Question about Konica Minolta Office Equipment & Supplies
Replaced Konica 7022 toner and add toner light stays on
Konica 7022 copier, put new toner bottle in, copier prints 1 copy, then says add toner. Help!
  • 1 more comment
  • Anonymous Mar 19, 2014
    I add toner and it lights up again saying out of toner.
  • Anonymous Mar 25, 2014
    replaced toner but copier keeps saying adding toner
  • Anonymous Mar 30, 2014
    copier adds toner constantly
  • Konica Minolta Master
  • 6,696 Answers
Remove the toner bottle carefully, pwr off and unplug the machine , then plug it in and turn it on do not put toner bottle into machine until asked for.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 13, 2009
Error code F 26-3 on Konica 7022
Sir/mam, you might have a bad drum density sensor or it was not cleaned or was destroyed by static electricity, if a vacuum cleaner was use to remove the old developer, NEVER use a vacuum cleaner for that procedure. Remove the drum and will see a small sensor near where the cleaning blade sits need to clean it replace it. Worse case the main control board is bad that what sensor talks to .Was the L Detect procedure run after the developer was replaced, and before you replaced the developer did you clear the developer counter, to let machine know it has new developer, because clearing the counter is the only way the copier has new developer, did you clear the counter for the new drum? The machine use the counters to determine voltages for certain assemblies. If L detect was not run and copies or prints where made get new developer and start over.
Jul 12, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Replaced the K imaging unit. The new unit does not reflect it being replaced on the copier. Consumables screen shows the K unit at empty still.
"K" is refereeing to the black toner not being full.... I would replace the Black toner bottle. The toners do have a chip on them, you may have got a defective one..... Good Luck
Jan 08, 2013 | Konica Minolta KONICA BR BIZHUB C451...
What's your problem?Minolta EP3050 CSPRO Copier printed copies, then display read ''malfunction detected'' code C0070
Main hopper toner replenishing motor M8 failure to turn.The output from toner bottle home position sensor does not go high within 5 seconds after M8 motor has been energized.Verify the conectors,sensor and motor.Open the front door,turn the toner bottle 1/4 turn clockwise manually with the bottle holder closed.Under the above condition does the toner bottle turn when the front door inter lock switch is turned on?NO - change the toner replenishing M8 motor.Does the toner bottle stop at home position after turning?NO- change PC35 toner bottle home position sensor.Recomanded use vacuum cleaner.
Aug 14, 2012 | Konica Minolta Copier Toner EP6001 CS Pro...
Code C0072
You did not give the model number? So, I'm going to guess, did you just add a new toner? If so remove the new toner bottle and close the door / cover and see if the copier comes to ready? If so, make a copy and when the copy is done install the toner bottle. The error code C0072 deals with the toner hopper motor. If the code will not clear, then you may have a broken gear in the hopper drive unit. Good Luck
Mar 28, 2011 | Konica Minolta Office Equipment & Supplies
Konica 7022 copier f 35-3 code
I have put in new toner yet there is still 'add toner' message on the screen.
What do I do? Please help me.
Aug 03, 2010 | Kyocera KM-1505 Copier
Minolta copier 1030, changed toner makes no copies
take the toner bottle out. turn off the machine then turn it on with the bottle out. once the machine, ask for toner install the bottle.
Jun 18, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 with Problem code F-26-1
There is toner/starter spilled onto a sensor near the drum, it mite just need to be cleaned, this sensor monitors the drums abililty to develope a image, if the cleaning does not work it mite be the sensor or the drum. The drum needs to be removed to clean the sensors.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 (code F-26-1) Pls call service 0870-2425050)
i have a konica 7022 it say call service code F-35-3, what's wrong with it, help me.
Mar 21, 2009 | Toshiba 2060 Copier
Canon Copier Model C122F - error light flashing
A common mistake is that people think that the waste toner needs to be emptied and instead the toner needs to be replaced --- and vice versa. Check to make sure that the toner bottle is not empty. Also, if you made copies that took ( used ) more toner then the machine was able to replenish, the machine has not had a chance to catch up. Place a white sheet of paper on the platen glass and make blank white copies. You may only be able to get 1-2 copies at first but as the device catches up with the toner replenish you should be able to make more. The blank copies you make -- do NOT put that paper right back into the machine. Lay it flat and let it cool, this will help prevent unwanted jamming due to heat build up in the paper. IF you have good amount of new toner in the machine, gently tap the front line ( or rear line) that feeds the used toner into the waste bottle. Sometimes the waste toner will clog and back up into the machine giving false 'waste toner full' message.
Jan 04, 2009 | Canon Office Equipment & Supplies
Minolta Di200f copier
The error code has to do with the toner bottle/hopper. You just adde toner Right? Take the new toner bottle out and make sure not to spill any. Then close the doors of the copier and turn the main power switch OFF then back On. Let the copier warm up to Ready toCopy. Then reinstall the toner bottle and that should do it for you. The toner was out of HP when the toner was replaced. ... Good Luck
Oct 08, 2008 | Konica Minolta DiALTA Di200 Copier
315 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
