Question about Sony PlayStation 2 Slimline Console
PS2 Slim Drive not working
Hi I have a V.12 (SCPH 70004) slimline PS2. The drive is not working i.e. the laser does not move to position when imitating a CD in the drive and the motor is not spinning. There is power to the rest of the PS2. The power LED and fan is running. I tried the following already:
a) Replaced the complete laser cradle - no joy.
b) Bridged the lid sensor at the back.
c) Replaced the power switch.
d) Tested all fuses - in order.
e) Checked for loose connections on the ribbon cable housings.
I would like to solve the problem myself. Any help will be appreciated.
3 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: ps2 slim line
if the laser is moved to the middle of the area and when you first turn it on it doesn't go back to starting possession's then some thing is wrong with the motor drive more than not it's likely you have a crack in the board.
Posted on Jan 04, 2008
  • 23 Answers
SOURCE: want ps2 slim to play multi zone dvds is there a code
the code should be 0000
Posted on Dec 07, 2008
PS2 Modchip and Laser Fix installation Failure ...
I bough ps2 with cracked after 3-4 days not working dvds are not read.
sometime it's working some dvds..
so plz solve my problem...
May 28, 2012 | Sony PlayStation 2 Slimline Console
Slim ps2 can it have a hdd attached
Hi The_Blaster0
im afraid you cant get a HDD on the slimline but you can buy a 64 MB memory card for around £13-£15
they look like this
you can buy them on ebay and amazon.
Dec 18, 2008 | Sony PlayStation 2 Slimline Console
PS2 Modded Trouble Reading DVDr's
Your DVD potentiometer pot on the back of the PS2 laser lens needs to be readjusted. Some people will try to tell you it's out of alignment but if that was the case it would not read CD's. Some people will try to tell you the laser lens is bad. If that was the case it would not read CD's. On the back of the laser lens are two potentiometer pots. In english? Two lil screws that are turnable. One controls the power of the DVD laser one controls the power of the CD laser.
http://www.cyber-mag.com/station/laserV9.htm
That link will give you pretty lil pictures of what i'm talking about :)
In a nut shell the story goes like this folks. If your PS2 won't read certain game DVD's that are of a certain color or if it all of a sudden mysteriously fails to read games it once read but will play cd's just fine, the voltage of the laser for DVD's is not set correctly. (this does needs manual tweeking from time to time if you take your ps2 and move it around alot or if you take it over to friends houses etc etc. Basicly alot of movment in general can take this out of alignment. Even keeping the PS2 on it's side could theoreticly (just my opinion) based on gravitational pull, unbalance the potentiometer.
RESOLUTION:
Step 1 identify your PS2 version:
Version 1 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U1"
Version 2 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U0"
Version 3 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U2"
Version 4 - SCPH-30000, 30001, 35001, 30002, 35002, 30003, 35003, 30004, or 35004, 8 screws on bottom of case
NOTE: Version 4 has 2 varieties of motherboard: Gap/No Gap, the difference between v4 "Gap" and v4 "No Gap" is the "Gap" is there's a spot in the center of bios chip where each side lacks solder points.
Version 5 - SCPH-30000R, 30001R, 30002R, 30003R, 30004R, or 30006R. Also, some SCPH-30000, 30001, 30002, 30003, and 30004 models have a V5/V6
NOTE: Version 5 & 6 - the difference between these two versions is one of the connectors in the corner.
Version 7 - SCPH-39000, 39001, 39002, 39003, 39004, 39008 or 37000
Version 8 - Only in Japanese consoles. SCPH-39000, or, SCPH-39006 (GH-022 BIOS 090)
Version 9 - if you have SCPH-50000, 50001, 50002, 50003, 50004, 50006, or 50007 you have a v9 or v10 board.
Version 10 - SCPH-5000x, with date code "3D" to the right and below the serial number on the back of the console. (GH-026 board)
NOTE: To know if its a v9/v10 start up PS2 with no game in it ,press triangle and check dvd driver version dvd ver 3.00 = v9 & dvd ver 3.02 = v10.
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find a small ''a'' under the SCPH number or have DATECODE "3C" you have a V9 PS2 main board. (GH-026 board).
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find DATE CODE "3D" as shown below, you have a V10 PS2 main board. (GH-026 board).
Version 12 - The new slimline PS2 consoles are referred to as PSTwo here, but elsewhere they are also known as "v12" units... their numbers are SCPH-70011/SCPH-70012, and also SCPH-70004 CB (Belgium).
Step 2 use either google or the link above. If you're using google your keyword search will be something like "ps2 v12 laser lens adjustment" *replace v12 with your ps2 model.
In either case navigate to the site and follow instructions to set the pots back to their factory default settings.
Oct 11, 2008 | Sony PlayStation 2 (PS2) Console
Clicking noise, PLEASE HELP!!! PLEASE!!!
That happend to me. All i did was move the piece that holds the laser right down by the part that holds the disc and it worked fine then..
Jul 12, 2008 | Sony PlayStation 2 Slimline Console
Disk read error on slim ps2 scph 75003
hello pauldonp...if this is an early version of the slimline they had a problem with over voltage which inturn took out the laser.your only option may be to replace the laser . sony did bring out a mod for this..i preferr the real old version of the ps2 as they had all separate boards and if one went faulty you didnot have to replace the lot ,also the lasers were a lot cheaper than the later models .in the slim lines the lasers are not all that expensive .they do take a bit of setting up as you have to know the ohms setting on the laser for each model..hope this helps
Feb 08, 2008 | Sony PlayStation 2 Slimline Console
Ps2 slim line
Jan 03, 2008 | Sony PlayStation 2 Slimline Console
Sonyplaystation2 model scph 70002
Check you 1st posting and please check Solved on this one. The solution I placed on your first posting will work. You gave me a Almost there vote on the last posting and it cut my rating. You cannot change it. By Clicking solved on this one will counter your almost there vote.
Nov 09, 2007 | Sony PlayStation 2 Slimline Console
Ps2 discs are not spining
Don't bother changing the lens. If i understand you correctly you have damaged the motor or some circuitry leading to it. I hope this helps! good luck on finding a new one, they are abundant right now!
Jul 21, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 Slimline Console Logo
744 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
