Question about LG LRSC-26922 Side by Side Refrigerator
How to fix freezer shelves from falling? - LG LRSC-26922 Side by Side Refrigerator
The freezer shelves in my ge Dss25KGRC side-by-side refrigerator/freezer keep falling down. It seems as though the shelves shrunk and no longer fit. Could it be that the freezer walls have gotten farther...
I had the same problem with my 3 year old GE Adora side by side. Call GE at 1800-386-1215. They were very helpful! They sent me all new shelves and drawers that were obviously wider because they fit perfect(only took a couple days)! Included in the shipment were spacers that I could of put on the ends just in case I needed more width. GE knows about the issue and is dealing with it on a case by case basis.
May 21, 2010 | Refrigerators
Lower shelves keep falling down out of wall supports
replace gromments and reduce the weight that you put inside the shelf/basket.
Apr 22, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have been given an upright freezer Model # HUMo46EB
try and get a technician near by to help you fix it up
Mar 04, 2010 | Freezers
Freezer shelf issue, roller adjustment, Icemaker problems
There is not a recall per say on this issue but there is what's called a training bulletin.. The cabinet tends to spread out causing the shelves to fall out typically in the middle.Some models have wider shelves that will not fall out but also can not be pulled out due to the recess in the sides of the inside of the cabinet. The other fix is installing a little c clip on the sides of the trouble shelf in hopes that it will stop it from falling out. part # is WB4X174 and I have not had good results with them but it is a cheap fix. 2 per side are needed. Ge would have to be contacted to see if wider shelves are available but they are very expensive!
Mar 21, 2017 | GE Profile PSC25MSWSS Stainless Steel...
GE side by side freezer shelves falling down
This appears to be a known problem with at least a couple of GE models (It has been happening in our freezer too). There is a GE Service bulletin at https://customernet.geappliances.com/OTIS/fs/home_images/REF01-10.pdf that seems to describe the fix as them sending out new shelves (and maybe someone to install them?)
Sep 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Shelves not saying in grommets. This happens will
I have exactly the same problem and it is mostly because of the cheap plastic support brackets. I'd like someone to to offer a cheap way to "rig" it so it will support the weight of the shelves when full. Glad tyo know I am not the only one.
Aug 02, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Shelves not wide enough to stay on shelve supports
your ansewer for not the rade qus,,,,,,,,,,,,,,,,,,,,,,, ok
May 22, 2009 | GE EasyCam Webcam
Freezer shelves fall
They are made for ease of installation but unfortunately, not stability. Slightly bend the sides outward, making the shelves slightly larger.
Feb 09, 2009 | GE GSS20IEP Side by Side Refrigerator
Rack on freezer is not working
low on freon. buy new . as freon level drops , ability to feed all shelves falls off. the last shelf to freeze is usually the first one to not freeze ,as charge goes away. time for new, cost to fix to great.
Nov 22, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer Shelves are too small for freezer and keep falling when I put food on them...
I had the same problem with the freezer sheles being too small in my GE Profile side by side. The shelves would simply collapse down with any weight on them.
After measurng the gap, I determined that the shelves were approximately 7/16" too narrow.
The fix I did was simple, effective, and very cheap.
I bought a roll of clear flexible polyethylene tubing at Lowes for about $5.The tubing is 3/8" outer diameter, 1/4" inner diameter (see picture below).
I cut pieces to fit along the side rails of the shelf, and then sliced the tube pieces down their length with a utility knife. I wrapped the pieces around the outside rails on each side of the shelf. It took a little work, but I got the tube pieces attached.
In a few spots, I did a double wrap of tubing.
The shelves fit tightly now and can hold significant weight without collapsing. Plus, they don't look too bad.
I hope GE fixes this simple problem in the future.
2_29_2012_2_35_52_am.jpg2_29_2012_2_36_07_am.jpg2_29_2012_2_36_33_am.jpg2_29_2012_2_36_53_am.jpg
Jan 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
LG LRSC-26922 Side by Side Refrigerator Logo
295 people viewed this question
Top LG Refrigerators Experts
Steve Allison
Steve Allison
deecee73
Level 1 Expert
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
