Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
No power to external harddrive
Worked fine for a few months now no power to harddrive
havent bumped it or knocked it at all but it has been plugged in constantly
Do you think its a manufacturing problem??
    Scholar:
  • 38 Answers
Yes, without a doubt!
I highly recommend sending it back for repairs or replacement. Most are covered under a 6 month warranty depending on the deal, and the country you are in as well. And computer shops don't generally fix things like External Drives, since they are not as a important part of a PC, but as a backup or storage device.
Good luck mate.
Posted on Jun 30, 2009
Beeping external harddrive
It probably got damaged by the fall. One thing that might sound crazy but i've seen it work a few times, put the drive in the freezer for a few hours and plug it back in. Pull your important data off if it does come up though, because it will not last.
If it still doesnt work, its possible the controller to the drive is damaged, since its external.. the drive might be ok, but theres no way for me to tell from this end. If its the controller, the drive can be removed from the enclosure (will void your warranty) and plugged in on an different interface to remove the files.
If the drive itself is damaged, the way they recover the files is to remove the platters and install them into another drive of the same model and pull the data off. This route is extremely expensive, $1000+. If the files are not extremely important, you'd be better off sending the drive back to the manufacturer and getting it replaced under warranty if it still has one.
Jan 15, 2014 | Transcend Computers & Internet
My external hd (fantom titanium) doesn't regularly open on my mac suddenly
fouad,
Inside the case of that Fantom is a regular harddrive.
Also inside that outer case is a small circuit board, that either the harddrive plugs directly into it; or there is an interface block the harddrive plugs into, and there are wires from it, that connect to the small circuit board.
(The USB cable is connected to the small circuit board)
It is this small circuit board that usually goes bad.
My suggestion is to remove the harddrive inside, purchase an economical external enclosure, and install the harddrive in it.
Have your harddrive back, and be able to use it as an external harddrive again also.
The Harddrive Inside:
Harddrives are measured by their Width.
A laptop harddrive is 2.5 inches across in width. (2-1/2 inches)
A desktop harddrive is 3.5 inches.
The Fantom Titanium II 500GB's harddrive inside, is 3.5 inches,
http://www.newegg.com/Product/Product.aspx?Item=N82E16822204034
Details > Physical Spec > Form Factor > 3.5
What I can't tell you is whether it is an IDE (PATA) harddrive, or a SATA harddrive.
However this external enclosure for 3.5 inch harddrives, is for both IDE, (PATA), and SATA harddrives,
http://www.newegg.com/Product/Product.aspx?Item=N82E16817388014R
[ You can also look at the label on the harddrive, and look up it's model number online, to see if it is IDE or SATA. Just type the model number in your search bar ]
Just want to include information on IDE (PATA), and SATA, in case you are interested,
IDE: http://en.wikipedia.org/wiki/Parallel_ATA
SATA: http://en.wikipedia.org/wiki/Serial_ATA
Regards,
joecoolvette
Jul 27, 2012 | Fantom Titanium II (TFD500C16) 500 GB USB...
SimpleTech 1TB External Hard Drive Silver My hard drive suddenly quit working. I plugged the hard drive in and powered on and the white power indicator light came on then just started flashing. The...
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Jul 25, 2010 | SimpleTech 1TB External USB 2.0 Hard Drive...
I bought a WD5000BEV harddrive in december 2009 and within 6 months it has started giving me problems. Sometimes the computer recognises it and some times it does not. Even thought it appears on the...
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 16, 2010 | Western Digital External USB 2.0 80 GB...
Seagate 1.5TB dropped from office table... TWICE.
the drive is damadged internally, you have to phone or email a data recovery centre to get your data back, that can cost $1500+ because of the size of the disk.
Oct 03, 2009 | Seagate FreeAgent Pro Desktop - 320GB -...
I have a 160GB signature mini external harddrive. It has been working fine for months but all of a sudden my laptop won't recognize when I plug it into the usb port. The red light comes on to show that it...
It sounds like your hard drive is dead. If you have tried it on a different computer and it did the same thing then your drive isn't booting up and is probably bad.
Aug 09, 2009 | SimpleTech Signature Mini 160GB External...
Screen stays black on startup of toshiba satellite L300
have you tried either switching between external and internal monitor usally Fn + F5 on toshiba or try plugging a monitor into the back and see if it displays.
if you get a display on the external monitor then its probably a screen or inverter fault if you donot get a display to an external screen then it is likley t be the graphics on the board itself.
hope this helps
Feb 22, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
I have been using my external usb harddrive for recording (seagate freeagent pro) its been working fine for about a month but earlyer it just stopped, the power light went out and i havent been able to get...
External HDD are similar to the normal internal HDD, only difference is that The physical harddrive is only place into the casing with usb terminal port so you can remove the physical HDD. Your casing's usb terminal may be damaged. Borrow a casing for a external usb HDD from a friend that is working and use it to extract your data to a PC. Hope it helps.
Nov 11, 2008 | Computers & Internet
My simpldrive deluxe external harddrive 160gb doen't power on any more...
Is it a 3.5" or 2.5" drive?
If its a 3.5" the first thing I'd check is the fuse in the plug for the power supply (if you're in the UK)?
If changing the fuse doesn't work it could be a problem with the power pack within the external HDD. Is it under warranty? You my be able to get it repaired or a new one (Don't forget, if you open up the fasia of the hard drive you will void the warranty). I assume you're not worried about data on the drive as you are happy to format it. If you are worried about data and it isn't under warranty/garantee I can tell you how to get the data off if you need me to?
Hope this helps.
Nov 18, 2007 | SimpleTech 160GB USB 2.0 / FireWire...
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
235 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
