Question about Royal VF1012mx Shredder
Shredder motor runs but gears are not engaging and will not take up paper to be shredded. Model is Royal VF1012mx
    Problem Solver:
  • 8 Answers
I have the same problem and upon removing the gears I found one that is plastic and worn pretty bad. Replacement parts can be purchased at 1-800-222-2310. Part # VF1012MX-08 Gear #2
I advise purchasing the metal one.
Posted on Aug 08, 2009
Thanks for all the advice, I opened it up and one shaft of the gears that drive the cutters is worn and just spins inside the gear. It appears that at one time the chaft or the hole in the gears was a hex. Or possibly there is a snap ring missing. I shook it up quite a bit and found no snap ring. Any thoughts on ease of repair. Or just go out and buy new?
Posted on Feb 13, 2012
My VF 1012mx paper shredder won't feed the paper in order to shred it. Green light is on but nothing happens when I put the paper in.
Does it run in reverse.????
You may just have dirty "eyes" where the paper is inserted, OR they may be defective.
Jun 04, 2011 | Royal VF1012mx Shredder
MY ROYAL CROSS CUT SHREDDER VF1012MX WILL NOT ALLOW ME TO FED MORE INTO SHRED. THE MOTOR RUNS BUT THE BLADES DO NOT TURN. THIS HAPPENED AFTER IT JAMMED AND I REMOVED ALL PAPER.
Most likely broken plastic gear inside...open it up to see which one then contact Royal at 1-800-524-0799 for parts assistance.
Jan 16, 2011 | Royal VF1012mx Shredder
Machine is turned on- constantly running- but will not shred.
You say it is constantly running.....you can hear the motor running all the time???? Clean the "eyes" if there is something dust/tape etc, stuck on or covering the eyes that could account for it running all the time...but you say it will not shred....look into the cutting shafts where you insert the paper and see if the shafts are turning....if they are not; but the motor is running, then you also have likely stripped a gear or teeth inside off a gear. You will have to open the unit up to see what is broken...then contact Royal at 1-800-524-0799 for parts assistance.
Oct 29, 2010 | Royal VF1012mx Shredder
A Royal crosscut shredder that usually only runs in reverse
in the middle of the paper enterance clean sensor
May 22, 2010 | Royal CIA 12X Shredder
Motor runs, but will not accept paper to shred
You say the motor runs...but can you see if the cutting shafts are turning???? if they are not then you have probably stripped a gear...open it up to determine which gear ( after unplugging machine of course.) then give Royal a call at 1-800-524-0799 for parts availability and prices.
Jan 17, 2010 | Royal VF1012mx Shredder
Shredder motor runs but won't shred paper. No
If the motor is running do the cutting shafts turn??? if not then unplug and open up the top to see if any gears are broken/stripped; give Royal a call at 1-800-524-0799 for parts and prices once you've located the problem.
Oct 23, 2009 | Royal VF1000MX Shredder
Royal VF12mx shredder
Pour some shredder oil in the throat where you normally insert the paper...put some shredder oil directly onto 1 sheet of paper and try shredding 1 sheet. If it wont even shred 1 sheet I would ask is the shredder running???
Mar 05, 2009 | Royal VF1012mx Shredder
Have a royal vf1012mx shredder that overloads everytime i try to shred.
Put in less thicknesses. Also, put them in in the center. If they are near the edge and they are at an angle, they will flip over themselves and double the thickness.
It is designed for 12 sheets of paper. They probably figure on 18 pound paper, not 20. Adjust what you put in to allow for this.
Red overload light is on
Try pouring some shredder oil into the throat where you normally insert the paper and run the machine in reverse.Put machine back into ready condition.
Put a piece of paper in the throat just enough so the machine should run but not all the way in so that the cutting mechanism catches the paper...all you want to do is make the machine run forwards but not actually be feeding in any paper.
If it wont even run in the forward direction you may have a pcb prob...give Royal a call at 1-800-524-0799 for parts assistance.
Jan 08, 2009 | Royal VF1012mx Shredder
Royal VF1012mx Shredder Logo
945 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
