Home | U-Line | BI-95 | Give-me plis a wir...
U-Line BI-95
Problem for U-Line BI-95
Give-me plis a wiring digram manual of the Ice
By sergioeletri on Jun 30, 2009
Give-me plis a wiring digram manual of the Ice Maker U-Line BI-95
Best Solution
posted on Jun 30, 2009
Helpful)
admiralstopf
Rank: Guru
Rating: 91%, 81 votes
Your going to call U-line and ask for it. 800-779-2547. Now what are you trying to do? I can give you the wires on the thermostat. Terminal 1 is red(icemaker) Terminal 2 is yellow(common) Terminal 3 is blue/black(compressor and cond fan motor) When yellow and blue or black are closed this will run the compressor and fan.Thermostat is satisfied then the red and yellow are closed and it advances the icemaker. Ejector blade at the 12 oclock calls for freeze cycle. at 2 calls for heater to come on(inside icamaker) at 10 oclock it trios the water switch and calls for water.Then back at 12 oclock calls for freeze cycle. Temps should be 10-15 degrees in the bucket. Warmer the setting the more ice it makes.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for U-Line BI-95
Questions and Unsolved Problems for U-Line BI-95
Do you recommend U-Line BI-95?
Answer
Answer
Freezer section not working and on display I have the codes 6 for freezer and 6 for fridge Samsung... (More)
Answer
Water turned on by self rotten egg smell and smoke coming out by ice maker.Turned power and water... (More)
Answer
Need a light switch part for our side by side refrigerator RX2545SH. Switch# 7DR1 61215C. Where can... (More)
Answer
Need to Know where to buy the blue connector that comes from the bottom of the freezer door and... (More)
Answer
need a new door and gasket. Murray
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For U-Line BI-95:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
