Question about Gigabyte Computers & Internet
I need gigabyte fsb 1066 motherboard drivers - Gigabyte Computers & Internet
  • 255 Answers
Download from this link
http://www.lostmydrivers.com/bios-and-system-update-drivers/gigabyte/gigabyte-ga-945gcmx-s2-bios-f1.html
Posted on Jun 30, 2009
    Scholar:
  • 38 Answers
Go to the manufacturing website at http://www.giga-byte.com/
Go to Support & Drivers, and search for your model. You'll find it there. OR if not.. which I doubt.. google is your friend.
How to install memory in a Gigabyte silent pipe motherboard
First, you must determine the applicable memory to your motherboard by reading the manual or it should be indicated in the box.
Ex.:
1600 (O.C.)/1333/1066/800 MHz FSB
4 x 1.8V DDR2 DIMM sockets supporting up to 8 GB of total system memory
With the above details, you can buy up to 4 memory modules, each with a maximum of 2GB. You can also choose your preferred FSB, 1333/1066/800MHz but you can tweak the system and choose the overclock module, 1600MHz. Remember to carefully install your memory module to the memory slot, the notch will give you an idea on how it'll perfectly fit. The left & right holder of the memory will produce a sound after you carefully install the memory modules thus, also indicating of a successful installation.
Hope this gives you a lot of help!
Thanks for using FixYa!
Aug 19, 2014 | Gigabyte Computers & Internet
HI, i have the gigabyte MB GA-945P-S3- and i saw in GIGABYTE web site that i can go with C2D E8400 but with overclocking and saw awhile ago that there are another problem with the CPU MP in the bios of it...
Only the Gigabyte GA-945P-S3 revision 3.3 does allow C2D E8400 or C2D E7500.
However the C2D E8400 only by overclocking, which certainly is not recommended.
So the Gigabyte GA-945P-S3 mainboard revision 3.3, should work with the C2D E7500
with BIOS version FFd and FSB setting at 1066 MHz.
Sep 04, 2011 | Gigabyte GA-945P-S3 Motherboard
I need a vga driver of a gigabyte mother board,
Gigabyte GA-8I845PE-RZ driver
http://www.gigabyte.com/products/product-page.aspx?pid=1768&dl=1#driver
If this answer helpful please vote me.
Good luck.
Jan 17, 2011 | Intel Gigabyte GA-8I845PE-RZ 845PE chipset...
What cpu is compatible with motherboard GIGABYTE GA-965P-DS3
Go to http://www.gigabyte.com/support-downloads/download-center.aspx?kw=GA-965P-DS3
and click on revision 1.0 - 3.3 as there may be additional CPUs supported in Rev 3.3 vs 1.0, you have to determine what specific Revision you have.
Dec 01, 2010 | Gigabyte 965P-DS3 (GA965PDS3) Motherboard
I need vga driver of sis964 that is inbuilt in gigabyte ga-8s661mb
download all drivers from the support website of gigabyte
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1724
May 10, 2010 | Gigabyte Giga-Byte: GA-8S661FXMP-RZ P4...
I am tryin to upgrade my processor on my 4000783 gateway motherboard need to change my fsb speed and dont know how
You cannot change your fsb. You need to upgrade to a cpu with a fsb speed that your board can support. Once you install the new cpu your bios will set the fsb to the higher setting of your new cpu if your board supports it. If you have your board specs it will tell you something like supports fsb 1066/800. That would mean you could upgrade to a supported 1066 fsb cpu. Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | Computers & Internet
1333 FSB processor ( E6850 ) on a 1066 FSB motherboard, DDR2 667 memory
Hi proenza. you're making good sence! You're D945GCL MB should be able to run 1066 FSB. Not 100% sure you're memory will keep FSB up to 1066.
Here's the trouble though. The Intel Core 2 Duo E6850 will not run on the Intel D945GCL motherboard because it is not supported. Look here at Intel's web site. Supported CPU's.
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=d945gcl
Intel E6850 specs sheet. http://www.dealtime.com/xPF-Intel-Intel-Core-2-Duo-E6850-Processor-3-0GHz-4MB-Cache-1333MHz-FSB-Conroe-Dual-Core-OEM-Socket-77
Intel E6700 spec sheet. http://www.dealtime.com/xPF-Intel-Core-2-Duo-E6700-2-67Ghz
This CPU is supported by the D945GCL MB.
Intel Core 2 Duo E4700 Processor BX80557E4700 - 2.60GHz.
$149.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3826343&CatId=2396
In order to get 1066MHz (CPU can run at), you'll also need the memory support at 800MHz. The D945GCL MB can only run DDR2-667MHz.
Many people buy a CPU to run MB's specs (1333MHz) just to find the same MB does not support DDR2-1066MHz or DDR2-800MHz. Motherboard Mfg's are lagging. DDR3-1333MHz is out there now to support the 1333 MHz CPU FSB.
http://www.lagoom.com/KINGSTON_1G_DDR3_1333MHZ_PC3-10667/KVR1333D3N9_1G/partinfo-id-580235.html
I hope this has helped you make a decision proenza.
Good Luck!
Mike
Jul 17, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Open Questions:
Computers & Internet Logo
10,281 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
