I accidentally unplug my electric range and plug it back but does not work, lights are off
SOURCE: whirlpool gold electric range control panel blinks w/all lights powers oven off
you say after 5 min of plugging in , is this brand new and still covered under your 1st year warr???if so get an authorized servicer out there to take a look at why should you be responsible for their problem
SOURCE: Frigidaire Electric flat top Range
My range will not hold the heat for either the convection or regular heat. the model number is CGLEF385AS2
SOURCE: Whirlpool Gold electric range control panel not working
I live in a new 500 home subdivision. The contractor ordered all Whirlpool Gold products including Electric and Electric/Gas Ranges. Many of my neighbors' panels have gone out! I'm talking about epedemic trouble. My son has had his oven panel (separate from stovetop) fail within the first year. Thank God it was under warranty...this is not a cheap replacement (he had the sensor touch pad. I just had my oven pad fail. I tried to set the clock for Daylight Savings and found out half my panel is out! The fix is a replacement of the panel. Depending on which model (push or sensor) look to spend at least a couple of hundred bucks. We have the Whirlpool Gold microwave panel and so far so good. My neighbor and my son's both went out! They just tossed the two year old products and replaced them with another brand. Sorry to break you the news...class action anyone?
SOURCE: jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
SOURCE: the oven doesn't work
unplg the system for 15 minutes then plug it back it. When you plug it back in make sure everything goes in straight. this is just trying to reset the system
