly to your computer).
1 Place the document face-down on the platen glass or load it
face-up in the ADF
2 Press [SCAN] [Start] on the machine.
If you are asked to select a program to launch, select “MF Toolbox Ver4.7.”
Scanning starts.
The MF Toolbox and the [Save] dialog box will open, but the document will be
scanned without pressing [Start] in the [Save] dialog box.
The scanned document will be processed according to your settings.
When you use [Start] for the first time, a folder with the scanning date will be created in
the [My Pictures] folder in the [My Documents] folder, and your document will be
saved in this folder. If there is no [My Pictures] folder, the folder with the scanning date
will be created in the [My Documents] folder and your document will be saved in this
folder2 Press [SCAN] [Start] on the machine.
Scanning starts.
Scanning starts.
folder
on Dec 08, 2009 | Office Equipment & Supplies
CANNOT INSTAL CANON n1240U SCANNER ON WINDOWS 7
Your scanner model is not supported on windows 7.
Jun 07, 2011 | Canon CanoScan N1240U Flatbed Scanner
I need to install a sound drive on my pc, my motherboard model is ibm fru pn 13r8926, please help me
Hi, you can download this program here:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-73783
It will find the the driver for you.
IBM has changed name to LENOVO.
Lenovo ThinkVantage Toolbox
for Microsoft(R) Windows(R) 7/Vista/XP
Version 6.0.5717.35
Installation Readme
IMPORTANT NOTE: This program will only run on Lenovo
Thinkpad/ThinkCentre/ThinkStation systems that run a 32-bit version
of Windows 7, Vista or Windows XP Pro (SP 3 or greater).
Microsoft .Net Framework 3.5 SP1 must be installed for the program
to work correctly.
This package installs the full version of Lenovo ThinkVantage Toolbox.
This package requires approximately 120MB of space on your hard
drive once installed. During the installation process, up to 300 MB
is required.
Downloading the package
1. Click the file link to download the file from the Web page.
2. When prompted, select a drive and directory in which to save
the downloaded file.
Installing the package
1. Navigate to the folder where you saved the installation file,
lttsetup_60571735x86.exe.
2. Double-click the installation file icon to start the installation.
3. Step through the wizard that will install Lenovo ThinkVantage Toolbox
on your system.
Hope this was helpfull.
Mar 27, 2011 | IBM (13r8926) Motherboard
Cannot install toolbox
1. Start -> Click Run
2. Enter msconfig and click ok
3. Click Startup tab
4. Uncheck program that you don't want to startup
You can disable programs that you don't want automatically load when you start your computer. By disabling these programs will help your computer startup faster.
5. Click Ok and restart
Now you should notice that your computer startup faster.
My Hot Tips to Make Your Computer Faster:
* Regularly check your startup folder to prevent malicious programs installed itself without your knowledge.
* Delete the temporary files from Temp folder (Start > Run > %temp% > delete all files).
* Upgrade your RAM to makes your computer boot faster : )
I hope this article can helps you to make your computer faster..
Aug 22, 2009 | Canon CanoScan 3000F Flatbed Scanner
An error message when i try to scan
On the CanoScan Toolbox program bar, select settings. Then hit the Browse button next to "Select Folder where Temporary Files are Saved" and go up one level to Canon from TB50. Then hit OK. This fixed the problem for me after Microsoft Updateinstalled updated Canon drivers. It looks like the geniuses at Canon are either having you write to a write-protect folder or one that only has system permissions and then giving you a disk-full error.
Mar 25, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Canon ScanGear CS driver error Code: 2,252,0 - Can't preview Actually I have the Canon CanoScan LiDE 80 Flatbed Scanner - but this wasn't presented as an option, so I thought I'd try the nearest...
Canon ScanGear CS driver error Code: 2,252,0. Error when trying to Preview scan using ScanGear in your program, e.g. Word, PhotoShop...
I had the same problem, Canon Technical were clueless on this error code. Yes the problem occured when trying to preview first however I could scan but without any preview, pointless really.
I have fixed it for Windows Xp SP3, Canon Lide 80. To Fix:
You need to download the latest ScanGear driver and Deldrv.exe from the canon website. You don't need the Toolbox, http://software.canon-europe.com/
It would help if you have Tuneup 2009 (even Trail version) for the later parts of this fix: http://www.tune-up.com/download/ just click download, you don't need to give them your email address.
1. Save these on C:
2. Remove the USB cable from your scanner - make sure it is unplugged.
3. Run Deldrv.exe, select your scanner and uninstall.
4. Now you will need to go into 'C:/WINDOWS/TWAIN_32' folder; you must remove anything in this folder - safest thing to do is CUT any items and paste them on the C: or personal folder.
5. Now the register parts - you need to purge your registry of any left over values. I found out after several attempts that this final step fixed the problem for me.
Basically through Windows XP Regedit or TuneUp Reg Editor search the ENTIRE registry for first 'ScanGear', second, 'Canon' and third if you have installed previously, 'Canon Toolbox'. Find any entries relating to any Canon scanner software and delete them. I only found around 6 or 7 entries to remove.
6. If you have TuneUp run '1-Click maintence' (correct problems) and afterwards run the 'Register defragger'. Restart.
7. On the next bootup your register should be optimised. Ok, disable any Anti-virus software.
8. Run the scangear setup winzip file you saved on C:. * it will extract a folder to C:. If get an error with the extraction, try running it anywhere else except C drive. Alternatively if you have WinRar, right click and manual extract contents. The scangear setup winzip file/folder (called lide80vst7250a_xpen) only contained a readme and setupSG.exe.
9. You must run the setupSG inside this folder. And you're done. Enable your anti-virus.
9. Now connect USB to scanner, Windows should pick it up. Open Word or PhotoShop > run the scangear program to preview.
10. Done! It worked my end.
Please let me know if this helped you.
Mar 14, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Driver for D646U Scanner
This printer was only supported in the US for Windows 98/ME but it worked with XP. The odd thing is that foreign sites continued to offer the driver for vista both 32 and 64 bit. But the US site dropped it. Here's how you can get it working and not have to read Portuguese.
Order is important, follow these steps exactly...
1. Go to www.canon.ca, click on downloads, and then click consumer products. Then click scanners and find the d646u on the list. Click the download drivers link after this.
2. Download number 1, 2 and 5 on the list.
3. Install them in the following order: 5(deletion utility), 2(scanner drivers: it doesn't matter what folder you open them to), and then 1(toolbox).
4. The computer will reset after toolbox is installed.
It should work after all this.
Jul 31, 2008 | Office Equipment & Supplies
Canon 4200f - Mac OS-X compatability
This solution does not work. On MAc there is no way to use this scanner. Canon sucks!!! There was no info about supported os on the box. It is just unfair to sell products without providing drivers for users.
Oct 24, 2007 | Canon CanoScan 4200F Flatbed Scanner
247 people viewed this question
old marine
old marine
