Question about Brother HL 2140 Laser Printer
Brother HL-2140 Corona Clean Error Won't Go Away!!!
Bought a refurbrished Brother HL-2140 Laster Printer cheap from Office Depot, but ready to throw it out the window of the hotel I'm staying in.... I'm getting the same Corona Wire Cleaning error that everyone else seems to have gotten, and now I can't print more than one or two pages without having to "clean" and reset the cartridge several times.
Is there a way to override this error altogether as it's clearly not a "real error"?
The error message is misleading. The printer wants a new toner cartridge.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002500/000026/faq002526_000.html?reg=us&c=us&lang=en&prod=hl2140_all
Posted on Jul 04, 2009
I has this same problem and found this on youtube. It worked for me. Try it. you may need to copy and paste the link.
http://www.youtube.com/watch?v=hPCGZZIdXyM
Posted on Dec 04, 2009
My printer HP ( HL-2140 laser ) print out a black sheet?
This will be the Corona Wire on the drum has broken. Replace the Corona Wire if you are technically minded or replace the drum unit if you are not.
Jan 10, 2015 | Brother HL 2140 Laser Printer
How do i clean the corona wire for my hl-2140 printer?
Well the best solution for the corona wire is to change it. It is the best and safest solution.
If you need further details and assistance please leave a comment. Cheers
Aug 25, 2010 | Brother HL 2140 Laser Printer
HL-2140 Clean Corona wire Message won't go away.
you have to take out the drum and on top of the drum unit, there is a blue color plastic which can be slide from left to right... just slide a few times from left to right...that will clean the corona wire .
Jun 15, 2010 | Brother HL 2140 Laser Printer
If you are getting "clean corona wire" on your PC and the toner light on the machine is solid, you need to change your toner cartridge.
This is a bug in the brother software.
Thanks,
Pat
May 11, 2010 | Brother HL 2140 Laser Printer
Get a clean the corona wire. Have removed the
Try using canned air to blow out that corona area, and then a Q-tip moist with alcohol to gently wipe the corona wire, if all that fails you will need a new drum.
Also press the go button 3 times so you get a printout and check that you are getting a clean the drum error or something else.
Dec 18, 2009 | Brother HL 2140 Laser Printer
Get error light when trying to print labels - HL 2140
The driver should pop up a error message. Possibly is due to clean corona wire. Slide the blue lever several times across (at the drum unit).
Dec 10, 2009 | Brother HL 2140 Laser Printer
Printer won't print error message corona wire needs cleaning
When you experience a persistent problem like this right at the beginning - listen to your own good advice. Take it back to the store and exchange it for a new one.
Jul 30, 2009 | Brother HL 2140 Laser Printer
Its said error and drum and its womt print??
You need to take out the drum and find the blue tab on top, run it back and forth about 20 times to clean the corona wire. When that doesn't help you open the door and hold the go button til all lights flash and then close door. Drum error should go away. Press go 3 times for a printed report.
Jul 03, 2009 | Brother HL 2140 Laser Printer
CORONA WIRE CLEANING
SWARNAVA has the most common wrong answer to this problem...
I am waiting for a firmware update to fix this issue. The only solution is repeatedly removing the drum/toner, moving the green cleaner back and forth, putting it all back together loosely, putting it in the printer loosely, and closing the door gently. Hold down the blue button until all the lights glow, then release. If you're lucky you only have to repeat this process a dozen times until you trick the sensor into not giving false readings.
Jan 20, 2009 | Brother HL 2140 Laser Printer
Brother HL 2140 Laser Printer Logo
971 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
