Question about Dell E228WFP Monitor
Display problem with Dell(TM) E228WFP Entry 22" Widescreen
My LCD (Dell(TM) E228WFP Entry 22" Widescreen Flat Panel LCD Monitor (Analog & DVI)) is behaving abnormally. Whenever I switch on my PC the display automatically goes off after one or two minutes with LED of the monitor still in ON state and when if switch off the physically and switch it back on the display comes back and again goes back after one or two minutes.
    Scholar:
  • 100 Answers
Gandon porvanij. vot ti kto
Posted on Jun 30, 2009
  • 102 Answers
Check ur video card
Auto detect analog
Hi Jessica,
Dell E228WFPC/E228WFP does support displays with 1920x1080 set resolution via DVI connection while it is restricted to validated Dell brand displays:
  • The restriction applies to resolution higher than 1680x1050 via DVI connection.
  • No restriction with VGA connection, which supports up to 1920x1200.
If you use a DVI connection set your computer's resolution to 1680x1050.
http://downloads.dell.com/Manuals/all-products/esuprt_electronics/esuprt_Display/dell-e228wfp_User's%20Guide_en-us.pdf
Feb 19, 2014 | Dell Computers & Internet
I need to connect a VGA dell monitor my Toshiba Laptop
HDMI is digital
VGA (the 15 pin connector) is analog.
If your connector has the digital to analog interface it should work, but likely it does not have that chip and thus will not work.
Your description of the problem tells me it may never work as you have it connected. Possibly it might be that the monitor is required to be powered on before the laptop is booted, but that only works in some cases.
I have also seen some work if a 2-step connector is used.
VGA to DVI connector, followed by DVI to HDMI connector.
DVI was the step toward digital that came before the HDMI standard was implemented and was only partially digital. DVI and VGA do not carry control signals nor audio. HDMI carries both those as well as the video.
YMMV but I think it would be cheaper and more efficient to actually purchase a monitor with a digital input (HDMI or DVI).
Without the digital/analog converter interface a digital output device (your laptop with HDMI out) can never operate an analog device (your Dell monitor with VGA input).
Mar 12, 2017 | Dell E193FPp 19" TFT LCD Flat Panel...
How can i use dvi port
DVI stands for (D)igital (V)ideo (I)nterface.
DVI is a new form of video interface technology made to maximize the quality of flat panel LCD monitors and high-end video graphics cards. It is a replacement for the P&D Plug & Display standard.
you can connect high definition monitor , LCD projector , LCD T.V to a DVI port
There three kind of DVI connector
1. DVI-D (Digital)
2. DVI-A (Analog)
3. DVI-I (Integrated Digital/Analog)
DVI-D format is used for direct digital connections between source video (namely, video cards) and digital LCD (or rare CRD) monitors
DVI-A - High-Res Analog
DVI-A format is used to carry a DVI signal to an analog display, such as a CRD monitor or and HDTV
DVI-I - The Best of Both Worlds
DVI-I format is an integrated cable which is capable of transmitting either a digital-to-digital signal or an analog-to-analog signal, but it will not work transmitting a digital-to-analog or analog-to-digital signal.
How to Recognize These three types of DVI Cable
There are two variables in every DVI connector cable, and each represents one characteristic.
The flat pin on one side denotes whether the cable is digital or analog:
A flat pin with four surrounding pins is either DVI-I or DVI-A
A flat pin alone denotes DVI-D
The pinsets vary depending on whether or not the cable is single- or dual-link:
A solid 27-pin set (rows of 8) for a dual- link cable
Two separated 9-pin sets (rows of 6) for a single-link cable
Jul 12, 2011 | Computers & Internet
If you add a DVI adapter to the the DVI cable going to the Dell Inspiron 580 VGA input, do you get true DVI quality? Can you use a DVI to HDMI adpater?
For the best results, you a straight DVI cable.
VGA is analog, while DVI is digital. The quality will not be as good a a regular DVI cable.
You can use a DVI to HDMI.
I use one going from my PC to TV and the quality is awesome.
Mar 03, 2011 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
Dell228wfp on start up pwr on is green screen
Either the cable is not connected to the proper port or the display-source is not configured properly.Here's what you can try.
  • Ensure that you have connected the VGA/DVI cable in the correct port. If you have an extended graphics card in your computer, use a DVI cable(Digital input) else the VGA would be the only option available.
  • If the cable seems to be plugged at the right place, press the first button from the left on the front panel of your monitor (Button 1 shown in the front view: http://support.dell.com/support/edocs/monitors/E228WFP/En/ug/about.htm#Front_View), once. This toggles the digital mode to analog mode of your monitor, and vice versa.
  • If the first two steps do not work, its not an issue with the monitor. It could be a failing cable or a defective video card, or the system itself is not completing the POST.
Thanks,
Abhishek
Feb 06, 2010 | Dell E228WFP LCD Monitor
Dell e228wfp monitor
in control panel,, go to power option,, go to advanced,, on the option of turn off my monitor,, make it never
Jan 08, 2010 | Dell E228WFP LCD Monitor
My monitor says cable not connected
If it like my monitor, same hookups as yours, then when you want to use the hdmi port you need to disconnect the dvi cable. The monitor cannot read from hdmi & dvi when both are connected, Try this & see if your PS3 works. Good luck
Jul 03, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Hi My name is denise, I have the invision 22" Moniter can you tell me are there build in speakers on the moniter.
http://www.testfreaks.com/blog/review/22-envision-g22lwk-dvi-widescreen-lcd-monitor-wspeakers-black/
Here is a review of the monitor, it says it does have speakers, but not very good review, but most if not all speakers that are built in are not great. I hope this helped, Gym
Dec 21, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
Compatible with Mac?
I have the same problem.  Did you find a solution or just return it?
Jul 21, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Dell E228WFP Monitor Logo
315 people viewed this question
Alun Cox
