Question about Canon PowerShot A75 Digital Camera
My camera keeps saying card locked and its not locked and i have tried other SD CARDS and its saying the same thing! please help?
  • 315 Answers
Okey, this can be tricky, but it worked for me.
I have Canon Ixus 60 and Kingston SD 1gb memory card.
After loading set of images on my laptop and putting the card back in to camera, screen displayed "Card Locked!" message.
I did everything to check the common flaws, but still the same message occured.
Material needed:
1 paper clip
The socket for memory card has this tiny detector for sensoring if the card is locked or not (same side as the lock switch on the MC). For some reason it was sticking out from the side. So, little fiddling with paper clip to put the detector back in and another try to put the camera on, everything worked out just fine.
Posted on Jun 30, 2009
  • Canon Master
  • 4,738 Answers
The following similar to guru_dev's recommendation, but would instead recommend using a non-metallic prod.
If you've reset the card's locking slide switch, and it's still showing locked, it's likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you'll see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glint's of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Somehow, the locking switch is making contact and has become stuck in the locked position (a single grain of sand can jam it there). With a plastic toothpick, or other skinny NON-METALLIC item, tap and gently push against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, to clear out any gunk that may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics). In this case please see the following (xscrewdriver, hope you don't mind me referencing your blog):
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
Posted on Jul 11, 2009
3 Suggested Answers
TXPandY
  • 6 Answers
SOURCE: screen reads SD CARD locked
I have 17 of these cameras and for some reason after a while some of them develop this problem. It is very frustrating but I can usually get them to work by taking disk out, turning on camera, put in auto mode, wait for delay to switch to ready then put card in. I works most of the time and if not turn it off and keep trying. Some kind of glitch in the computer I guess. Hope this helps.
Posted on Nov 28, 2008
  • 41 Answers
SOURCE: I have bought a digital
If you have the ability, put the card on something else and format it then try.
Posted on Jul 30, 2011
I have an vivitar vivicam s128 when I put my sd card in it says card protected what can I do
Sure you did not lock the card? The little notch should be in the up position as in the picture. Then the manual says you can use SD cards up to 32 Gbyte, but I can't find anything about the cameras compatibility with SDHC cards. So try the camera with a SD card. The used to make SD cards up to 4 Gbyte, but today, even 1 Gbyte cards are SDHC.
1- check Lock
2- Use SD card to see if your camera works with that.
See a 4GB card, only SD, but not for sale anymore.
25340409-k1yyfchjsxnzfpw0twyoxddp-4-0.png 25340409-k1yyfchjsxnzfpw0twyoxddp-4-2.png
Dec 27, 2014 | Vivitar Cameras
My VPC-E760 keeps saying card is locked but the sd card is not locked
For the card locked, make sure that you are using a 2GB or smaller card. The E760 can not use 4GB or larger SDHC cards. 2GB cards can still be purchased on Amazon if your local store no longer carries them. If you are using 2GB, then here are some more tips for card locked.
For the "lens error", see this article for tips and steps that might help you repair it.
Apr 11, 2012 | Sanyo VPC-E760 Digital Camera
Hi, my FZ35 cannot read the SDHC card. The SDHC card is ok and readable on the PC... Please help..
Did you try a plain SD card? Some cameras will not read the SDHC cards...plain SD cards are marked as such and will not be more then 2 GB cards...
Here is a tip that I wrote about SD Cards and how to unlock and lock SD Cards.
If you are getting a memory card locked message then check this out.
How to Unlock SD Card
heatman101
Apr 22, 2011 | Cameras
Anybody please help me!!! when I take picture my cam keep saying ''CARD LOCKED''.. how to fix this problem??? Please...
Just like old 1.44 drives, sd cards have locks on them. Take the card out of the camera. Look at the side of it and locate the slide. This lock and unlocks the card. This is a feature to prevent accidental erasure of the card.
Hope this helps.
Apr 13, 2010 | Samsung L100 Digital Camera
I have put a 4gig sd card in my finepix a900 and it keeps saying "card error"
Hello :
Look for a tiny switch on the side of the SD card . This switch indicated [ Lock or Unlock ] . You need to unlock it . If that didn't help , then you need to format the SD card before using it . If that didn't help also , then the problem is with your Camera and not with the SD card . there also must be a sensor in the [ reader on the camera ] which detects the position of the switch. Maybe there is dirt in the sensor. The best way to check would be to try another SD card . but you could try blowing out any possible dirt and see if that fixes the problem . If that didn't help , then you need to format your 4giga SD card before inserting it inside your Camera .
72b3844.jpg PLEASE DON'T FORGET TO RATE !
good luck .
Apr 08, 2010 | Fuji FinePix A820 Digital Camera
A540 says "memory card error" " card locked" but 4gb card is not locked - can access card on card reader - copy on and off. a540 works with 2gb sd card no problem. please help?
The A540 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in this camera. You need to use SD cards, 2GB and smaller.
Jan 13, 2010 | Canon PowerShot A540 Digital Camera
Jazz digital camcorder dv151 will not work
make sure its using the sd memory not cameras internal memory
Nov 30, 2009 | Jazz DV151 Camcorder
Cant use 4gb sd card in my camera why?
The D50 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it will only work with devices specifically designed to accept SDHC cards. The D50 wasn't. It only works with SD cards, 2GB and smaller.
Dec 19, 2008 | Nikon D50 Digital Camera
Screen reads SD CARD locked
Nov 23, 2008 | Moultrie MFH-DGS-100 Digital Camera
Canon PowerShot A75 Digital Camera Logo
1,643 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
