Most cameras won't let you copy pictures from a computer to the memory card. However you can use a card reader (either built-in to your computer or attached via USB or FireWire). A memory card so connected will appear to your computer as another hard drive and you can copy files to and from it the same way you normally copy files on your computer.
You neglected to specify the make and model of your camera, so I'm going to assume it uses a memory card of some type.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it. DO NOT format the card until you've BACKED UP your files from it (typically to a PC or USB drive (stick or external hard drive).
The memory card for a digital camera is only used to store pictures. The problem with your camera not storing the date correctly is most likely a battery issue. If you let the camera battery completely drain, it will reset to factory settings. If this is not the problem, I would suggest calling the company's tech support line, as they will be able to help you track down the problem.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto on Mac or Windows Photo Gallery on Windows.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
I was having the same problem and contacted Casio. The issue seems to be that there are pictures/video on your internal camera memory which is conflicting with the memory card. Here is the fix:
Turn of the camera and take out your memory card
Turn on the camera, click menu, setup, hit the up circle twice and click reset and click reset again until the camera resets
Then click menu again, setup, hit the up circle twice and click format, click format again until the camera formats
(This will delete the pictures from your memory card so make sure you have them saved)
Turn off the camera and put your memory card back in, turn the camera on again. Repeat the format process for your memory card and you will be good to go!
Once you took pictures without a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures with a memory card, all pictures are just saved on the memory card itself.
If you are seeing 100-757 on the LCD screen. It means that there are already 757 pictures taken from the first time you've used the camera.
It is possible that some of the pictures are in the internal memory and some are in the memory card.
STEPS to DOUBLE CHECK:
1) Remove memory card out of the camera - Turn on camera - View pictures on the internal memory by just pressing on the PLAY mode button
(lowest of the 3 little buttons) - Pictures seen are just the ones saved on the internal memory
2) Return memory card back in the camera - Turn on camera - View pictures on the internal memory by just pressing on the PLAY mode button (
lowest of the 3 little buttons) - Pictures seen are just the ones saved on the memory card itself
*** If you want to transfer pictures on the internal memory of the camera to your MEMORY CARD, you just have to follow the steps below:
- Make sure there is a memory card inside the camera - Turn on camera - Press on PLAY mode button to view pictures - Press MENU/OK button - Keep scrolling to the right until you see COPY TO CARD - Select YES using the arrow keys - Press MENU/OK to confirm * When you've done these steps, all pictures from the INTERNAL MEMORY of the camera will be copied to your MEMORY CARD but it depends on the space left on your memory card
** If still, you could not view the pictures, it's possible that the pictures are really gone when you have transferred the previous pictures to your computer.
** Once you have transferred pictures to your PC, and you have deleted those on your camera, the FILE NAME of the pictures will not start from 100-001 again unless you have reset the file name on the settings of your camera.
In example, i already have 256 pictures on my camera so the filename reads 100-256 for the last picture taken. And then i decided to transfer those 256 pictures to my PC and i deleted those immediately after being transferred. So, as i took another picture, FILENAME will start with 100-257 if i have not reset the FILE NAME settings to 100-001.
hi, i had a problem with my camera where i put in memory card and it said 'out of memory' i took the card out turned on camera went to set up mode and found one that said 'rest to factory defaults' pressed that and then put card in and all ok, might be worth a try :-)
