Question about Sansui DTV2760 27" TV
Sansui 54cm TV zoom
The picture / screen is zoomed to a smaller picture on my Sansui 54cm TV. How do I restore it back to normal
Push the pip buttton
Posted on Feb 24, 2008
Picture is much smaller than screen size Sony tv
Should be a botton on your remote that changes that..like normal...Zoom..Full screen.And if your useing a antenna sometimes the pictures not as big as the screen. Try a hd video and see if it plays full screen
Aug 13, 2013 | Televison & Video
Emerson 32 HDTV LCD...my picture is smaller than the screen. How do I make the picture fit the screen. I'm missing a few inches of the images on both side...?
Most Emerson remote controls have a "FORMAT" button. Each button press cycles through TV Screen aspect ratio choices, such as Normal, Movie Expand, Wide, Zoom, etc. Pick one that fills your screen. You will probably have to change this setting again, depending on the signal source or channel selected.
The button cycles through the choices in a loop, so you can always get back to Normal.
Mar 24, 2013 | Televison & Video
Tv resolution issue
check zoom on either your tv remote or direct tv remote. someone has hit the zoom button . Its can be called zoom,picture, picture size. You want to get it back to normal. this can be done by hitting one of those buttons repeatedly until you see normal come up.
Apr 07, 2012 | LG Televison & Video
My wife was cleaning the front of our flat screen tv ....she must of hit one of the buttons on the front of the TV ....the picture went smaller How do i get it back to normal size?
Can't changes tv picture screen sizes,when the tv is off.She is cleaning the tv,when it is off wright?Yes.Than the tv programming u are watching stay small screen size the whole entire times even different seen or in commercials?Tv even in difference tv channels,screen sizes are small too?Sometimes tv changes screen sizes by itself to fit the tv programming it is playing to fit it prgramming format it displaying.Still have all small screen sizes all the tv channels.Tv must be on and playing.U have the tv original remote wright?Yes.Try looking on ur tv remote control look for a buttons said like Aspect Ratio,Picture Sizes,ZOOM or VIEWMODE buttons,by pushing one of these buttons on the remote should able to changes tv picture screen sizes.
Apr 13, 2011 | Insignia IS-LCDTV32 32 in. Television
It appears that the image on the screen is zoomed in, but I can't figure out how to "undo" that. Thank you!
If the image on screen is zoomed both in vertical and horizontal direction, your TVs power regulator inside it is faulty. [Overvoltage]. If it is zoomed in vertical direction only, that is only the height of the picture is zoomed, you can adjust it with the remote control button directly on going through menu and get in to the function menu. Normally all TV remote has a special button marked as "Zoom" which on pressing it once the picture get zoomed, again another press the picture gets wide and again an another press picture will come to normal mode. You should select normal mode to retify the problem.
Oct 16, 2010 | Panasonic CT-27SL14 27" TV
When watching a dvd and selecting zoom 1 and changing settings to whats comfortable for us it changes back to smaller screen why is this ? is there away for locking our settings ? its fine with normal TV...
the reason why you have different sizes is due to the resolution on the media. If your DVD player has a resolution upscale, you can set it to the max which should be 1080i or 1080p. this will give you the best picture. Regarding to the setting on your TV. you can go to menu, setting and picture. you can set your setting there for zoom and it will be like that for all your station. Note: if you do that, you will lose some of the edges when watching high resolution programing.
Jun 17, 2009 | LG 37 in. Flat Panel LCD HDTV
PICTURE TO LARGE FOR THE SCREEN AND ZOOM ISNT FIXING IT
Your TV set may have settings for picture size ratios but also if you have cable or sattelite service, they too may have these settings. Try both TV and cable remocons for proper adjustment
Jul 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Zoom in and zoom out
Hi.
Try looking in the menu under PICTURE. see if there is picture size adjustment for picture size eg 16 x 9 4 x 3 normal wide.
Nov 10, 2007 | Bush 2871NTX 28" TV
Picture bigger than screen
This can be caused not enough high voltage going to the picture tube. If the picture seems to get larger and smaller depending on the brightness of the scene on the screen that is probably what it is. IF that is the problem, there isn't much a normal consumer can do.
Nov 08, 2007 | Samsung TXF2899 28" TV
Sansui DTV2760 27" TV Logo
430 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
